Scratch Build – In Progress The POWER CELL - ZenModz "COMPLETED"
Discussion in 'Project Logs' started by Zenator, 11 Oct 2015.
  1. Zenator
    Zenator Minimodder
    12 May 2015
    Hello again.
    Mid week update, My first ever I think.
    I have been working on the GPU, making a way for the heat to be removed to the outside of the case. As well as making a way to to trap the heat from entering the inside of the case. and still have a way to connect a monitor to the GPU with out letting the heat in. So what I have done is make a cover that will do both, and then I will make one more to cover the monitor cable plug to hide it as well.
    I will also be making a cover to hide the PCI-e cable on the GPU.
    So this is what will be going on behind the GPU to get the Hot air out. this will also stop the PCI-e cable from getting in the way as well. that will run from the top down into the bottom of the case and back up to the MoBo.
    Then the pillar face cover will go back over the top. so non of it will be seen.
    Also in the last photo. you can see just a small notch in the center that's where the hdmi will run into the bottom of the case and out the back near the IO port. did not think to say anything about it. as It was the quickest thing to fit. :p
    Thanks for stopping by. :)
  2. Cheapskate
    13 May 2007
    Little bumps and stuff just add to the level of detail.:thumb:
  3. Zenator
    Zenator Minimodder
    12 May 2015
    That they do. :wallbash::thumb:
  4. Zenator
    Zenator Minimodder
    12 May 2015
    Hello again.
    Today I painted the Cover for the GPU that I made. Now it looks like it belongs to the GPU cover.
    All the gaps have been filled, then primed in a single pack.
    I then painted it in a white acrylic single pack then sanded with 600 wet&dry paper.
    I then added the red line. And then painted it in a 2 pack clear coat.
    This photo is out of focus but not on the fan and light above. Nice and flat and Shiny.
  5. Zenator
    Zenator Minimodder
    12 May 2015
    Hello again,
    Over the last day or so I have been putting the outside loop and blocks together,
    I glued then from the inside & out.
    And there are no leeks from any of the tubing, Happy days.:thumb:
    Leek testing, and this one had one. I filled then all up with water. added a plug to one end, added some air pressure to the other end to make sure they will work.
    I modded the SSD as well I know its been done before but it still looks cool. and I have never tried it before so I just had to give it a go,
    The PCB had to be flipped over for the ram to be seen. and I put some 1mm clear behind the window.
    Thanks again for stopping by.:D
  6. eucalyptus
    eucalyptus I am 19 and Swedish!
    29 Sep 2015
    Wow, now we're talking! Those pipes looks amazing, can't wait to see more!!!! :D :D :D
    I am a big fan of water cooling, and the bigger loops the better! Addicted to this project, you have to give me more pictures!!!
  7. Nexxo
    23 Oct 2001
  8. Impeccable Logic
    Impeccable Logic What's a Dremel?
    9 Mar 2015
    Great stuff. Looking forward to see it all completed.
  9. Zenator
    Zenator Minimodder
    12 May 2015
    Thanks eucalyptus, :D More pic's again soon.
  10. Zenator
    Zenator Minimodder
    12 May 2015
    Thanks Nexxo I love it! :thumb:
  11. Zenator
    Zenator Minimodder
    12 May 2015
    Thank you Impeccable, :D As am I. :thumb:
  12. Zenator
    Zenator Minimodder
    12 May 2015
    Hello Again, The painting process is underway.
  13. Cheapskate
    13 May 2007
    A little gray changes the look dramatically, and I vote warp core. :lol: The aliens will be mad when they find you have been sharing their tech online.
  14. uerseya
    uerseya Covered in rock wool
    25 Aug 2008
    Imagine plugging that into a lady toy:eeek::jawdrop::D
  15. thechoozen
    thechoozen Minimodder
    9 May 2006
    it really looks great already!
  16. abbas-it
    abbas-it We came, we saw, we mod, you awe!
    1 Jun 2011
    insane, love it
  17. HerrOtto
    HerrOtto What's a Dremel?
    17 Apr 2013
    Very, very nice!! Keep it up. Can't wait until it's done.
  18. Zenator
    Zenator Minimodder
    12 May 2015
    Thanks everyone, Adding more details to the inside of the case now will post again soon. :)
  19. eucalyptus
    29 Sep 2015
    Damn it! I hoped for white with green details :D
    Everything white, but with green watercooling, water, fittings and so on.
    And the 970 Turbo GPU, which has red details could be green instead of red's ;)
    It looks good man! Really like how you do something special with the water cooling :D :thumb:
  20. Zenator
    Zenator Minimodder
    12 May 2015
    Thanks, :D There is only room for one all white & green PC and that's your Mod. :p
