Motherboards Quite simple. Which board.
Discussion in 'Hardware' started by Kronos, 7 Feb 2012.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    If all you're doing is FPS gaming, I'd just get the cheapest. Unless you need the added features of the more expensive ones, there's no real point. But then if you have the money, may as well get the Maximus IV.
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    Thanks, I had an Asus P8P67 and it just did not do it for me same with the Gigabyte P67-DS3.I am currently using a GA-Z68-UD5 and it's hard to put my finger on it but there seems to be something missing.
    I must admit I was leaning towards your suggestion.
  4. feathers
    feathers Minimodder
    11 Apr 2009
    Get the same board I have... Asus P8Z68-V/GEN3 at about £137.
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    Any particular reason why?
  6. noizdaemon666
    15 Jun 2010
    Just to add on to my last post, I personally if I had the money, would get the Maximus IV as it seems an awesome board.
  7. wodgah
    wodgah What's a Dremel?
    26 Jan 2012
    I have the Sabertooth and i must say it is extremely easy to use setup overclock and i have had 0 issues at all. About to watercool my rig and push things further and for the money i think the sabertooth is great.
  8. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    What are you plugging into it? The three boards you have linked too are all different sizes.
  9. Kronos
    Kronos Multimodder
    6 Nov 2009
    Pardon? Not sure what you mean. They are all 1155 boards so will take my i5 2500K.Or do you refer to something else?
  10. noizdaemon666
    15 Jun 2010
    He's referring to physical size. The Gene-Z is mATX, the sabertooth is ATX and the Maximus is E-ATX. But I seem to remember you having a large case so all would fit. Though the Maximus would make it look the fullest.
  11. Da_Rude_Baboon
    28 Mar 2002
    The three boards are different form factors and sizes. mATX, ATX and eATX. They will have different amount of expansion slots and layout. For example if you buy the mATX board and decide to go SLI all the slots will be covered and you wont be able to plug in anything else, such as a sound card. Will an eATX board fit in your case?
  12. feathers
    feathers Minimodder
    11 Apr 2009
    Yup,
    Extremely stable, 5ghz with ease even on auto and it's not expensive. Great fan control with 3 x 4 pin pwm fan headers plus additional 3 pin headers too.
    There's alos gen 3 PCIe if that's any use when Ivy comes.
  13. Kronos
    Kronos Multimodder
    6 Nov 2009
    Of course how stupid of me.
    [QUOTEThe three boards are different form factors and sizes. mATX, ATX and eATX. They will have different amount of expansion slots and layout. For example if you buy the mATX board and decide to go SLI all the slots will be covered and you wont be able to plug in anything else, such as a sound card. Will an eATX board fit in your case?][/QUOTE]
    Thanks for coming back. I had no thought to look at form factors, I have no need of an e-ATX so that lets the Maximus IV Extreme out or a m-ATX so thats the Maximus IV GENE-Z out so I am left with the Sabertooth.
    As to my case i currently have the SilverStone FT02R-W which has to many design flaws for my liking, rubbish space for hiding the cables,the fact that the top lid is not hinged also the top lid has the braces covering A) the top exhaust grill making it a little tricky adding an extra fan for a push/pull effect and B) another brace that goes across the graphics card back plate making it difficult if you have an older type secondary monitor of fitting a dvi adapter to the GPU. So it is going. I am currently take with the Lian Li B25FWB but am still looking at cases.
  14. Kronos
    Kronos Multimodder
    6 Nov 2009
    Will have a look at that.Thanks.
  15. feathers
    feathers Minimodder
    11 Apr 2009
    Thing is I decided a while back I am done with more expensive mobos. A good mid price mobo in my experience can be very good.
    Stability and overclocking are the most important things for me. Ease of overclock as well.
  16. Tangster
    23 May 2009
    I'd recommend the MSI P67A-GD53/55. Both are great boards and can take a decent 2500K up to 5GHz and beyond with no trouble at all. I assume the equivalent Z68 models are also great boards.
    Not the largest set of option in the BIOS compared to the Maximus, but they have some of the best VRM's I've seen on a board(extremely cool running, even with high volts) and are cheaper than many competitors.
  17. Kronos
    Kronos Multimodder
    6 Nov 2009
  18. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    i like my board. it has better heatsinks than the standard p8p67.
    i have got my 2600k to 5ghz but i didnt want to keep it there 24/7
    at 4.6ghz, it has been very stable. i have had 1 bsod since i bought it, but i think that was the ssd
    this is also with he bclk at 103.5 and ram oc'ed
  19. boltonuk007
    boltonuk007 What's a Dremel?
    29 Sep 2011
    £120 at scan
  20. boltonuk007
    29 Sep 2011
    What sort of voltages does auto put through it to get 5ghz? I tried it on auto to get 4.8ghz and it tried putting 1.6v through it! Im currently running at 4.8 with 1.38v
