Scratch Build – In Progress Wargames WOPR desk computer
Discussion in 'Project Logs' started by HCP, 5 Nov 2012.
  1. David
    7 Apr 2009
    Very cool - looking foward to this one!
    Subbed.
  2. Gimlehr
    Gimlehr What's a Dremel?
    13 Dec 2012
    Oh the memories! looking forward to seeing the finished product. Subbed!
  3. HCP
    HCP Minimodder
    19 May 2012
    Trying the leds in the panels before paint.
    Noticed the yellow needs to be changed to amber, too much yellow
    BTW, its 3mm led´s :)
  4. HCP
    HCP Minimodder
    19 May 2012
    Made some more panels for the USB headers.
    The USB headers goes here, behind the "tower" at the red arrow.
    And a colourtest to see how it looks :)
    Soon gettin´ there, much time goes to the LED´s and not so much for the case right now.
  5. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    Looks clean
  6. loftie
    loftie Multimodder
    14 Feb 2009
    Don't get any ideas of taking over the world, otherwise we're going to have to go tic tac toe on your ass :D
  7. Big_malc
    Big_malc Minimodder
    7 Sep 2010
  8. HCP
    HCP Minimodder
    19 May 2012
    Hammertime!
    *Smack*
    Got tired of the roof, the plastic i used was to soft that i sagged when sanded and after 10 runs with putty/filler i still didnt have a flat roof.
    And all wet sanding made the wood increase in thickness, had it in the oven for a couple of hours now to dry it up.
    Going to replace the roof with 4mm acrylic, and i hope i can get done with the casing now, all other parts just laying around and wait
  9. HCP
    HCP Minimodder
    19 May 2012
    Current state of the case.
    Testing the led-panel, i wish i made the cutout bigger... See if i make that change later or if i just go with it.
    Nevermind the edges, its not done yet ;)
    Almost time for some Tic Tac Toe
  10. matiss
    matiss Minimodder
    24 Jun 2010
    Hello Joshua :D
    You can never go wrong with some wargames. As a big fan of the movie i have to watch that stunning beauty come to life.
  11. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    R.I.P.L.E.Y. died J.O.S.H.U.A. lives :)
  12. HCP
    HCP Minimodder
    19 May 2012
    Hehe, i didnt watch the second movie until i begun with this project. Its crazy that they missed sooo much details on the WOPR, insanely bad WOPR in the movie with Ripley.
  13. HCP
    HCP Minimodder
    19 May 2012
    I have stopped using my white plastic and moved to acrylic, more rigid and not flopping around when sanded. The styrene is to saggy to use in a case this big.
    Its gettin´ taller!
    I have three fans in the case, on on either side of it, on pulling and the other pushing, one side have double setup (where the rad is).
    Both fans are hidden behind a panel and push/pull air trough a duct in front of it. I have made some tests with cardboard just to see the flow and cooling capacity and its plenty good for my purposes. Tested with 100% cpuload in 4hrs and a H60 cooler.
    I didnt want any visible fans, im all focused on making it really really look like a smaller version of the real WOPR :)
    The small tabs behind the rounded corner on the acrylic is temporary there when gluing, to get nice straight corners. otherwise they will hit the motherboard :)
    First pic, case rising to the skies.
    This is the back side with IO-plate cutout. You also see the fan hole that later is hidden.
    Pic two
    Here is the cover over the fan on the left side of the case.
    Other side have the same type of panel.
    Here is how the real WOPR looks like at almost the same angle :)
  14. Pranja
    Pranja Blackwolf
    18 Dec 2011
    This looks awesome. ;)
    I like that movie-this is great way to remember it.
  15. Muerlin
    Muerlin What's a Dremel?
    10 Dec 2009
    You've been busted for using VLC! :thumb:
  16. Alekoy
    Alekoy Ostekake!
    28 Dec 2003
    AWESOME!
    Planning on putting a big lens with a red light behind it on my server rack, HAL-style :)
  17. HCP
    HCP Minimodder
    19 May 2012
    Time to start making the light controllers.
    This is just a test for one of nine controllers for the LED panels.
    White and blue to the left is output and its triggered on/off by the red with a knot on.
    Soldering iron heating up...
  18. HCP
    HCP Minimodder
    19 May 2012
    Current status, its bondo time.
    Tonight i tried to get the shape of the "tower" 100% but whatever i did, it didnt look right.
    Until i cut a inch from the length, then the tower fit and all proportions is 90% spot on.
    I have some strange thing with the tower, it looks too wide, but really isnt too wide.
    So now i have cut the length, made a new tower piece and bondo it all over.
    Alot of sanding to do before i put on some primer to check all small spots to fix.
    Right now it looks like crap, but you guys who seen the WOPR probably can visualize it :)
    While the bondo dries, its time to make the left panels ready. I want it standing by itself today!
  19. HCP
    HCP Minimodder
    19 May 2012
    Been working on this the latest weeks and finalizing most of the parts.
    Also had to strip all base paint due to flaking, that took some time :p
    Next step is a layer of base paint that can be sanded to fill the pores and scratches, and glue all stuff together.
    The WOPR is alive, and its time to get it together, right now :)
    Teelzebub likes this.
  20. David
    7 Apr 2009
    :cooldude:
    I'd almost forgotten about this one - can't wait to see the final result. :)
