Memory which RAM I use for M2N-PLUS SLI
Discussion in 'Hardware' started by mfaridi, 5 Jan 2009.
  1. mfaridi
    mfaridi What's a Dremel?
    1 Jan 2009
    I want buy new RAM for my mainboard , it is M2N-PLUS SLI vista edition
    I can find this RAM in here
    which one is better ???
    Kingston
    OCZ
    Corsair
    patriot
    PNY
    kingmax
    TwinMOS
    apacer
    Geil
    but Kingmax and Twinmos and Apacer have good warranty in here , and I am sure they are orginal
    but about other RAMs , I am not sure
  2. Diosjenin
    Diosjenin Thinker, Tweaker, Et Cetera
    14 Jul 2008
    The most universally respected brands of RAM are Corsair, G-Skill, Mushkin, and Crucial. If you need to get something cheaper, going with OCZ or Patriot wouldn't be bad choices either. Just keep in mind that you'll want DDR2-800 for your board, and you'll be fine.
    - Diosjenin -
  3. mfaridi
    1 Jan 2009
    thanks
    Can support this motherboard 4 GB of RAM without problem ?
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
  5. mfaridi
    1 Jan 2009
  6. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    It will be OK, just remember to get 2x2GB sticks, 4x1GB sticks might give some problems.
