Reply
Thread Tools View Mode
Old 15th Jun 2011, 06:40   #161
transparentK
What's a Dremel?
transparentK has yet to learn the way of the Dremel
THANKS SO MUCH MAN, I finally got everything off except for the back cover. it seems like its the only thing left keeping the "skeleton" together. Do you know how to get it off? ive removed all visible screws but it seems like its stuck on something right around where the lowest pci clip thing is. (yes i unlocked all the clips). thanks again!
transparentK is offline   Reply With Quote
Old 15th Jun 2011, 08:41   #162
MrBean
Supermodder
MrBean has yet to learn the way of the DremelMrBean has yet to learn the way of the Dremel
I am currently travelling, so unable to look - once again though, I think there are one or two screws below the PCI slots or PSU bracket - you might have to remove the PSU bracket at the back to get to those.
I can check on Friday though, will be back home in the afternoon - I guess that's Thu night your time....
MrBean is offline   Reply With Quote
Old 16th Jun 2011, 00:06   #163
MrBean
Supermodder
Good morning from NSW, Australia everyone
You know what the worst part about modding is - those times you cannot get to it if you want to! My Wife has just informed me UPS has delivered my new Koolance dual-DDC reservoir, and a few other goodies, and of course, I will only be back home tomorrow night Blegh....
Oh well, at least I have lots to do on Saturday, I hope my tubing from GAMMODS will arrive in time. Should have enough left over to finish off things though, so check back for an exciting watercooling-redo update!
I have also ordered a bunch of goodies from our friends over at MDPC-X in the EU, and this parcel too have been posted, but this will take a little longer to arrive. Should have it by next wekeend though, then I can finalise the sleeving and few remaining items.
Will keep you posted.
Old 16th Jun 2011, 00:19   #164
KayinBlack
Toxophile
KayinBlack's Avatar
KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.
I know the feeling-mine comes in tomorrow-I had to grab one too, after the EK debacle.
KayinBlack is offline   Reply With Quote
Old 16th Jun 2011, 12:12   #165
MrBean
Supermodder
Yeah, that's another story - I have 2 of those 5970 EK nickel blocks, one each on my and the Wife's systems.....
Old 19th Jun 2011, 04:58   #166
MrBean
Supermodder
Hello Everyone,
A small update -> Some of my goodies was delivered on Thursday, so I am posting a few pics of this. I am still awaiting my tubing, and this will most likely only be delivered on Monday
I have also decided to pick up 2x new V3.2 DDC's from PC Case Gear in Melbourne, so hopefully those I will have on Tuesday.
I will then remove and keep the dual V3.2's, mounted to the Dual Watercool Top, and doing duty in my PC currently. I will also get a few new fans from this supplier - so, hoping my MDPC-X package will also arrive end of this coming week (Nils did a great effort of shipping this very speedily, thanx Mate!), I will have a very good modding weekend, as I would like to sleeve pump-cables, new Fan-cables, PSU et al.
Easier to do this all at once, so please check big update during the week, and next weekend.
I am also awaiting 2x of the SmartGLCD boards, they were delayed for over 6 weeks, but DHL should deliver them either tomorrow of Tuesday - andat least 1 will find it's way into this mod......pending it's physical size.
But, enough babble, herewith a few pics of the goodies that came in this past Tuesday.....
My new Koolance RP-401X2 reservoir, from all possible angles - please note that this will be fitted with 2x new DDC 3.25 pumps - in the photos, a blanking plate is visible where one pump must go. Once I have the new pumps, hopefully tomorrow night, I will post a few pics of it assembled.
This setup will, however, work really well with this mod, and thanx to Koolance for the beautiful, yet very functional, design
and a last one
Herewith the pretty nice bit of tubing that will allow running both pumps in series, as well as the bit that goes in the fron to 'link' the 2x reservoirs together - by default this reservoir comes setup in dual-loop, i.e. parallel configuration, I will be running single-loop serial-mode though.
Also visible is a nice Koolance TMS-18 flowmeter that will be connected to the TMS-200 controller board....
and
Old 19th Jun 2011, 05:06   #167
MrBean
Supermodder
and a quick few of the Koolance TMS-200 controller and optional daughterboard, which will allow automatic control of both pumps, various temperatures, and in my case, due to serial-mode operation of 2x DDC pumps, a single flowmeter.
