Hardware The Secrets of PC Memory: Part 4
Discussion in 'Article Discussion' started by Tim S, 10 Feb 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Freedom
    Freedom Minimodder
    27 Oct 2004
    Nice article but could you please not call voltage power. Power = current * voltage. So while the voltage may be lower the current they draw is just as important.
  3. noobarino
    noobarino What's a Dremel?
    3 Aug 2007
    i agree
  4. wyx087
    15 Aug 2007
    hey, where did that timeline table on page one go? i was going to look at it more closely later.
    edit: hum..... it's still not displaying for me:(
  5. Guest-16
    Guest-16 Guest
    Uh, it's still there!? :eeek:
    Also, if the voltage drops and the current stays the same, surely the power will drop? :) If you (ever) find anything technically inaccurate - feel free to email/PM me :):)
  6. ryanjleng
    ryanjleng ...
    15 Nov 2007
  7. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    the voltage drop reduces power consumption because all transistors and mosfets have an input capacitance and therfore as they are made up of such devices all IC's have input capacitance. If smaller signaling voltages are used this input capacitance has to store and discharge less total energy per voltage transision. This is also why reducing the switching activity (reducing frequancy) reduces power consumption. this is more pronounced when IC's are constrcted using CMOS tech wherby the non switching power consumption is negligable per gate (unless built on a very small proccess wherby quantum tunneling causes problems) (which is why intell gets all excited over new insulators).
    basicly lower signaling voltages = lower power consumption almost all the time.
  8. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    Very well written, Good job!
  9. LVMike
    LVMike What's a Dremel?
    11 Aug 2004
    I learned a lot about ddr3 i didn't know from this article. I enjoyed it very much, good job.
  10. ChiperSoft
    ChiperSoft What's a Dremel?
    27 Aug 2006
    Yeah, this finally explained to me why DDR3 is actually worth using. The simple fact that it can move a whole byte for each clock cycle is pretty awesome.
Tags: Add Tags
