X-Box Tournament
Discussion in 'Gaming' started by jamesc7, 1 Mar 2006.
  1. jamesc7
    jamesc7 What's a Dremel?
    5 Feb 2006
    Hello.
    Im a sixth form student currently taking part in a young enterprise scheme. Our latest business idea is to run an xbox tournament at lunch break, playing Halo 2 and Fifa 2006. we have the xbox consoles to play on but getting hold of TV's is a different matter. however we do have alot of computer monitors at our expense. the original plan was to have one TV for the fifa tournament, and 2 for the Halo games so each halo player could have his own screen.
    is there anyway i can make this setup using computer monitors, and if so what adapters do i need to buy?
    any help is much appreciated :D
  2. mushky
    mushky gimme snails
    24 Mar 2003
    The only one I know of is X2VGA but it won't work if your Xbox outputs PAL. there are ways to get a PAL Xbox to output to NTSC but it's naughty. The X2VGA will probably cost more than a 2nd hand TV set anyway. If I was you I would try to get some 2nd hand TVs. You might even be able to get some donated if you're clever.
  3. Atomic
    Atomic Gerwaff
    6 May 2002
  4. mushky
    mushky gimme snails
    24 Mar 2003
    Exactly. You'll need a scart female to female adaptor as well as that.
    You can get a 24" TV on ebay for cheaper. Probably get 2 TVs cheaper if you check the local freeads.
  5. chemo
    chemo True Jungle Brother
    20 Feb 2005
    or if any computers there have tv in?