This should give some protection to the system in case of pump-failure, althouh I am running punmps in series for redundancy anyway. Overkill, most likely, but nice and fancy.
and back-side PCB's
and the bits and pieces that came with the main controller - mine will be mounted in a PCI slot, as the 5.25" drive-bay will be accommodating the Koolance Reservoir.....there are more sensors and cables that came with the optional daughterboard, but no need to post a pic of them, hehe - we all know what cables and sensors look like....
Old 19th Jun 2011, 05:07   #168
MrBean
Supermodder
Placeholder
Old 19th Jun 2011, 05:13   #169
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
That is quite a fancy reservoir, I like it. I was looking at those Koolance control units at one stage as well, they look pretty reliable. One of my friends has just become a Koolance supplier so I may take a look what he has on offer.
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 19th Jun 2011, 05:19   #170
MrBean
Supermodder
Yeah, I have the mCubed bigNG too, but although a nicely designed, compact unit, it lacks software updates - sad - but it seems the TMS-200 is going the same way, but at least the code (although it being VB6) is available......
Let me know your friend's url, please, once his store is up and running.....
But you're right, the res is pretty seksi - but I won't see any of it, ok, maybe if we peek behind the drive-bay lid/cover on the front of the BB case......I simply got it due to it's extremely practical nature....
Old 19th Jun 2011, 05:43   #171
The boy 4rm oz
Project: Elegant-Li
I'll PM you his url.
__________________
Old 19th Jun 2011, 06:11   #172
MrBean
Supermodder
Thanx Mate, appreciated
Old 19th Jun 2011, 06:20   #173
MrBean
Supermodder
Just ordered 2x DDC V3.25 Pumps too, and will pick them up from the supplier tomorrow.
Nice, tomorrow evening I will assemble the reservoir
Old 19th Jun 2011, 07:00   #174
The boy 4rm oz
Project: Elegant-Li
They are a good pump, I have one of the 18w ones (yet to use it but have tested it), extremely quiet, more so than a D5.
__________________
Old 19th Jun 2011, 07:25   #175
MrBean
Supermodder
Yep, I have 2x 3.2's, and an older MCP350 too.....just thought a good time to get the newer 3.25's......
This way I can keep my rig running over the next few days while assembling the reservoir et al....
Old 19th Jun 2011, 09:19   #176
Evenge
Hypermodder
Evenge's Avatar
Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.Evenge is the Cheesecake. Relix smiles down upon them.
Nice to see this project is alive!
__________________
Projects: Discovery | Strobe
i5 2500K - 8GB - GTX570 - Win 7 - Ducky G2pro TKL Special Tactile Mix
Evenge is offline   Reply With Quote
Old 19th Jun 2011, 10:32   #177
MrBean
Supermodder
Me too :rofl:
About time I got this going again!
Old 20th Jun 2011, 13:55   #178
MrBean
Supermodder
Hello Everyone,
Just picked up 2x new Laing DDC 3.25's, as well as 4x NB-Multiframe M12-P's this afternoon.
Had a lot to do for my real job, already 23h00 and not yet finished with everything, so I will start with fitting pumps to the Koolance-res tomorrow evening, when I will post pics of the new toys to.
Check back then, and ideas/feedback/critisism et al, as always, appreciated.
Best regards,
mrbean
Old 20th Jun 2011, 14:55   #179
Razer2007
Building Proxima
Razer2007's Avatar
Razer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the Dremel
Hey MrBean, dit lyk goed man!
Looks like a nice case to mod. Just like a G5.
__________________
Proxima - MOTM Feb 2012 Winner
CAGE - MOTM Sept 2010 Winner
Razer2007 is offline   Reply With Quote
Old 21st Jun 2011, 00:56   #180
MrBean
Supermodder
Dankie Razer, goed om van jou te hoor
I am really embarressed about the G5-casemod not progressing, gotta get back to that one soon. Will start with it once this mod is complete, but so much going on at work, I don't always have the time for modding - just extremely busy
But, that's life.
Enjoy CT, and look forward hearing from you again!
Reply
Tags
case mod
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
