Modding EPIA Alloy mod
Discussion in 'Article Discussion' started by The_Pope, 16 May 2006.
  1. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
  2. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Awesome mod! :) Great stuff
  3. DriftCarl
    DriftCarl Minimodder
    2 Nov 2004
    Although I am mad about cars, that mod really isnt my thing. I have no doubt that it is an amazing mod and very original. But it isnt "spectacular" like some of the other case mods I see around.
  4. speedfreek
    speedfreek What's a Dremel?
    9 Nov 2005
    Nice work there, I would be a little too worried to go messing around with some alloys like that but you had sponsorship to help you out. You did good. :thumb:
  5. Dragon
    Dragon What's a Dremel?
    20 Jul 2001
    Nice mod, I also really respect the fact that he made a point of actually pointing out the errors like wonky PSU, rather than trying to hide them in the photos.
  6. bloodcar
    bloodcar Minimodder
    1 Sep 2002
    Now that is nice. That's like the Man's Version of an HTPC.
  7. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    Looks good shame about the wholes drilled in the rim from the first version :)
    An idea i had is how about having the centre cap as the power button? That would be cool.
  8. Firehed
    15 Feb 2004
    While the whole tire/rim PC really isn't for me, it's pretty well done. If you discount the fact that home theatre's don't function too well without a DVD drive or tuner.
  9. BG_Geno
    BG_Geno What's a Dremel?
    4 Mar 2006
    Media PC
    Excellent mod--well worth the effort. One question. Did I miss the part where V2 got a DVD ROM drive? Not much of a Media PC without a DVD ROM drive. DVD's over a networked drive are only so so.
  10. BadHead
    BadHead Minimodder
    16 Feb 2004
    Yip - A wheely good mod - and one that you'll never get tyred of....!
    Geddit...geddit.....Aw,well never mind.
  11. Lonesarah
    Lonesarah What's a Dremel?
    6 May 2006
  12. mattthegamer463
    26 Nov 2004
    Nice mod, but I don't really feel too wowed by it. I guess because I'm a stylish but practical type of guy, and that has about no practical applications. It would just roll off a desk and stuff, so sort of less than normal practicality. Looks pretty cool though. On the plus side, if you drop your PC it will bounce and roll, so it won't break as long as its not jostled too much.
  13. Etacovda
    Etacovda What's a Dremel?
    4 Nov 2003
    I thought the first version was terrible, personally (sorry!) but the second one looks the part. I would have used the centre badge as the power button personally.
  14. malcolm
    malcolm What's a Dremel?
    8 Mar 2004
    The valve cap as the reset button would also be great :)
    Maybe one of those see through valve caps, and use it as the power light and button in one?
  15. LoneArchon
    LoneArchon What's a Dremel?
    15 Jun 2004
    Great mod and love the second version even more. But for my room this would not fit and would look out of place. I have to hand it to you on the originality great work and great to see that you did not leave it as it was after version 1
  16. Pookeyhead
    30 Jan 2004
    I like computers... I like cars... I like this mod.
    Fantastic :rock:
  17. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    Thank god you re-made that dude the origional didnt look so hot but the revision sweeps and is a very good mod indeed. Personally I would have left the tire off but that's just me.
  18. Fozzy
    25 Jan 2005
    Well as for practicality
    a) This computer wasnt designed for and will never be used for gameing because epias arent fast enough. That means it's only going to lans as a showpiece which eliminates practicality all together.
    b) It's not going on his desk it's sitting next to his computer up against a wall and probably will only be moved once a year.
    c) He made a stand for it to keep it from rolling.
    d) Who said mods were practical. I used to be able to strip my comp in under an hour. Now it would take at least 5.
  19. GoTaLL
    GoTaLL What's a Dremel?
    17 May 2005
    well allmost right .. i like cars i like the "raw" look on it .. it dont look like a computer ...
    i will be using it as a "htpc", sure a dvd would be nice to have in it but not needed "i dont want any parts of the computer showing .. the cables when connected is strapped together so still dont show .. .. its connected to the lan at home works sweet , using talisman desktop on it .. only 4 big buttons showing .. photo, dvd, musik,video got a wireless keyboard with remote what more is needed..
    it will be brought to Dreamhack for show true but it will still be landing in my livingroom at the end .. (if no one buys it).. ;)
  20. Lazlow
    Lazlow I have a dremel.
    8 Aug 2003
    It looks very good and original. It was good to see that you started again on V2 - the first was OK, but the non-parallel PSU looked terrible.
    Is it one of the first mods to blend PC and Car modding?
Tags: Add Tags
