Case Mod - In Progress "The NOTalis Project" by E.E.L. Ambiense & Mnpctech...."Snow storm halts install!"
Discussion in 'Project Logs' started by mnpctech, 7 Oct 2009.
  1. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Haha, that would be epic cooling overkill. :rock: I'll have to ponder on this for a bit...
  2. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    *looks at Bill with a smile* Yeah, Bill...imagine a triple 140 grill with these! I totally didn't think about this right off the bat and have been bugging him constantly about it, ya know... ;)
    Thanks, mate!
    To heck with the rules on what is or is not; just do it! :D
    +1!
    Heh heh heh...
  3. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    We would have to scale them down on a single mounting plate, like we did on the SG05 bezel shown here. Otherwise the single Overkill grills are too big..heh.. Anyways, you know where to fine me when you want one :D
  4. ringo
    ringo What's a Dremel?
    14 Jun 2008
    very cool fan grills
  5. E.E.L. Ambiense
    26 Jul 2007
    Oct. 18th Small Update!
    Heh heh heh. ;)
    Update time! Here's a little morsel to chew on for a bit.
    You know, one of the frustratingly-bonehead things we discovered about this lil' chassis? Silverstone didn't put any bloody case feet on it! What the..?! Why?! It's not that hard. Come on, guys. Vibrational transfer, etc. just seems like a good enough reason to have some, ya know? Or even preventing the chassis from scratching up your desk or something, lol.
    Oh well. We picked up a small package of I believe StarTech-brand cheapy rubber stick-on case feet. They'll do the trick just fine.
    I'm finishing up on the PSU modification as well. Make sure you have your screws handy when doing so. ;)
    Finishing up on the final layer of rust application to the side panel grill. So sexy.
    As well as finishing up on the front panel plate's rusting. So realistic! We were stoked.
    More soon!
  6. mnpctech
    21 Apr 2003
    Was that recovered from the TITANIC?! :D
  7. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Looks absolutely stunning!
  8. jhanlon303
    7 Sep 2006
    Most excellent. I approve a lot.
    There is some stuff called Rustall that the model car builders use too. It would work on the plastic fan?
    http://www.rustall.com/
    Keep going, this is neat.
    john
  9. mnpctech
    21 Apr 2003
    Glad you like it John!
    The sophisticated finishes product works on plastic as well. You sand & prep surface first, apply spray paint primer coat, then use their Metallic surfacer as base coat before applying their Instant Rust solution. You could dismantle a fan and follow the same procedure as E.E.L. illustrates in this video
  10. Reverse
    Reverse Reverse/srvR
    25 Sep 2008
    It really does look like it was.
    Nice job so far!
  11. E.E.L. Ambiense
    26 Jul 2007
    Oct. 19th Update
    Here we are again; another update.
    Let's get to it.
    Last we left off, the front plate was rounding third base. Now, Bill's putting some final touches on the shell's rust application before the side grill installation.
    The hell am I looking at?!
    Next we have Bill working on the chassis itself. You can see the finished PSU installed already.
    The cool thing about this stuff is you can continue to layer different applications as much as you want. Yes, there will be some buildup with it, but it looks so cool.
    Bill was keeping in with the look of authenticity by installing the PCI slot covers and then hitting those screws with the rust application. This looks the most realistic, unfortunately it may be difficult to install any PCI expansion peripherals! :hehe:
    Bill's installing the side grill onto the shell itself, along with the mesh.
    I weathered up the scrap mesh with some holes here and there that are strategically placed so you see them inside the counters on the acrylic grill itself to give it a more detailed layered look. It worked pretty well!
    Don't worry; it'll look a lot better than this mustardy look really soon... It's coming!
    Moar coming!!!1
  12. stonedsurd
    11 Mar 2009
    Oh maaaaan, that's seriously epic :clap:
  13. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    indeed... epic.
    moar!
  14. mnpctech
    21 Apr 2003
    I didn't even notice when you took these pics. Excellent :D
  15. E.E.L. Ambiense
    26 Jul 2007
    Heh heh, ninja-pics!
  16. Cheapskate
    13 May 2007
    Where's the reactor go?:D
  17. perplekks45
    9 May 2004
    You guys are sick!
    Admittedly, not as sick as Cheaps [and he's the only one to blame for that] (haven't blamed you in a while, Cheaps... sorry 'bout that :p) but sick.
  18. mnpctech
    21 Apr 2003
    I'm sure E.E.L. and I can find a way to blame cheaps for this one :D
  19. E.E.L. Ambiense
    26 Jul 2007
    Oct. 20th Update
    Alright, keeping the momentum going, here's another update!
    Bill and I continue to assemble the chassis and get things to come together like a good little case should. :)
    Bill's finishing up on final assembly of the chassis insides.
    If you scroll down with these pics really fast, it's alsmost like a movie! :hehe:
    ...aaaaand done.
    Here's some closeup shots of the shell/side grill assembly so far to show some cool detail.
    More will be coming soon!
  20. St3ph
    St3ph What's a Dremel?
    8 Aug 2009
    Woahh... that's modding at its best o_O
    even real rust isn't as rusty :D
