Scratch Build – In Progress The Shrine (update 24/3 COMPLETED! photos and video)
Discussion in 'Project Logs' started by quizz_kid, 14 Oct 2012.
  1. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Time for a new project!
    "The Shrine" is a HTPC in solid walnut. The concept for this build is nature and technology in symbiosis.
    For coolant I´ll be using something amber like. This to resemble resin, binding machine and nature together. Colors I´ll be using are Walnut, black and copper.
    The build is designed around an acrylic dome which I found a couple of weeks ago
    It will be built in two levels:
    *A top "display", with water cooled CPU and MB encapsulated by the dome.
    *A base, "the trunk", where other components will be sharing airflow
    Sketch
    I will also have an Arduino based LED system on top, with 30 diodes in orange,
    breathing sort of randomly. Well, let´s just hope for the best :worried:
    Specs:
    CPU: ?
    MB: ASRock H77M-ITX
    Psu: my oldCorsair CX 430W
    GPU: my old GTX 460
    RAM: Corsair Donimator 2x4GB
    SSD: Corsair Neutron GTX 240GB
    Water cooling for CPU:
    Block: Alphacool NexXxoS XP³ Light - Acetal Edition - Intel/AMD
    Rad: Alphacool NexXxoS ST30 Full Copper 120mm
    Fan: 1x Phobya G-Silent 12 1200rpm Black Silent Edition
    Res & Pump: Phobya DC-220 & Alphacool Cape Corp AGB2
    Fittings: Alphacool 16/10 G1/4 - shiny copper
    Dome, aprox 320mm in diam
    I will try to finish my REDELUX build next week. Until then...
    Hope you´ll enjoy this / Quizz
    Sponsors:
  2. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Woodwork:
    Bought myself a fine piece of walnut lumber
    Cut and planed pieces
    24 pieces and some 7,5° cutting. Then I made 2 rounded groves along each piece, for decoration.
    BRIO railway in walnut anyone???... Or just a 24 sided cylinder.
    Some components for you guys:
    ASRock H77M-ITX
    Picked this board because of layout and color.
    My old 460 will be placed under the mobo with a flexible riser.
    Three 40mm fans for intake.
    PSU was too big, so I took it apart.
    Much better!
    Components for the Arduino module.
    Thank you Andreas on Aquatuning.se for the cooling system from Alphacool and Phobya!
    And thank you Gareth at Corsair, for the RAMs and SSD!
    Waynio likes this.
  3. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    This is a nice idea, good luck on it dude! :thumb:
  4. C4B12
    C4B12 Minimalistic PC's
    6 Oct 2011
    Always nice to see your scratch builds. Love it. Looking forward to this. :)
  5. Waynio
    Waynio Relaxing
    20 Aug 2009
    Another quizz project, & now sponsored :D:rock: awesome. :clap:
  6. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanks!
    Thank you... and nice to see you here mate!
    Yep... Should probably change signature to "pro" now... or "owned" maybe :D
  7. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Work from today:
    Started by milling the intake on the front. This is the only decorative element on the main walnut cylinder. Going to keep it sparse and simple here, to keep the spotlights on the dome.
    I placed sacrificial pieces in there before I cross cut in the milling machine, to not lose material.
    After milling.
    I like it! Like a abstract tree or something. Goes well with the concept I think.
    Backlit.
    Took away some material for the three 40mm fans. Not the best intake, but it´ll help a little.
    I will have a hatch in the back to facilitate assembly. Here I´m using a 7,5° gigg for some hinge milling.
    Black hinges.
    Kind of discrete I think.
    The backside.
    Milled a hole for the radiator on the hatch, 10x10cm.
    Almost ready for glue now.
    Found some 5mm magnets for the hatch aswell.
    Drilled holes for them.
    Later! :lol::lol::lol: / Quizz
    Livio likes this.
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    That sacrificial method is handy to know about :) nice to see some more workshop stuff in your logs, was never all that sure of what methods or tools you use for all steps really but it's always been clear you are awesome at this. :D
    Sweet progress. :clap:
  9. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Bro, your work is sooooooo good, talented thats for sure!!! Cant wait to see how this is going to look like at the end!!!
  10. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
  11. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanks Waynio. I know I´ve been sparse with workshop pictures before. This is my new workshop btw :lol::lol::lol: The zink machine I´m working on there is a KILLER!! You can do anything with it...
    Thanks AnG3L! Much appreciated...
    :lol::lol::lol:
    Some work:
    Put the pieces in order
    Used masking tape to keep them together
    Glued under pressure. Note that I didn´t glue the pieces with red crosses. That´s the hatch.
    After a couple of hours I removed the pressure. The cylinder is pretty fragile as it is, only 13mm thick. But I will make it more stable later and lock the cylinder with bottom and roof.
    I milled inside the hatch and made a plateau for the 120mm radiator.
    The zink machine is a pleasure to work with... My new favourite toy!
    This is how it´ll look like...
    I´m not going to use skrews from the outside so I drilled holes right through the rad.
    Later!!
    Waynio likes this.
  12. Attila
    Attila still thinking....
    22 Feb 2008
    Awesome work quizz. Much to learn from your project logs. The sacrificial wood for the milling is good to know, I always wonder why the ends break when I'm using the router. :rolleyes: And the geometric constructions are always so well done. I watch. :)
  13. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thank you Attila. Yeah, I learned about using sacrifical pieces just a month ago, feel kinda new born :idea:
  14. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    Great work quizz.
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    Oooooh, real nice work quizz. :dremel::rock::clap::hip:
    Watching what you do is really going to give me drive to try a woody project. :)
  16. Furball Zen
    25 Jan 2012
    Quizz, youre giving Waynio a woody!!
  17. Cheapskate
    13 May 2007
    Oh, this is going to be good.:D
    A delicious block of walnut like that is hard to come by here.:( Even the pine available here right now was from stuff that died during the drought. It's all cracked and crappy.
    I'm going to assume you drilled between the tubes. :worried:
  18. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanks!
    Yeah, you def should try it... It´s like working with butter compared to metal work :lol:
    We´ve got some really good local lumber up here, it´s a blessing :D
    And yeah, I tried to avoid the tubes while drilling.
    Just a small update today. I wanted a delicate small start button in black and copper, but even searching through ebay did me no good. Hard to come by things in copper I guess. Well, I gave up and made one myself.
    Bought this 13mm push button in nickel
    Had to drill some holes in the back to seperate button from nickel housing.
    Seperated...
    Painted the nickel in copper. Also cut and painted som mesh for the intake.
    Button glued back with epoxy. That´s it!
  19. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    More work...
    Made a bottom piece in 16mm MDF and milled two groves for supporting walls inside the chassis.
    Cut the two walls from an 10mm shelf I had laying around.
    Test mounted stripped GPU, PSU and SSD
    Airflow will pass between the walls and through the chassis.
    Cut and veneered the plate for the mobo. 4mm MDF with walnut.
    The plate/display will be attached to the two supporting walls with screws on top. And here´s the h77m on top of it.
    Walnut and black... I think this will look really good :lol:
  20. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    Looks sweet! Nice work preventing tear out with the sacrificial pieces when doing the vents. What do you use for milling that? Is it a metal mill, or one specific for wood?
    I don't know how I missed all this... But glad I found it :)
