I recently got given a TJ07 case and after looking it over... How do people get the quad fans in the bottom of the case to work? Custom mounts? Is there parts you can buy to do it? *confused*
You can purchase third party radiator stands which you then mount the fans on Some double sided tape will secure them in place so there is no case drilling involved
I use velcro on mine. Don't use too much of either velcro or double sided tape as it sticks it too much and is a sod to remove whatever you've fixed down.
