Case Mod - In Progress Little box of grey and orange
Discussion in 'Project Logs' started by tranc3, 2 Apr 2012.
  1. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Seems like I haven't been on this side of the forums in a while. I kind of dropped out of the modding scene for a while. To be honest the recent John Hanlon Fund Raiser Build and MNMPCTech have made me want to get my dremel out and start making something of my little case. This p180 mini has been sitting around for over a year in all it's stock glory.
    Plans so far:
    Reworking the front for better air flow, and/or a 240mm radiator for liquid cooling.
    Small (Bolt on?) window on the side panel.
    possible repaint of the entire, at least some parts of the interior.
    Keep a simplistic yet appealing modern design overall.
    Better cable management.
    Move the hard drives to the bottom of the case.
    Eventual a full system upgrade, running a bit behind the times.
    Orange lighting/tubing.
    I felt if I made a thread it may motivate me, even if it hasn't helped in the past. The biggest problem I'll encounter with this build is that I don't really have a place to work on any thing with power tools at the moment. We're in a small one bedroom apartment and I don't think the neighbors would enjoy a dremel running in the middle of the night. We're planning to move soon as I'm starting a new job so I should have some working space in the near future.
    I'll keep all my thoughts and progress related to this build in this thread, be prepared for lots of rambling ideas.
    Happy modding my friends, suggestions and constructive criticism is always welcome!
  2. Guest-23315
    Guest-23315 Guest
    Not a project log, so will get moved to modding :thumb:
    Just remember to get used the tool before cutting anything of value, and measure twice cut once :
  3. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Well I put it here since I planned to put the project log here, thought I was in a grey area... If it needs to be moved I won't be upset.
  4. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    The start of something.
    Couldn't sleep tonight so I pulled the front off, took it apart and snapped some photos.
    Started working on some things in sketch up.
    And Photoshop
    I wonder who I could get to cut me out a nice piece of acrylic...
  5. Metrodusa
    Metrodusa What's a Dremel?
    14 Jan 2012
    Whoever works with acrylic might have a laser CNC. It's not expensive, if you have it in Autocad already.
  6. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    About 75% with the internal chassis in sketch up.
  7. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    been working on it in Sketch up, got a pretty decent model to play with. I'm thinking replace the two front vents with one single door, and an integrated dust filter not to sure on the cut out i have on the grill. and then just a simple window on the side.
  8. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Thinking about the front like this, either acrylic or aluminum. With the mesh in the middle and a removable mesh dust filter that slides in the door.
  9. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Just looked at Evercool ME-240 3.5" and thought it'd be nice mounted on the front where the usb/audio is. move the usb/audio to the side of the case maybe?
    Something like that
  10. Megatron1764
    Megatron1764 What's a Dremel?
    3 Apr 2012
    I hope this goes well. This is the same case I have, and have been looking for some ideas for mine. Keep the updates coming. :0:rock:
  11. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Hard drive failed today, fantastic.
    But in other news Its a real mod now. Stripped it down and drilled out some rivets.
    As you can see certainly no room for a 240mm radiator...
    Much more open.
    Now I've started thinking having the hard drives right up front would make me uncomfortable. Thought about moving them internal plenty of room to add a hard drive cage.
    Also been thinking about running the tubing for the liquid cooling down through the divider, drilling two new holes keeping the industrial/minimal look.
  12. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Been thinking it'd be better to make a longer cover for the front, maybe bolt/pop on would be better..
    Also thinking about working these in to the bottom two 5.25" bays since they would be covered by this panel.
    ICY DOCK 3.5"
    ICY DOC 4x2.5"
  13. jhanlon303
    7 Sep 2006
    Sneaked in on me. I like this. I had that case once. Left it stock and had a nice lady buy it. A few lights and she was happy.
    I watch.
    john
  14. Dexta211
    Dexta211 What's a Dremel?
    18 May 2010
    Big fan of mods on this and the P182, so subbed!
  15. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Maybe some Orange on the front? Bolted on.
    Might get some particle board to try some stuff with, before I go dropping money on acrylic panels.
    Also x500 is up for this being another sort of co-lab, this one We'll finish. He's sending me a package with some goodies in it, also just informed me of a Laser cutter that he has access to at his school.
  16. Cheapskate
    13 May 2007
    Dremel it. File it. Sand it. :D You don't always need to rely on fancy machines. When you get rickety and old, (or just maniacally meticulous,) go for the CNC.
  17. jhanlon303
    7 Sep 2006
    Yo! somebody mention old and rickety?
    We don't do this caliber of work. Is nice.
    john
  18. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    First booboo from the project! Hot rivets are not your friend.
    pulled the bottom 5.25" bays out, making room for the potential new home of the hard drives.
    The case got a booboo too... might get covered with some orange acrylic...
    side note:
    I feel like I should be taking better photos, looked around the forums and noticed every one has very high quality photos of there projects.. I wish I had something better then my HTC Hero to document progress with.
  19. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Thought I should give an example of what I'm planning with the hard drive cage and lighting.
  20. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Thought I'd do a test fit in sketch up, my scale is slightly off from the components I've used, still gives a good idea of whats going on in my head.
