Watercooling 5870 Waterblock
Discussion in 'Hardware' started by Bloody_Pete, 23 Sep 2010.
  1. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Hi Everyone
    Whats the best 5870 waterblock? I've never replaced a cooler on a graphics card before, but as long as it's straight forward it shouldn't be a problem, so no fiddly blocks. I'm also planning on using (1/2" - 3/4") 19/13mm Compression Fittings for my loop, so this has to be compatible with the block. Budget isn't a issue, but the cheaper the better.
    Oh, and I want a full cover block :thumb:
    As a side note, whats the general concensus on Fluid these days?
  2. Big Elf
    23 Apr 2009
    I'd always look to EK first and the configurator is pretty nifty.
    http://www.coolingconfigurator.com/
    If it were me I think I'd look to a Swiftech MCW60 or 80 with one of these
    http://www.swiftnets.com/products/HD5800 HEATSINK SERIES.asp
    or RAM sinks. At least you can reuse the block with that method. You might need 45º compression fittings for them though.
    I use deionised and anti-algae mainly because I had a bad experience with Feser gunking up my block and staining the res and tubing. Other coloured fluids might not be as bad.
  3. Bloody_Pete
    11 Aug 2008
    Yeh, I've played with the EK website several times, I just wanted peoples views on block usage :)
  4. Bloody_Pete
    11 Aug 2008
    Used the Ek configurator, but it doesn't have my version of the Sapphire 5870 1GB, only the new revised version. Mine should be a standard 5870, so which block will work best?
    Edit: Do all 5870's have RAM on the rear (top)?
  5. Bloody_Pete
    11 Aug 2008
    Bumpy Bump :)
  6. Bloody_Pete
    11 Aug 2008
  7. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    I hope you're not planning to buy water online. Just walk into any automotive store and they'll sort you out, should save you a few quid.
    Where i live they also sell proper distilled water at pharmacies but they only give you so much...
  8. Bloody_Pete
    11 Aug 2008
    The nearest Halfords is a trek away from where I live, and the bus would cost more than the cost of delivery... Plus its free delivery from the Halfords website...
  9. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Does it necessarily have to be one certain store? Anyways, if it's free, then why not! Get two! lol
  10. Bloody_Pete
    11 Aug 2008
    10 ltr's may be a bit much :p
  11. Bloody_Pete
    11 Aug 2008
    Anymore thoughts anyone?
  12. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    for the 5870 and 5870 E6 you will want to use this block
    This block comes with thermal paste and heatpads for the ram and power.
    Also the key thing to when looking around to buy this block, look for this part number... 3831109835043
    The 5780 E6 has some mem chips on the back of the card, however these have some heatpads which can be reused if carefull or use whatever is left from the water block kit, in which will stick to the black back plate fitted on the 5870 E6 as part of the stock cooler.
    The instructions for the block are quite clear and easy to follow with regards to fitting the block :)
    I would recommend this non conductive fluid should you be unfortunate enough to spring a leak.
  13. Big Elf
    23 Apr 2009
    If you want a non-conductive fluid don't add anything to deionised/distilled water. Even that, over time, will become conductive.
    If the block isn't listed on the EK Configurator I'd check with them to make sure which one fits. If there isn't a perfect fit for GPU, VRAM and VRMs you could have problems.
  14. Bloody_Pete
    11 Aug 2008
    I ordered a load of deionised water :) Is the Nickle version preferable over the plain copper one, to stop galvanic corrosion?
  15. Big Elf
    23 Apr 2009
    You'd only get galvanic corrosion if you have aluminium in your loop which these days is unlikely. I personally think the nickel and delrin blocks look best. A nickel block doesn't tarnish either.
  16. Bloody_Pete
    11 Aug 2008
    Cool :)
    If I use just deionised water, what should I add to it? Silver coil?
  17. Big Elf
    23 Apr 2009
    I use both a silver coil and King British Green Algae Control (from Wilkinsons) on the principle that it'll probably take a while for the silver ions to get assimilated in the water.
  18. Bloody_Pete
    11 Aug 2008
    Just grabbed a Silver Coil :) Is the Green Algae Control needed too?
  19. Big Elf
    23 Apr 2009
    I've never been sure how long it takes for the silver ions to be effective which is why I put the algae control in as well. It only needs a drop per litre and costs under £4 with enough in the bottle to last roughly 300 years.
    Bloody_Pete likes this.
  20. Bloody_Pete
    11 Aug 2008
    I may have to keep an eye out for it. Does it discolour the water at all?
