Hardware Asus Immensity: ROG board with on-board HD 5770
Discussion in 'Article Discussion' started by Lizard, 3 Jun 2010.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
    Wow! on-board HD 5770?!
  3. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    Just don't try it with Fermi unless you want a hole in your motherboard
  4. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    The problem is its more than likely going to cost more than the equivalent mobo and GPU separate, Unless the lucid chip sees a massive improvement i cant see this taking off tbh.
    If it was an matx 1156 with a built in 5450/5770 it would be great for a media comp.
  5. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Wow! On board 5770? That'd be a killer to cool efficiently without blocking anything.
    Sounds more like a 5450, TBH.
  6. Glix
    Glix Left Thumb Stick in the mud.
    11 May 2010
    Whilst I like the idea of a mid end card on the mobo. I think that ATX is the wrong platform to use it on. Like above me says, m-ATX and it would be great for media comps as all it does here is take up lanes on a X58 board where you wouldn't even consider using a mid end card with. Thankfully it's only a prototype to demonstrate the idea.
  7. CharlO
    CharlO What's a Dremel?
    21 Oct 2009
    Do want, here are my life savings. Only, will you please also add a 64gb ssd to boot the os? I'll die happy after unboxing.
  8. Lockon Stratos
    Lockon Stratos I Will Snipe You!
    19 Apr 2010
    It would be nice if that onboard 5770/5450 can be hybred crossfired that would be total poonage. - imagine....2 5970s+integrated 5770 in hybred crossfire. though i suppose there would probably be some serious driver/Ai issues with the gpus fighting over work or deciding what sort of work to make the integrated chip do.as its not as powerful as the other GPUs...
    guess we wont know until we get some reviews.
    on a side note - its a pitty Asus cant be this Gung Ho about their soundcard dept. their drivers are stable but they could do with lots of tweaking. the DS3DGX eax emulation engine could do with a little fine tuning too. theres quite a few games out there that dont work properly with Xonars when it comes to EAX. but Asus just dont seem interested in building a decent tweaked driver that fixs the issues.
    these guys in the interview seem genuinely passionate about their company & their products. now if only they could channel some of that enthusiasm into the audio dept.
  9. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    If they do release a model including a decent GPU I'd be tempted to purchase it for my next upgrade. If the Hydra really works as intended and provides decent performance then why not use it to blend my 5870 with a built in 5770 and get a little more performance and future proofing? Seems like that's the real goal listening to what the interview said: allow people who already have a dedicated graphics card get added gaming performance from their motherboard through the use of the Hydra.
    Only slight draw back I see happening is it physically taking up the top couple expansion slots, but seeing as a full card would take up a couple anyway who cares?
  10. shadow19935
    shadow19935 Whats overclocking? :D
    17 May 2010
    You could have a HD 5970 + HD 5870 + HD 5770 and the onboard HD5*** an none of the cooling fans would be obstructed by the other GPU!! PURE WIN!! :D
  11. Pete J
    Pete J Employed scum
    28 Sep 2009
    I'm going to go against the grain here and say having an on-board GPU is a BAD idea. Why?
    1) That integrated GPU is taking up a 16x PCI lane that could be used on a more powerful card.
    2) Integrated GPU with an i7 9xx CPU? Really?*
    Bottom line is that if you want an X58 motherboard, you're most likely looking at a 5850+ anyway.
    *I can think of some people who'd want to build a powerful FEA computer and wouldn't be interested in a stupidly powerful GPU. In which case, this would actually be quite a useful mobo.
  12. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    I clicked, and I immensified the Immensity.... MOUHAHAHA
    (yes, I really felt that way. It was great.)
  13. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    For point 2, judging by the presence of the Hydra and by the RoG naming, this is certainly not meant to be used as a standalone graphics solution. It's not just integrated graphics in the traditional sense, it's more like additional graphics. Like one of the gentlemen in the interview says, the idea is to provide integrated graphics which won't be wasted when additional GPUs are added, and instead support them.
    Following that for 1, it would seem that it could easily be wired up to run at 8x, which would probably be fine for a 5770 or less, which should allow for two more 16x slots (X58 provides that many, right?). That would allow for 2 cards in full Crossfire/SLI as well as a 5770/5450. The only situation which really starts holding a person back is the likely inablity to use tri-SLI/Crossfire. Crossfire solutions could go 2x5970, so 3x5870 is somewhat rare, so ATI solutions are largely unaffected. SLI would allow for two cards of choice, such as 2xGTX480, with only extra high end system such as your own being affected.
  14. neocleous
    neocleous Minimodder
    12 Feb 2002
    Forgive my ignorance but why would I want to mix ATI and nVidia cards together what is benefit over a straight ATI crossfire or nVidia SLi setup
  15. stonedsurd
    11 Mar 2009
    Next time you see Mr. Hsu, please tell him that the reason no one wants ASUS in India is because they're selling their stuff at about 20% more than competing products and their local distributor is the spawn of Satan.
    It has nothing to do with ROG or non-ROG boards.
  16. Unknownsock
    Unknownsock What's a Dremel?
    13 Jul 2009
    So when you upgrade to a new card you can still use your old card along side it.
  17. hbeevers
    hbeevers Yes, it can play crysis!
    24 May 2010
    This is a great idea for future upgrdes! I'm only running an i3 cpu at the moment with an asus hd 5770 but in the future i'm looking to upping to an i7, this would mean that i could also see a GPU improvement with only buying a new CPU and mobo, hopefully this combo would be cheaper than buying a decent lga1366 mobo and 5770 seperately though. It's also great for future proofing, keep your old card AND use the new one no matter what manufacturer it is.
  18. willyolio
    willyolio What's a Dremel?
    17 Feb 2007
    i want to see some benchmarks of this baby. and also how well the Lucid chip works.
  19. javaman
    javaman May irritate Eyes
    10 May 2009
    So Asus possibly integrate an HD5770 into their motherboard while AMD (and intel) aim to integrate that level of performance into the CPU.
  20. Guinevere
    Guinevere Mega Mom
    8 May 2010
    In a mini-itx formfactor?
    No?
    Then I think I'll skip
Tags: Add Tags
