Graphics The GTX 980 Thread
Discussion in 'Hardware' started by Shirty, 31 Oct 2014.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    No I think I will lay on my bed and stroke it for a while.
  2. MeddlE
    MeddlE Norwegian Blue
    23 May 2011
    Make sure you wipe it clean afterwards. :eyebrow:
  3. Shirty
    18 Apr 1982
    And be sure to thoroughly de-gunk the fan...
  4. Kronos
    Kronos Multimodder
    6 Nov 2009
    Now that the card has been inserted in the necessary orifice. What now? Someone mentioned overclocking, is this really needed? If so how is it done bearing in mind I have only ever tampered with a GPU and that almost ended in disaster.
  5. Cei
    Cei pew pew pew
    22 Mar 2008
    I wouldn't bother. Just play games damnit.
  6. Shirty
    18 Apr 1982
    I'm with Cei here, on a U2711 just get playing. Your eyes will smile :)
  7. Kronos
    Kronos Multimodder
    6 Nov 2009
    That's fine with me, cheers guys.
  8. suenstar
    suenstar Collector of Things
    13 Sep 2009
    It certainly stands out in that case, though I quite like the GPU being a bit in your face compared to the rest of the machine.
    Unless you're tying to show off with high benchmarking scores or doing something that specifically requires pushing your components to their limit, there's very little reason for overclocking your card so I'd say just leave it as it is.
    For gaming, you'll likely find that it will perform absolutely fine on the stock settings.
  9. Pookeyhead
    30 Jan 2004
  10. Kronos
    Kronos Multimodder
    6 Nov 2009
    I am tempted to cover the backplate in white 4D Carbon Fibre Vinyl Wrap. What say you?
  11. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    :D what you think we going to say
  12. Kronos
    Kronos Multimodder
    6 Nov 2009
    Don't do it you idiot, could be a suggestion.:D
  13. Parge
    16 Jul 2010
    I would say it won't work.
  14. Kronos
    Kronos Multimodder
    6 Nov 2009
    That is a tad ambiguous. What wouldn't work
  15. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Aesthetic issues aside, the 980 backplate is not flat but fairly deeply grooved and contoured, with an extra chunky bulge where the SLI 'flap' is. You'd need a very thin and flexible vinyl sticker in order to conform to it.
  16. Kronos
    Kronos Multimodder
    6 Nov 2009
    It is actually pretty flat. Just one raised part towards the power connections. Absolutely no 'chunky bulge' where the SLI connections are and certainly no flap in that area.
    I think I will cover it and see if the overall look enhances my colour scheme. Easily removed if not.
  17. The_Crapman
    5 Dec 2011
    Would the heat not cause it peel off? I had a bad experience with some noise absorbing foam recently, which I'd stuck around the outside of the 5.25" bays to dampen the noise of my pumps. The heat from the pumps not only cause it to peel away from the case, but also managed to separate the 2 layers
  18. Kronos
    Kronos Multimodder
    6 Nov 2009
    I had the stuff covering my 2 GTX 670's with no peeling issue's at all so I don't think that this be a problem.
    I think I will do it now, will post back with an image if I am happy with the result.
  19. Shirty
    18 Apr 1982
    Have you played any games on it yet? Otherwise it's going to be a very expensive case decoration!
  20. Kronos
    Kronos Multimodder
    6 Nov 2009
    OK tried the white 4D Carbon Fibre Vinyl Wrap and it did not look good at all so that idea is a no no.
    As for gaming, not really as I have not got anything that takes my fancy at the moment. I bought A story about my Uncle but that will hardly test a 980. I am struggling through Alien Isolation but am struggling to get into it. I still have a second playthrough of COD: AW but I found the first so boring I am not rushing back to relive that any time soon.
    Could play FC 4 for a third time I suppose. Or have a look though my quite extensive Steam catalogue for something to play.
