Scratch Build – In Progress The green water of class
Discussion in 'Project Logs' started by Corsaronero333, 25 Feb 2012.
  1. james-milligan
    james-milligan Minimodder
    21 Sep 2010
    It does look pretty amazing I must say! Keep up the good work :)
  2. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    I LIKE ! ! ! The murano glass(not the most common of materials) looks sooo beautiful... It must be quite fragile though...
  3. Corsaronero333
    Corsaronero333 What's a Dremel?
    25 Feb 2012
    Thank you master glassblowers are fantastic, and as you say have a high cost, but I can assure you that they are all very well spent.
    For the rest I will have 'surprise still hope
    Thank you so much, I love the glass and all its features
    thanks
    Thanks to the glass you're right, it is not easy to find, but I can assure you that it is fragile, has 18mm thick, the only thing to be careful and tighten the screws, washers are rubber and not too heavy a hand
  4. Corsaronero333
    25 Feb 2012
    As soon as I can see you can place the arrival of the material, in this case we speak of the sleev NILS, to stay in theme colors I preferred to take the black, bottle green and finally green light, I think it will come a great job now we just have to wait for the arrival of the power supply ........ who will?
    This is a small sample of vanilla-colored ...... I would say not bad
  5. Corsaronero333
    25 Feb 2012
    Returning home after a month, now takes up with small, early stage of assembly, good vision guys
  6. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Gooooood, that's sexy.
  7. Cheapskate
    13 May 2007
    Lovely. I'd be tempted to sneak LEDs into the pillars. I bet that glass lights up well.
  8. RealWeaponX
    RealWeaponX What's a Dremel?
    16 Mar 2012
    :jawdrop:
    *subbed*
    I can't wait to see how this work of art turns out...
  9. Cown
    Cown Minimodder
    25 Feb 2012
    This is absolutly amazing, this is not modding, this is art!
    Did you make the glass look that way yourself or did you buy it and cut it out to fit your creation?
  10. Corsaronero333
    25 Feb 2012
    thank you very much
    Brilliant idea I have 100 green LEDs will be used a test on a pedestal and then we will
    Believe me I am more 'you eheheheheh
    Thanks for the wonderful compliment, the glass is cut and drilled the second of the patterns of wood that I have prepared the first
    New Uppp
  11. peteski
    peteski long live the pc
    8 Jun 2011
    this is one sweet looking mod :rock: :rock: :rock:
  12. Corsaronero333
    25 Feb 2012
    Thank you so much:)
  13. KidMod-Southpaw
    28 Sep 2010
    This is just fantastic, and it keeps getting better.
  14. dirky90
    dirky90 Minimodder
    19 Mar 2012
    very clean so far, i thought it looked good with the wood; and then that glass!!
  15. grejh0t
    grejh0t What's a Dremel?
    4 Apr 2012
    amazing work
  16. deragoku
    deragoku What's a Dremel?
    12 Apr 2012
    I read the other build, elegant summed up quite well, building on their real good FeAl metal.
  17. Corsaronero333
    25 Feb 2012
    Thanks guys for a great evening up :rock:
    In all the banquets that respect there is always a need for air flow at the top, in this case we have created a 2 and a right to the left, both featuring 80mm fan but ...... what has been created is well beyond .....
    The media can raise and tilt freely to suit asks that a
  18. Corsaronero333
    25 Feb 2012
    There's still light and watercooling the entire system and see the beautiful.
    In written corsaronero333 will be applied on the underside with a plexy green LED so you can highlight just the writing.
  19. Corsaronero333
    25 Feb 2012
    Last 4 photos for tonight, let's see what happens tomorrow
  20. Corsaronero333
    25 Feb 2012
