Graphics offical aquamark3 thread
Discussion in 'Hardware' started by Carbon, 15 Sep 2003.
  1. Carbon
    Carbon Banned
    8 Jan 2003
    can everyone post their scores in this thread plz :d
    you can get aquamark3 here
    my score 20,493
    (taken image off, need some space on my host..lol)
    [edit1] RULE: THE USER POSTING THE LINK MUST PROVIDE EITHER A FULL SIZE SCREENY OR A VALID FUTUREMARK LINK OR IT WILL NOT BE ENTERED INTO THE TABLE!
    [edit2] here is the league table... credit to mace for the below image (and me for being so bored that i did the original ;) ) [/edit2]
  2. micb
    micb Minimodder
    4 Sep 2002
    AMD 2000 XP, 512MB PC133, ATI Radeon 9800 non pro.
    All Stock Clocks.
  3. Tim S
    Tim S OG
    8 Nov 2001
    I'll sticky this one, seems worthy of it, I'll post my score when I've rebooted/installed it :hip:
  4. [DE]FreD_S
    [DE]FreD_S Certified Specialist of Awesomeness
    6 Jan 2002
    34917 Can be viewed HERE
    Cheers
    [DE]FreD_S
  5. Hwulex
    Hwulex Minimodder
    1 Feb 2002
    Server... slow.... as..... a slug.... in toffee....
    Managed to get the mirrors page working though and downloading at 60KB/s. Screenies to follow. :)
  6. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Results
    The Massive Overdraw made my system cry.
    edit: oh yeah, system specs:
    AMD XP 2500+ Barton
    512mb PC2700
    ATI Radeon 9500
    All stock clocks
  7. Tim S
    Tim S OG
    8 Nov 2001
    Well, my card struggled to get thru this, but my CPU pweeens :D
    Barton 2500+ @ 223x11 2453Mhz
    nVidia GF3 @ 237/522
    2x 256Mb PC3500 Mushkin level II @ 2-6-2-2 446Mhz DDR.
    ABiT NF7-S - no mods
  8. :Galokin:
    :Galokin: Guest
    Downloading now, shall post results later on.
  9. tk421
    tk421 Idiot.
    15 Jan 2002
    xp2400+@default
    sapphire 9600pro (default 398/290)
    2x256 corsair pc2100
    abit kr7a (ya i know its old as dirt, but im poor)
    maxtor 60gb
    samsung 172w (dvi-i) 1280x768@60hz
    all stock speeds ... air cooled ..
  10. :Galokin:
    :Galokin: Guest
    ya rock on, wot an amazing result...not :blah:
  11. micb
    micb Minimodder
    4 Sep 2002
    BIG Z put a ATI 9800 or PRO in you computer and you will be looking at 40,000+
  12. Tim S
    Tim S OG
    8 Nov 2001
    I know :D :D
  13. Flax
    Flax What's a Dremel?
    24 Jun 2002
    Ack! Whys my PC running so badly?
    http://arc.aquamark3.com/arc/arc_view.php?runID=106535743
    22535, my PCs an xp2800+ with a 9800 Pro, thats over 10000 less than similar PCs, with the same drivers too. And with my performance settings put to "looks like a donkeys ass" too. And a clean(ish) install of windows. GRRR.
  14. micb
    micb Minimodder
    4 Sep 2002
    Flax you have something odd there, both you CPU and Graphics card scores are running a fair bit slower than mine.
    You should be in the 35,000 - 40,000 Aquamark3 bracket.
    What ATI Drivers are you running?
    Have you got you "AGP Aperture" size set to 256 MB in "Advanced Chipset Features" in you BIOS?
    What motherboard do you have?
    Do you have the latest Hyperions AGP drivers?
  15. Flax
    24 Jun 2002
    Well, that seemed to fix it. Updated mobo and graphics drivers and set appature to 256MB and scores up to 39924 :) I also rememberd to turn off virus scan.
    http://arc.aquamark3.com/arc/arc_view.php?runID=140817008
    ---Old post
    Newish drivers, have newer on hdd but haven't got round to installing :D I'll do that in a bit and check the bios settings too.
    Hyperions are Via drivers, no? Chipset is nForce2 and semi up-to-date, but worth checking for new ones I guess.
  16. DarkRain
    DarkRain What's a Dremel?
    7 Jun 2003
    Well here's my effort so far 45788 all on air cooling.
    Might play a bit more and see what else i can get out of it
    Link to scores
  17. Hwulex
    Hwulex Minimodder
    1 Feb 2002
    Well that was painful.
    It got to the stage where I didn't have to rely on the program to tell me the fps, if you know what I mean. :sigh:
    Detailed Info: Here.
    Still, at least my GFX beat BigZ's by 9. ;)
  18. Tim S
    Tim S OG
    8 Nov 2001
    blah :waah:
    My graphics card is the win :D
  19. Enraged
    Enraged What's a Dremel?
    22 Apr 2003
    woooo 3700 and change.. wow this system sucks.
    Athlon 1.33
    512 pc2100 ram
    geforce2 mx 32mb
    ill have to see what the new system does:
    athlon xp 1700 (the overclockin freindly one, hoping for 2400 MHz)
    512 pc 3200 ram
    geforce fx 5200
    i might sell the 5200 and pick up a radeon 9600 pro after looking at the HL2 scores the FX 5200 does...
  20. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    i so need a new graphics card :(
    edit:
    doh forgot specs :D
    2500+ @ 2.3gig (205x11.5)
    4200 128mb @292/576
