I just got done with my newest mod last January, TRITON. I thought I should put up my work log on it here. Let me know what you guys think. I will be starting a new mod in the next couple weeks. It will be a Mini-ITX build in CaseLabs new mercury s3. For my build this winter I'm going to be using CaseLabs new Merlin SM8 case, EVGAs Z77 Cheesecake board, 2 EVGAs GTX 680 Classified Hydros, and an Intel 3770k. I am still working on the rest of the components. I will be building a custom 5 bay reservoir, feet, and a few other parts. Thank you CaseLabs for another high quality case. Thank you EVGA for your continued devotion to the enthusiast community. Thank You Roccat for your outstanding products.
These are my final pictures of Triton. It is featured on the front page of CPU Magazine. Thank you everyone for your feedback, ideas, and support.
The CaseLabs Merlin SM8 case is smaller than my last build (EpiDemic). It is a single wide case with a variety of options. The first thing I will be working on is the 5 bay reservoir. this is my first attempt to see how the water will flow after getting it all glued together, and building an icycle design into it. I sanded down the outside to create a frost look to it. I still need to use a larger grit sand paper. I put together a quick gasket to see how every thing works. I also made a video. I still have a few other things to do to, but let me know what you think so far. I put togeather a video of the water flow for you guys to see. http://youtu.be/kXk-nz6FInw
I've been looking for fans that would go with my build. I picked up an Xigmatek xaf-f1256. It has white leds. not sure if I like the white leds or not. Great fan though. Very quiet and great air flow. Would be nice to have some blue leds in it though. I've been putting in some leds on top of the resevoir to illuminate the reservoir. This picture only has one for now, but when i'm done it will light it up really well. I will probably put it on a dimmer. I have a couple small tweaks to do on it, but minor ones.
I started working on the feet today. I still have some polishing to do. I also ordered some MDPC sleeving. Freshly cut After a little sanding And some more sanding
Happy Holidays everyone. I've been ordering parts and working on the feet. I received my sleeving from MDPC. I picked up some Carbon fiber vinyl, and the rest of my fans. I was playing around with the carbon fiber vinyl a little of a 240 rad my buddy DA gave me. I ordered some other vinyl to do the rad in my build with. I am also fabbing up a mount for my pump. Here is an early picture of one of the feet i wrapped, drilled and tapped. I will be mounting a blue led inside once finished.
So I picked up a d5 pump and a 480 rad today. Took a picture and quick video for you guys. There is no resistance an I need to turn the pump down a little, so the water is just flying through there. should have less bubbles once turned down. http://youtu.be/ZNEfJT2YI10
As promised, here are some pictures of what I have been up to the last couple weeks. First here are some pictures of what I got in the mail. I talked to the guys at Roccat this week about a mouse. These guys are great. They are sending me there Kone XTD mouse, and there Isku FX keyboard. Thanks Roccat. Blue connectors in as well as my ax1200 connector kit. The rest of my Fittings, Orings, and Tamper proof buttons. Picked up this 480 gtx rad from Clamdip on the PDXLan Forums. I got my Dominator Platinum, and force GT 240 gb ssd in today. I started out by wrapping the gtx 480 rad with some brushed blue steel vinyl. I wrapped the koolance block with vinyl and cut out the dark grey metal. The 2 gtx 680 classies were pretty time consuming to wrap. I continued on my vinyl wrapping spree by rapping my AX1200, followed by my drives. I have about 90% of my wiring complete at this point. I finished the 24 pin, the 4 pci 8 pins, and the 2 mobo 8 pins. I still have a couple more to do. I also built, wired and sleeved the feet light and I also lite up the acrylic peace behind the pump. Here is the support and mount for the pump that I built. I did some decals and painting a little yestarday. Ok, lastly. I need your opinion. Should I wrap the top of the Dominator memory and put green lettering on top that says dominator. OR, should I leave it chrome. It looks so nice the way it comes.
The gtx 680 classified hydros come with the red led, that light up the frosted acrylic block in the water bridge. The Led are soldered onto the board, so i covered them up and drilled a hole in the bottom of the water bridge. I made a new acrylic block with a channel board out on the bottom. I ran up some wire through the channel to some blue leds on either side of the acrylic. Looks realy cool. I need to put my dimmer on for my UV lights. they are up way to high. I then wrapped the cover to the block. So, I needed to see what the ram would look like with the lettering on it to make up my mind.
I was sick all last week. I did manage to get a few things done though. I sleeved the sata power cables, sleeved the sata cables, sleeved the 6 pin power cable for the pci slots, wrapped all the dominator memory (Thanks for everyones input), built a mesh guard for the wires that sit over the top of a fan. Organized some wires, and have been trying to come up with a name for my build. I also received a Roccat Kone xtd mouse, and Isku keyboard. I spent the night playing around with the mouse. Is all I have to say is, WOW, what a great mouse. Besides just the basics of a mouse, comfort, smoothness. It looks amazing. I love the way I can customize the colors on the sides. All I have left to do is build a power cable for my pump lighting and fans (I'm just waiting on the sleeving to come in.), install the wire guard above the fan by the pump, and get some decal work done on the outside.
I will be starting a new build within the next 2 weeks. It will be a Mini-ITX build in CaseLabs new Mercury S3 case.
Great attention to detail. Really impressed with how well the vinyl wrapping came out too. Expecially on the graphics cards.
Thanks for the great feedback. I was really happy the way the color scheme came out. All the green highlights just made everything pop.
