Reply
Thread Tools View Mode
Old 26th Sep 2008, 00:46   #1
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Watercooling a Jetway C7??? -Finished and tested-
This will be a quick little log. Most of you know I've been teasing JHanlon about watercooling one of his Via powered systems. Recently, he he said, "YOU do it!"
-That's right. All my prodding backfired, and I'm forced to figure out how to do it for him.
-I got this little care package from him recently. I've known some Colorado-folk, so...
-On go the safety goggles.
-BOOM!
Well, that was a good idea. The box was literally stuffed.
-Inside was 2 Via POS boards, a slimline optical, PCI risers, a usb card reader, a usb extension...
-a 1 gig micro card and an antique laptop HD...
-2 mini ITX psu's...
-Payment?
-and a factory sealed Jetway 1Ghz with a gig of ram.
-The plan is to replace the heatsinks, (even the passive northbridge one,) and make waterblocks for this. When I get a working result, I will ship the blocks to John.
-Yeah...crazy.
I got the board running and figured out that the system is running at about 1 degree above room temperature. It's going to be hard to top that.
-First off, I popped off the northbridge block. I'm in luck. The 2 chips are the same height. The memory slot riser worked as a nice leverage point for a screwdriver.
-Oh, d*mn! That's tiny! The main chip has potential to rock. (John, You will need to keep the little washers under the heatsink.)
-I knocked out the back bracket with a mechanical pencil, and used it as a cutting guide.
-The old fan for anyone who cares...
-I got the blanks cut, then hurricane Ike hit. I was forced to hand turn the drill press by flashlight.
-This is the first part of the CPU block. It's two layers of clear plexi glued together with the bonding surfaces stained with purple marker. I will be adding a third layer for the gasket area later.
-I needed a way to tap the holes perfectly straight. Everyone has a cheap socket extension that snapped in half on them. I just found a use for it. The 12 point 1/2" socket is a perfect fit for the tap.
-The whole rig fits nicely in the drill press. Please forgive the blurry pics. -no power, etc...
-The test fit with a Danger Den self-sealing barb.
-The parts from McMaster showed up. I'm using 1/8" copper, and I'm going to try to make some O-ring seals.
-The power came back on last night, so I got a little milling done. I made a channel to get flow to the little hole in the middle of the O-ring.
...And that's where I'm at. I'm going to go into a lot of details because this is doubling as an installation manual.
Wish me luck!
Cheapskate is offline   Reply With Quote
Old 26th Sep 2008, 01:03   #2
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.
What kind of a modder turns a drill press by hand with only a flashlight?
A Bit-Tech.net modder!
No electricity for what 12-13 days? Props from Here!
Above and beyond.
John
__________________
My deepest gratitude to this community.
jhanlon303 is offline   Reply With Quote
Old 26th Sep 2008, 01:11   #3
Cheapskate
Cheapskate's Avatar
It was more out of boredom, honestly. You can only spend so long eating.
Old 26th Sep 2008, 03:14   #4
LooZypher
Huh!? What!?
LooZypher's Avatar
LooZypher has yet to learn the way of the Dremel
Heh
Very nice, very nice indeed.
__________________
ASUS P5E Deluxe. Core 2 Duo E6600@3200 Mhz. Corsair PC2 6400. Sapphire Ati Radeon 4780 1gb DDR5.
Corsair 1200AX
!!!Happy hour Every hour!!!
LooZypher is offline   Reply With Quote
Old 26th Sep 2008, 03:24   #5
Langer
Jesse Lang
Langer's Avatar
Langer has yet to learn the way of the DremelLanger has yet to learn the way of the Dremel
LOL, the flashlight hand tuning bit made me laugh...BRAVO mate.
__________________
project:HELIOS -- project:PROMETHEUSCU
Langer is offline   Reply With Quote
Old 26th Sep 2008, 03:53   #6
Darkraven
Multimodder
Darkraven's Avatar
Darkraven has yet to learn the way of the Dremel
Like the box explosion. Good sense of humor.
Darkraven is offline   Reply With Quote
Old 26th Sep 2008, 04:00   #7
Neji
Multimodder
Neji's Avatar
Neji has yet to learn the way of the Dremel
Super stuff. This is gonna be good.
Neji is offline   Reply With Quote
Old 26th Sep 2008, 09:33   #8
Burnout21
Is the daddy!
Burnout21's Avatar
Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.
full blown hurricane outside, and the only thing he can think of is a way to mod! LEGEND!
