Case Mod - In Progress Silver Dragon "Video" Pag22
Discussion in 'Project Logs' started by ulysses Cazuquel, 1 Apr 2007.
  1. ulysses Cazuquel
    ulysses Cazuquel Sex, Casemod & Rock'N Roll!!!
    29 Apr 2006
    As it had promised I am in return with a new project using as main subject known dragons beyond the painting of 3 effects that will be used
    Here this picture of the architecture of the cabinet that I will use where his main quality this in the laterals ones that are totally flat contributing to me not to have any problem to do my cuts
    Here this the image of my first cut already printed of the two dragons that I will start cuts it in the next
    week
  2. Damouse
    Damouse Thats no moon!
    27 Jan 2007
    very nice dragon design, i like i like!
    argh i hate zoomable pics... could you not? The dragons are too cool for me to avoid this thread :)
  3. Bas van der Werff
    Bas van der Werff What's a Dremel?
    18 Feb 2007
    What brand & type of case is that?
  4. ulysses Cazuquel
    29 Apr 2006
    Today it was the day of leaving the lateral ready for the cut tomorrow
    I began sanding all lateral ties to be in the metal
    Then I made the demarcation to put the drawing of the dragon so that each dragon was perfectly in the same height was very difficult, but obtained success!!
    Now it just lacks to remake some lines and to start the cut tomorrow
  5. ulysses Cazuquel
    29 Apr 2006
    here the first and only image of the cuts of the dragons therefore now only when it will be finished
  6. Bas van der Werff
    18 Feb 2007
    And? :D
  7. dan-ere-07
    dan-ere-07 What's a Dremel?
    29 Mar 2007
    Nice cuts keep it up !!
  8. ulysses Cazuquel
    29 Apr 2006
  9. ulysses Cazuquel
    29 Apr 2006
  10. stormshadow
    stormshadow What's a Dremel?
    16 Mar 2007
    omfg. nice
  11. ssR
    ssR Carbon God
    11 Aug 2006
    awesome stuff dude. you got probably one of the best if not the best dremeling skills i've seen on those forums
  12. dan-ere-07
    29 Mar 2007
    wow the best side panle ive seen well done :jawdrop:
  13. JAxen
    JAxen What's a Dremel?
    18 Nov 2005
    mawd skillz!!
  14. picio71
    picio71 What's a Dremel?
    19 Sep 2004
    very nice dragon design, i like ;)
  15. ulysses Cazuquel
    29 Apr 2006
    I finished the cuts today them dragons and with them they had been more than 90 cut record
    bigger resolution
  16. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    That's some damn good cutting
  17. ulysses Cazuquel
    29 Apr 2006
    image effect cut dragons
  18. TapperSwe
    TapperSwe What's a Dremel?
    20 Nov 2006
    Very nice work :thumb:
  19. Raziekiel
    Raziekiel What's a Dremel?
    12 Sep 2006
    WOW. Thats all I can say... :jawdrop:
  20. ulysses Cazuquel
    29 Apr 2006
    here an image you to see before and later and seeing the care that I had with the details
