Scratch Build – In Progress ZdMods - Project pǝʇɹǝʌuı - Final Pics! (post #273)
Discussion in 'Project Logs' started by Meelobee, 8 Mar 2012.
  1. GamerIDGoesHere
    GamerIDGoesHere www.^.com
    3 May 2012
    Very nice! Looks amazing and very creative. Keep up the good work!
    oh and subbed :thumb::thumb:
    - Dan
  2. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Love the look of the cable pass through:thumb:
  3. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    thanks GamerID :)
    Thanks bluc! :) It's actually not as I intended, the idea was to make the 24 holes in the aluminum sidepanel, but after drilling (freehand, I don't have a drill press) 4 of the 24 holes were misaligned so much I couldn't fix or hide it. So I decided to cut out all the holes to the rectangle it is now. (the small triangle on top was an idea from my GF, the triangle matches the top of the case.)
    Currently I'm making an ATX extension cable, but progress is slow. Hopefully some pics of it tomorrow :)
  4. Meelobee
    5 Nov 2003
    Update!
    After receiving the lasered pannel I showed in the previous update I started making the ATX cable. Long story short, sleeving is not my thing.. and my fingers hate it even more, they're al burned and scarred.. Anyway, I've cut 2 lenghts of wire, 12 for the inner curve and 12 for the outer curve, this way the cables align best. Then I soldered the pins to the wires and sleeved it with Paracord.
    Here's how it looked when I was halfway done:
    And after 3 evenings filled with burns and curses I´ve got this:
    Worth it! :)
    Sponsored by:
  5. MeddlE
    MeddlE Norwegian Blue
    23 May 2011
    Looking good. What is the significance of the one blue sleeve?
  6. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Absolutely lovely. I still believe that this is one of the most stylish builds I've seen - worthy of MDPC...
  7. Meelobee
    5 Nov 2003
    Thanks MeddlE, no significance just for looks :)
    Thanks Tattysnuc, doing my best to keep it looking good :)
  8. bluc
    4 Apr 2012
    Awesome build 5 star for sure!! That cable pass through came out great!!
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    Oh yeah :rock: very nice. :clap:
  10. Paslis
    Paslis Minimodder
    13 Jun 2011
    Nice cable pass through Meloobee. :D
  11. Meelobee
    5 Nov 2003
    Thanks bluc! Very happy with how it turned out :)
    Thanks! :)
    Thanks Pasliis :thumb:
    mini update:
    Been figuring out a way to connect the EATX cables, without running a bundle of cables in front of the mobo, this is what I came up with:
    Testfit (crappy iPhone pic :grr: )
    Now let's hope the bars won't melt :lol: (2mm brass)
    Waynio likes this.
  12. The_Crapman
    5 Dec 2011
    that is fricken sweet!
  13. Waynio
    Waynio Relaxing
    20 Aug 2009
    I'm definitely not sure about this but isn't copper best for the crazy power mod. :D
    Only ever seen this crazy awesome approach done once before by Chiller on a thermaltake level 10 evga sr-2 extreme overclocking mod.
    Flipping awesome power mod though, love it, I believe he insulated it some how also so it wouldn't be as dangerous. :D
    Brave power mod this. :D
  14. Meelobee
    5 Nov 2003
    Thanks Crapman & Waynio :)
    Not sure how this is gonna work out, I haven't tested it yet, But I'm sure it will work just fine. (top row is 12v, bottom row is 0v). And ofcourse the bars will be isolated, the pics show how far I got with it last night. Gonna try and finish it tonight :) And yeah I've only seen it on the videocards in Chillers mod too.
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    Hope it works nice mate, will be a very nice feature of the project, will end up looking amazingly clean. :dremel::hip:
  16. Meelobee
    5 Nov 2003
    Allright, took a little longer as expected (life got in the way, lol) but here's another update:
    Update!
    Filled the gaps between the pins on the eatx connector with metalputty and filed it down:
    Bend the other ends of the brass bars into shape:
    Fits like a glove :)
    There will be some spacers in between the 2 bars, and the bars will be isolated from eachother by either heatshrinks or plastidip.
  17. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Nice, MOAR pictures.
  18. Shurika
    Shurika Minimodder
    9 Mar 2012
    The idea of hard wires isn`t new, but you did it absolutely perfect! btw, don`t you think about hard cooper wires in isolation? What the main reason you used wires without isolation?
  19. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Put some heatshrink or rubberpaint on those rails :)
  20. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Good idea, but i would have just made it come out the top with an insert like the 24 pin.
