Case Mod - In Progress UNIT: 4 - DONE! on 22.04.08
Discussion in 'Project Logs' started by FrooP, 24 Oct 2007.
  1. FrooP
    FrooP can I eat this?
    24 Oct 2007
    some more work on the PSU tower :dead:
    "some" bondo
    while the bondo was drying i drawed an PSU backplate
    puzzle in a different way
    makro
    ...bondo & sanding...
    some of those parts you dont wanna show.. but i needed to because it is just worse.. some fixing is needed here
    as you can see, stil far from being done :/
  2. Cheapskate
    13 May 2007
    That's the problem with filler building. -It takes forever to dry.
    I can't wait to see how this comes out...but I kinda' have to.
  3. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    using bondo, or what us brits call P40 you have to apply in thin sections, as a big lump takes ages to dry and can warp then crack. if you are using it right it should be dry within 10 minutes and ready to sand or for the next layer if your building up.
    i tend to perfer to apply a layer of bondo then sand with 80 grit, to find any little air bubbles, brush it off with compressed air then apply the next layer of bondo, saves so much time finding the air bubbles as you go, rather than finding them in the end!
  4. FrooP
    24 Oct 2007
    sunday :dead:
    this
    a) sucks b) need some time to look like i want :dead:
    yesterday.elektronics arrived, im to sick to solder so i cleaned up the soldertable :dead:
    before
    and after
    toolZ
    wires
    stuff
    this is the electronic madness which will be inside unit 4
    a video
    :D
  5. eXplode
    eXplode sound freak
    1 Dec 2007
    Omg. What dedication... :jawdrop::jawdrop: how many hours u used til now?
  6. Cheapskate
    13 May 2007
    :hehe:
    I used to be able to do a pretty good 'Cousin It' impersonation too!
    That's a lot of new molex plugs. I'm used to just ripping them off from older systems.
  7. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    did you make that video your self?
  8. FrooP
    24 Oct 2007
    yeah i did it all by myself, i used adobe after effects and sony vegas
    PCB WORK
    yeah i make my on circuits and etch em. with a laser printer and a iron
    after ironing the printed circuit on the pcb i need to remove the paper
    this is what it looks like then
    the mega led fader (100+)
    actually its tribaloverkills fault that i made this :D
    cutted
    goddam small $#!t
    after ironing and removing.. SICK!!!!
    etching fluid
    while etching
    afet 15 minutes i recognized that the pcbs where still the same, so i took my um.. dryer which makes air pretty D*#n hot :O s the fluid has a higher temp and its moved so it etches WAY faster
    i must say.. this method PWNS!!!!!1111oneoneone the pcb was done after 7 minutes
    and always think of THIS COULD BE YOUR SKIN! so wear ALWAYS GLOVES! its.. acidly
    and bÄm
    then i need some holes
    :D :D :D
    yeah.. here you can see how big this thing is :O
  9. FrooP
    24 Oct 2007
    so the pump control is done :)
    it does work.. at least i _think_ it does.. the relai works and thats all what it has to do
  10. dan-ere-07
    dan-ere-07 What's a Dremel?
    29 Mar 2007
    is the led fader your using like the one designed for the xbox 360?
    where the leds fade on then fade off and carry n like that in a continues cycle
  11. widmod
    widmod Minimodder
    9 Oct 2006
    When you look closely on the circuit you can see that he got the layout from http://www.meisterkuehler.de/
    which means master cooler in english but the whole site is in german....:D
  12. FrooP
    24 Oct 2007
    @ dan
    no its a custom designed by another forum member.. its able to fader about 100 LEDS well..should be.. it doesnt work.. :(
    update time!!!!1111oneoneoneeleven
    another hole
    which is wayyy better than the old one :rolleyes:
    now i need to close that opening
    taped
    and again, fibreglass :rolleyes: :D
    miled the led holes
    epic makro failure
    cablechannel
    aim
    and bOOm pushbuttons insertet
    dis is how it looks like from teh inside
    the fibreglass is also dry
    and smoooooooooth
    got wires?
  13. dan-ere-07
    29 Mar 2007
    oh dear thats not good
    do you think this would work?
    and put all the led's in parerlell with the single led
  14. FrooP
    24 Oct 2007
    ugh.. sorry but i think this wont work.. the leds need to much ampere for this small transistor.. this is the circuit i used
    :rock::rock:
  15. FrooP
    24 Oct 2007
    GIMME A HELL YEAH!!!!
    my christmas gift :)
  16. FrooP
    24 Oct 2007
    another update
    this groove is for a wire, so i can hock those steel support wires in, just like in the real build
    mounted the cd cover(which needs some new tiles
    and the old hdd cage is mounted (need some kitbash)
    quick inside overview
    and the pushbutton terminal is mounted also
    time to mill
    action shot :O
    and the finished part
    this should be some kind of mega fuse construction, one of em is broken
    led wire channel was milled
    this is how it should look like, except the cap of the real fuse wont be visible in the finished part
    _some_ wires
    ..and a happy new year
  17. Cheapskate
    13 May 2007
    EEEEK!
    Hand feeding stuff into a routher bit!?!?
    Please use a back stop guide and a push stick!!! I've seen what happens to WOOD when you slip. I pray you keep your hands clear from the bits.
    I like what you've done. are you putting a molten red core under the reactor?
  18. Jipa
    5 Feb 2004
    Might be wise to keep hands away from the bit, but the foam is so soft I just can't see it backfiring too badly.
  19. FrooP
    24 Oct 2007
    whoa update time Oo this is the awfull picture of my workshop
    expand the pc
    this is a quick dual external harddrive "mod"
    sanded
    polish stuff
    and polished(beta ;))
    this is what it roughly looks like, the old cd drive will house the circuit stuff and maybe something more^^
    some kitbashing is needed and some (or alot) paint (will be flat black)
    anyways real update, 2 cutting disks
    cutted a channel
    in there will run the wires for the led, and some space for the resistors oO
    :D
  20. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    neat use of cutting disks.