__________________
Project log Mocha70
Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2
Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
Burnout21 is online now   Reply With Quote
Old 26th Sep 2008, 09:40   #9
liratheal
Sharing is caring
liratheal's Avatar
liratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpitliratheal is almost as Godly as yodasarmpit
You, sir, lie!
Next you'll be saying you can only spend so long drinking.
On topic: You're banana's. Looks pretty, though.
__________________
Desktop: Asus Sabertooth X58, 12gb Corsair XMS3, i7 950, 2x XFX 6870 1gb's, Corsair 1kw
Laptop: Alienware M15x, 5730 1gb, 8gb DDR3, i5 520M, Samsung 830 256gb, Seagate Momentus XT 500gb
WHS: Gigabyte Z77-D3h, i3 2100, 16gb DDR3, 5xWD 1tb, 5x Seagate 1tb
I game, Do you?
liratheal is offline   Reply With Quote
Old 26th Sep 2008, 09:57   #10
HeXeN
Straight from Hell
HeXeN's Avatar
HeXeN has yet to learn the way of the Dremel
I'm keeping my fingers crossed Cheapskate for this project :> so it's equal to keeping my eye on it and also keeping my rig in the cardBox
HeXeN is offline   Reply With Quote
Old 26th Sep 2008, 10:20   #11
Burnout21
Is the daddy!
Burnout21's Avatar
i think this system needs to be a phase changer, watercooling isn't enough for that beast! lol!
__________________
Project log Mocha70
Old 26th Sep 2008, 14:10   #12
Cheapskate
Cheapskate's Avatar
Thanks everyone.
@ Burnout - I saved the modding for after the storm. I slept through the actual hurricane. It seemed real weak compared to Alicia, which was like someone was sprayinging the house with a fire hose.
I will save phase change for a pico board.
@ Liratheal - Drinking seemed to be everyone else's only pastime. Someone ran over our garbage can. Ice and cheap beer was the only thing the stores were stocking at first.
Old 26th Sep 2008, 18:26   #13
jhanlon303
jhanlon303's Avatar
Block LOOKS small in the vise. What size barbs are those?
John
__________________
Old 27th Sep 2008, 02:36   #14
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for president
Hand turning a drill press by flashlight. Thats passion in action!
mnpctech is offline   Reply With Quote
Old 27th Sep 2008, 02:49   #15
jhanlon303
jhanlon303's Avatar
I keep getting this visual of Cheaps with a flashlight in the mouth turning the drill press with both hands and mumbling bad words about weather and people from Colorado.
John
__________________
Old 27th Sep 2008, 04:17   #16
KayinBlack
I Endure
KayinBlack's Avatar
KayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for president
Damn. Got me beat.
Course, with no Dremel...
Well, I'll just have to post these blocks when I finish them...
__________________
I don't feed the trolls...
Quit chopping up the locals to make tools.-Cheapskate
KayinBlack is offline   Reply With Quote
Old 27th Sep 2008, 05:20   #17
Spillers_909
What's a Dremel?
Spillers_909 has yet to learn the way of the Dremel
Anyone who turns the drill by hand because the power went out wins my vote for being a true modder.
Spillers_909 is offline   Reply With Quote
Old 27th Sep 2008, 08:43   #18
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
This is a really cool idea. Looking forward to seeing how it all turns out.
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 27th Sep 2008, 10:20   #19
DaveVader
Fast Action Response Team
DaveVader's Avatar
DaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run CrysisDaveVader can run Crysis
haha, top notch mod! Real commitment and a good sense of humour (by all).
Can't wait to see how it turns out.
__________________
Current Rig: Gigabyte EP45 DS3L | E8400 | 4*1GB PC6400 | GTX 560Ti | 80GB Seagate/2*1TB Samsung F1/1TB WD Element
Origin name: Schizomida
DaveVader is offline   Reply With Quote
Old 27th Sep 2008, 14:56   #20
Cheapskate
Cheapskate's Avatar
Thanks everyone.
@John - That's a 3/8" barb. This block is just a hair under two inches. I still have to cut the excess material off.
- I don't hold tools in my mouth!! The flashlight has been behind a few toilets, and I bet the other tools taste terrible. I only needed the flashlight to line up the bit, or test fit the tap progress. A more accurate image would be me stopping the turning, grabbing my flashlight, and saying, "OK, what did I just do?"
@Kayinblack - Let me be the test monkey. Later you can do it right.
Reply
Tags
scratch build
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
