Hardware Fractal Design Define R3 Review
Discussion in 'Article Discussion' started by Claave, 29 Oct 2010.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. stonedsurd
    11 Mar 2009
    Another fantastic case. Those folks at Fractal definitely know their work!
  3. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    Looks great, shame I've already got my new case ;(
  4. memeroot
    memeroot aged and experianced
    31 Oct 2009
    Great review of a lovely case.
    just out of interest this comment worries me slightly
    "make sure their graphics card cooler exhausts air out the back of the case rather than into the case."
    Given the increasing use of aftermarket coolers on oveclocked gpu's how should this affect our views of cooling results on other cases.
    How should we read GPU results now, previously they could be (largely) ignored if you had a rear exhaust gpu but now you are simply measuring the intake temps of the GPU...
  5. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Given the R3 is structurally identical to the R2, could you elaborate a bit on this comment please.
    It's good to see Fractal Design taking on constructive critisism and acting on it. The R3 is an improvement to the already very good R2.
    Get some low noise 120-140mm fans in the roof and another one in the front and you have an excellent cooling case as well.
  6. Cei
    Cei pew pew pew
    22 Mar 2008
    What's an "Admiral job" for a PC case? Does it command a navy of small RAM ships and hard drive cruisers?
    Yeah, typo on first page ;) Looks like a lovely design for a case though.
  7. Baz
    Baz I work for Corsair
    13 Jan 2005
    For your sharp eyes, it's too the crow's nest with ye!
  8. facwit
    facwit What's a Dremel?
    24 Aug 2010
    So glad I got one of these cases. It looks fantastic and I can hardly hear my gtx480.
  9. Claave
    29 Nov 2008
    I seriously hope that 'too' was ironic Harry... :S
  10. azrael-
    azrael- I'm special...
    18 May 2008
    They still have those disparate case feet. Shame... :(
  11. Cei
    Cei pew pew pew
    22 Mar 2008
    Everybody knows sailors can't spell. Yarrr.
  12. devilxc
    devilxc Biding my time...
    23 Mar 2010
    Excellent to see they took on board the feedback and improved it. They seem to have done as much as possible while avoiding the price hike associated with changing the manufacturing process.
    If I was looking for a case atm I would have this near the top of my list.
  13. julianmartin
    julianmartin resident cyborg.
    25 Jul 2004
    My R3 arrived last week and I am very, VERY happy with it. I have 4 120mm fans in there, 2 from Fractal and 2 Gelids, and it is still very quiet. Most of the noise comes from my GPU. Very impressed and great value too, IMO.
  14. Pierre
    Pierre What's a Dremel?
    17 Jun 2010
    As I know, the Fractal Design Define XL is (or is expected shortly) in bit-tech's labs...
    Since the full tower case is actually much different in configuration, I can't wait for it to be tested...I am particularly interested in seeing how well hdd cooling is for the bottom compartment...
    If I could make a request, that would be to fill the bottom 6 hdd bays of the Define XL and see what the hdd temperatures are, since there is no direct airpath...
    Someone else said it before in the comments... Was this case improved sturcturally, as rigidity is concerned? Was there wider steel sheets used? Were they folded better?
    How rigid is the HDD cage against vibration (these were all mediocre qualities of the Define R2)
    Can't say I favor the switch to faster spinning fans...it will most likely mean that I might have to replace them, increasing the overall cost...
  15. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    For those wanting to see what a difference additional fans made to the R2 case, check out the follow up here: http://www.bit-tech.net/blog/2010/01/25/fractal-design-define-r2-follow-up/.
    Note: the R2 was tested using different kit (as mentioned in this R3 review) so bear that in mind when reading the follow-up.
    The bottom line is that additional fans can make a huge difference to the cooling ability of the R2 & R3.
  16. lp1988
    lp1988 Minimodder
    24 Jun 2008
    I think I have just found my new case :)
    whenever I decide to change that is
  17. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    My overclocked 4850 dumps hot air inside my case (an R2) and it's absolutely fine. I'm only using the two top fans as exhaust because my H50 takes up the slot at the back. It's actually cooler than it was in my Antec 900 because I can get cool air to the underside of the graphics card using the 120mm intake on the bottom.
    I must say I never really understood why you guys at bit-tech mostly review cases at their stock configurations, given most of your readers like customising their PCs... that's why they buy "Custom PC Magazine" not "Stock-Configuration PC Magazine", I'm pretty sure.
    Fractal Design could have packed their case with expensive fans but that would have driven the price up. As you yourselves proved some simple alterations to fan/airflow setup makes a big difference so why can't we have reviews with stock AND custom cooling configurations? Please?
    These cases would come off very well in such a test as there are so many different places to put fans to optimise airflow for your specific hardware. Many cases are less customisable and their "decent" stock cooling might be the best you can ever get out of them. It would be nice to know this information before buying stuff, so I'd like to see it in reviews.
  18. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Do you have any idea of how many cooling configurations that would be? Combined with time for setting it all up, testing it and deciding on which fans you use it would take years. It would probably result in 1 case review pr. 6 months.
  19. Yslen
    3 Mar 2010
    I'm sure it could be done quicker than that. If they can't do it then fine, but I generally read CPC/bit-tech for their quality reviews, so I thought i'd voice my opinion on what they could be doing to improve them further.
  20. Necrow
    Necrow Minimodder
    24 Feb 2009
    Are Antec engineers are still wondering where their deisgn plans for the P182 dissapeared off too? lol
Tags: Add Tags
