now either im a noob or something isn't right; parents new pc wont do anything! gigabyte F2A85X-UP4 , A10-5800K , antec 450w psu nothing happens at all when I press the power button ! nothing at all - no beeps nothing! except - the psu power switch (internal) is lit and orange? any idea`s?
Doesn't sound good if you are getting absolutely nothing when powering on. Disassemble and maybe try another PSU. If still no action sounds like the boards smoked.
Oh - not BIOS then Sounds a bit more serious. If it's in the case, take it out and build it on the side, just to check for shorts (electrical, not the clothing variety - it's too cold for those at the moment)
Trying another PSU would be an easy check if you've got one spare. Not wanting to be rude, but have you made sure you've plugged everything in correctly (including the front panel connectors) since I know in the past I've had a moment of panic when nothing seemed to work before finding out I'd connect the power switch to the wrong headers.
Meh dead antec psu it is. .. definitely a noob moment for me I think should have checked first! Windows installing on 8gb 2133 cl 10 ram and an ssd
