Cooling Theres a hole in my bucket!
Discussion in 'Hardware' started by iggy, 4 Aug 2007.
  1. iggy
    iggy Minimodder
    24 Jun 2002
    everywhere
    dear liza, dear liza
    just installed my new system, and ive been running it for a wee while leak testing and there seems to be a very small leak somewhere amongst the rad fins near the barb end of it.
    does anyone have any advice on how to fix it? unfortunately i think i have somewhat voided the warranty by adding a fillport to the other chamber :/
    wish id leak tested before i made that :/
  2. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Telford
    No chance of a better pic? Could be repairable
  3. severedhead
    severedhead What's a Dremel?
    19 Dec 2002
    Nottingham
    If you can find the leak and reach it you could repair it. I punctured my rad with a self-tapper which was a bit too long a few years back, but managed to fix it with a soldering iron in about 5 mins.
  4. Cyprio
    Cyprio G5 Supermodder
    2 May 2006
    London, UK
    Better pic? It looks like you have installed a HE/PA Thermochill directly into a case???! :)
  5. nazomcg
    nazomcg Minimodder
    4 Aug 2006
    Birmingham, England
    I don't know whether this would work in pc water-cooling, but where I work (a garage) we fix car radiators with a special liquid that seals small holes. Just a thought if you can't think of a better method.
  6. iggy
    iggy Minimodder
    24 Jun 2002
    everywhere
    any idea what the special liquid is called? i know theres rad weld, but there are supposed to be better solutions than that.
    cant get a better pic atm, because as severed head said, its in the case. the puncture itself must be tiny, as im losing only a few millilitres every couple of hours, and none at all when the pumps off.
  7. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    Canada
    try weld-bond
  8. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Wisconsin
    duct tape, that fixes everything
  9. Krikkit
    21 Jan 2003
    Lincs, UK
    Try a soldering iron - I had a hole in one of my rads (2nd hand) from some adventurous self-tapping screwage, that lost quite a bit of water tbh.
    If you can't see the leak, try weld-bond as BBQ said. :)
  10. Hack'n'Slash
    Hack'n'Slash Minimodder
    20 Dec 2001
    Manchester
    Sodium silicate, in some form or another?
  11. nazomcg
    nazomcg Minimodder
    4 Aug 2006
    Birmingham, England
    I'm not altogether sure, but its a thick brown-red colour and smells awful.. if that helps :duh: sorry I can't be more help
  12. Hack'n'Slash
    20 Dec 2001
    Manchester
    Sounds like Radweld.
  13. timmythemonkey
    timmythemonkey Monkeymodder
    27 Apr 2006
    UK
    I hope you never go into medicine!
