Case Mod - In Progress ZdMods | Project 180 | Final Pics 20/12/13
Discussion in 'Project Logs' started by Meelobee, 27 Dec 2012.
  1. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Now that I've almost finished Project pǝʇɹǝʌuı (new GPU arrives today!) I've started on a new mod, which I'd like to share with you.
    This time not a scratch build, but a rebuild of an exisiting case, the Antec P180. Why this case, well simply because I had it sitting around after building Inverted.
    Currently the hardware is outdated: Intel Q6600, 4Gb Ram, Radeon 6870. So I'll buy new hardware along the way of the build.
    Picture time!
    Standard Antec P180 housing
    Again I'll be using 25x25mm aluminum tubes
    Cut away parts of the original front to make room for the alu tubes
    All alu bars in place, 3mm transparant plexi in between
    Finished the top and bottom with a alu strip
    Testfit of the front
    I want to put 2 fans in the front that will draw air from the bottom of the front through the tubes. They won't be able to breathe much, but hopefully enough for what I want to do
    Sketchup of the fan cutout in the front
    This is what it looks like so far, the 2 outer tubes still need to be cut
    That's it for now...:dremel:
    [​IMG] [​IMG]
    Sponsored by
    [/URL]​
  2. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Love the idea mate!
  3. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Looks really nice, I like it.
    Good idea with the tubes. ;)
  4. _ferry_
    _ferry_ What's a Dremel?
    22 Apr 2004
    Great idea, and fits very well with the part of the front which remained :)
  5. Guest-23315
    Guest-23315 Guest
    That front door looks sweet as...
  6. Ace_finland
    Ace_finland Minimodder
    11 Aug 2012
    very nice as always!
  7. bulldogjeff
    2 Mar 2010
    I love the look of that front. That is going to look really good when it's done.
    As for the fans, you'll be surprised at just how air flow you will get. There are no filters or other obstructions to impede the air. So it shouldn't have to much of an affect.
  8. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    that front. industrious-looking. aggressive yet sleek..
    10/10! love the idea for creating airflow! where are the words to describe this?!
  9. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    Wow this is looking good :)
  10. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Great originals idea subbed looking forward to where this goes :D
    Sent from my Nexus 7 using Tapatalk HD
  11. Meelobee
    5 Nov 2003
    Thanks for the great replies everyone :)
    I've done some more work on the case:
    First I've finished the front, the fans are now countersunk into the tubes
    There were some damaged area's on the plexi which I filed down, before:
    After:
    Fans fitted
    Front on the case
    I've bought some pieces of alu sheet to replace the front, back and midplate of the case.
    Took the case apart, the white sheets on the left are the new alu parts
    After cutting the front and back there wasn't much of the original material left
    Made the front sheet to size
    And bolted it all together again
    [​IMG] [​IMG]
    Sponsored by
  12. KidMod-Southpaw
    28 Sep 2010
    This is just awesome! Love the front panel!
  13. siliconfanatic
    10 Sep 2012
    quick tip, you might want to get rid of the front part of the fan shroud as, when you shoved em in you created what my mind sees as a severe hindrance to the airflow, because as far as the fans are concerned, the bar/tube thickness just got halved, which halves the amt of air they can getwas also halved... the other option is to un-sink them a tad. correct me if i am wrong, a few red flags just flew up in my head. still great idea, gives me even more ideas for getting more air into my case.
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    About time I subscribed to this, looking nice so far Meelobee. :)
    Acrylic aluminium cheesecake sandwich. :D
  15. Meelobee
    5 Nov 2003
    I'll see how it works, if needed I could unsink them a bit. :)
    Thank you sir...Cheesecake :clap:
    Had some time to work on the case this weekend, first I've put the original I/O panel into the midplate.
    Then I've cut 2 bars to replace the top piece of the case. To still be able to slide in the sidepanels (the panels have small hooks) I had to cut 3 rectangular holes in the side of each bar
    The 2 top bars sit on L shaped pieces attached to the front and back of the case
    With the sidepanels on it's all flush and straight :)
    I've polished the strips on the top and bottom of the front with Commandant #4 after sanding them to P800
    [​IMG] [​IMG]
    Sponsored by
  16. Attila
    Attila still thinking....
    22 Feb 2008
    Terrific work Meelobee! :thumb: The front is awesome.
  17. Meelobee
    5 Nov 2003
    Thanks alot Attila :)
  18. Guest-23315
    Guest-23315 Guest
    This. This. This.
    Can't believe someone hasn't done this before on a P180
  19. siliconfanatic
    10 Sep 2012
    i might've missed something:worried:, but are you, say, gonna light up the acrylic, or do something flip-out crazy awesome with it :D
  20. Meelobee
    5 Nov 2003
    Thanks Mankz, I was kinda surprised too :)
    Yes leds will be involved. I've drilled holes in the top of the acrylic to fit 3mm white leds. Here's a testpic with a normal light behind the acrylic:
