Graphics Which 670 would you get?
Discussion in 'Hardware' started by j4mi3, 12 May 2012.
  1. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    not bad for the money =] I'd still go with a 7970 overclocked for 50 bucks more.. the 680 is way overpriced as usual!
  2. teppic
    teppic What's a Dremel?
    18 Jul 2011
    I'm stuck between an Asus 7970 top (factory oc to 1GHz) or an Asus 670. Both DirectCu, though the 670 is smaller. Not much between them at current prices (£370ish for the nvidia, £400ish for the AMD).
  3. docodine
    docodine killed a guy once
    10 Feb 2007
    I say, bring back white motherboards! Sapphire did it, not sure why no one else did.
    Apparently clear PCBs are even possible to manufacture, even though all you'd be seeing is copper I guess. Would still be an improvement over brown.
    This discussion made me think of this legendary thread :lol: It's a shame that the good pictures don't work anymore
  4. Guest-23315
    Guest-23315 Guest
  5. The_Crapman
    5 Dec 2011
    Oh dear god! i've got a striker II and one of the best things about this board is all the voltage LEDs on it. That is an absolute travesty!
  6. docodine
    10 Feb 2007
  7. docodine
    10 Feb 2007
  8. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Me to! Reference GTX 680 with the complete Phases surrounding a GTX 670 GPU is too good to pass up.
    If I'm impressed by it then I'll try and hold out on SLI until the prices drop off a little... if I can that is! :D
  9. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    I'm supposed to have it by Wednesday! Would it in any way be bottlenecked by a 2500k @ stock when playing at 5120x1200? Because then I would need to overclock my CPU
  10. Blogins
    3 Aug 2010
    A 2500K has some ways to go before it gets bottlenecked!
    Also looks like my Gigabyte GTX 670 Windforce 3X order has fouled up some how. I pre-ordered, stock became available for general sale today yet my order remains unfulfilled. Looks like a little bit of a fail for ebuyer in this case. I forgive them all the same! :thumb:
  11. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    I will only by one when they'll release a short PCB one. Id-est one with a cooler that doesn't increase the card size (to match the length of a miniITX motherboard).
  12. Blogins
    3 Aug 2010
    I'm curious if EK will come up with a dinky GTX 670 water block. The shortened PCB seems to have caught them by surprise. I don't like the fact half the memory is likely to be exposed round the back. A simple backplate is a little cheap and nasty if cooling the card fully is your desire. That said, it'll leave a nice lot of room in your case to accommodate bulky water cooling gear!
  13. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I've been thinking that. It'd be nice if they came up with a tiny-version, simply because it'd be so much lighter and, in theory, cheaper. Simply because there'd be so much less of it.
    Question is; Will it happen?
    Looks like EK are going to have four new blocks out in Early June, after that; we may see 670-short edition blocks.
    Nuts to it. Just Emailed EK, asking if they were ever planning to make the blocks for the short-PCB 670s.
  14. Blogins
    3 Aug 2010
    Well done! If they did I could go the route of water cooling a couple in my Fractal R3, although I'd have to get creative with the placement of radiators if I want to maintain silent running.
  15. Blogins
    3 Aug 2010
  16. .//TuNdRa
    12 Feb 2011
    Oooh. Colour me interested. I'll still see if I can't get a reply off EK anyhow, might give us a timeframe as to when the blocks will be built.
  17. The_Crapman
    5 Dec 2011
  18. .//TuNdRa
    12 Feb 2011
    Look up. "VGA Fullcover: Coming soon"
    Just got a reply off EK:
  19. The_Crapman
    5 Dec 2011
    :duh: Sorry bloggins. Somehow didn't see that bit right at the top that says 'Coming Soon' and that you'd pointed out as much in your post. Not at all obvious....:worried:
  20. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
    Just bit the bullet on an Asus GTX 670 from Novatech for £349.99
    Got £340 for my 2 GTX 570's on Ebay, so almost paid for it!
    Bring it on!
