What do you want reviewed?
Discussion in 'Feedback & Suggestions' started by james888, 13 Mar 2011.
  1. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    CM Silencio 550 review would be nice. Just got on sale in around here and seems like a good competition to the Fractal design case
  2. Krikkit
    21 Jan 2003
    The whole point of the rep system is that anyone is free to give rep as and when they feel it necessary. To review every post and decide if it can be repped would be the only way to cut out your gripe - old, useful threads would be excluded from rep otherwise.
    [edit] That sounded a bit strongly worded, it wasn't really supposed to be having a dig. :p
  3. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    This hit our lab late last week. Currently the plan is to get it into the next issue (96) of the mag and on the site either just before or just after, depending on the site schedule, so stay tuned.
  4. antiHero
    19 Jan 2005
    Sweet, thx
  5. Pete J
    Pete J Employed scum
    28 Sep 2009
    I have a request for a review, but it could be time consuming.
    Working as an engineer and being a computer enthusiast, I'm sometimes asked to build PCs that can do CAD and/or simulation work. Mainly this is to be done as cheap as possible and hence I end up using a Geforce card (AMD drivers SUCK in Linux) but a couple of systems I've been involved in have had larger budgets. In these cases, I've confessed that on the GPU side of things I don't know what would be better for a system, an expensive Geforce or equivalently priced Quadro. One system ended up getting a £1000 Quadro just to be safe since the fellow running it was reconstructing MRI scans.
    Anyway, what I'd like to see is a comparison for Geforce and Quadro card running various CAD programmes, particualarly paying attention to equavalently priced versions. Things like:
    Anti-aliasing and image quality
    Frames per second
    Stabilty (my GPUs can end up needing a restart after a day's work using CAD)
    Comparison of OpenGL vs standard rendering
    Memory usage of cards
    And any other things you can think of.
    Cheers for reading!
  6. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    That's a good suggestion Pete J, and something I've been thinking about the last few months.
    The principle problem is finding realistic benchmarks for professional cards, as getting hold of the apps and even more importantly proper 3D models/simulations is nigh on impossible as they are very valulable IP to the creators.
    What apps/tasks do you, or your customers run?
  7. Pete J
    28 Sep 2009
    I can understand that getting your hands on software to test can be expensive/hard!
    Personally, I use SolidWorks and know for a fact that a quadro card doesn't produce visual glitches that are seen time to time on Geforce cards. From an endpoint view it doesn't matter but it's a little distraction that can add up over time. My other colleagues use Abaqus, which seems to run okay regardless but hates AMD cards under Linux (it's a cross-OS programme).
    As for the MRI scanning software my colleague uses, it's proprietary! However, the micro-CT scanner we have has some software which can be used for a one month trial period, the name of which I've written down somewhere. However, you'd need data (TGA files) to construct a 3D model and typical model files consist of around 7GB of 2MB files.
  8. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  9. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Thanks for the link Fingers66. Unfortunately, from what I can see the benchmark that's being talked about there is synthetic, not a real app, something we try to steer clear of on bit.
    As, while x many more transfers per second or MB/sec may be a good thing, what really matters is how much faster do the apps that you run complete tasks.
    Still, right now it's better than what we have, which doesn't ammount to much more than 3D renders (which are more CPU than GPU limited).
  10. Fingers66
    30 Apr 2010
  11. RedFlames
    23 Apr 2009
    I know it's hardly ideal but would the openGL portion of Cinebench do the job?
  12. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Indeed, still I've got a few of them lying around the office for purposes like this. If anybody has any workloads/models they'd like to share for benchmarking purposes, I'll take another look at our editorial calendar and see if I can schedule some time to experiment with them.
    Cinebench uses the same codebase as Cinema4D, which is used in a lot of films/games so it's actually a pretty good benchmark. I'd like some more tests though too.
  13. RedFlames
    23 Apr 2009
    I'd happily make some models for you to use but alas my own pc is borked, plus i'd need to know what versions of what software you had.
    There was a site, whose name annoyingly eludes me that had scenes available to download for benchmark purposes [though i think that was for render times rather than viewport performance].
    And i know Cinebench is based on 4D, that why i suggested it. I know you also use it for cpu benchmarking. 'Hardly ideal' was more referring to it only being one test.
  14. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Great, hopefully that's something we can explore in the future :thumb:
    That's another issue we need to fix too; as its very easy to measure render times, but in most apps that's CPU limited not GPU limited, so is great for Xeon and Opteron reviews, but not much cop for Quadro and FireGL reviews.
    Still, as a race we thive on challenges! :D
  15. Fingers66
    30 Apr 2010
  16. holzj17
    holzj17 What's a Dremel?
    22 Sep 2010
    ^this, plus the H80
    maybe do a labs test for closed loop water coolers to see which is best as an out of the box unit
  17. zabinko
    zabinko What's a Dremel?
    24 Oct 2009
    Agree, I also want to see the Mugen reviewed. It's one of the top coolers on many other review sites, and is about half the price of the Frio.
  18. mikemorton
    mikemorton Minimodder
    5 Nov 2010
    Mine is short and sweet.
    Razer Hydra please.
  19. RedFlames
    23 Apr 2009
  20. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    i would love a watercooling masterclass the mag has been dry about this subject...?
