#141 |
Hypermodder
Still loving my front row seats here
!Keep on going
#142 |
Supermodder
Just one simple word NICE. Keep up modding
#143 | ||
Ultimate Modder
![]() Quote:
![]() Enjoy the front row bro, I ll do my best for you to do so! ![]() Thanks brother, much appreciated!
#144 |
Ultimate Modder
Also Merry Xmas to all my friends here from the bottom of my heart, I want you to know that each comment I receive here is precious you are all in my heart and I wish you all the best but above all, health and love in your lives! God bless!
#145 |
Music Enthusiast
Just awesome bro! Such great craftmanship!
Hope you have a Fantastic Christmas rest those hands ready for a New year of modding! -DP
__________________
deadp1xels@yahoo.co.uk |
#146 |
Ultimate Modder
Thanks buddy for your wishes and your awesome comments, the best to come for you too!!!
#147 |
Carbon Fiber King
Congrats on the nomination! Well Deserved!
#148 |
Ultimate Modder
Thanks brother!
#149 |
Building Proxima
I had to catch up on a few updates here, and everything looks super duper awesome! And congrats on MOTY nomination, but I didn't even think that you wouldn't be there.
__________________
Proxima - The log of Dreams
CAGE - MOTM September 2010 Winner ------------------------------------------------------ LOSIAS.net Losias.net Facebook :: Losias.net Twitter |
#150 |
Ultimate Modder
Thanks bro, nice to hear from you again, I will be back soon with a new update
#151 |
Ultimate Modder
Time for the last update of this year guys!
I did some work on the first compartment of this mod as you will see. I had to find a way to use acrylic in order to attach the bezel and back on the bottom part. I didnt want to use plain angles for "art" reasons and also for extra durability. So I created my own -more sturdy- angle by bending and somehow sculpting a piece of white acrylic. It took me 2 hours to create this piece! Here is how it looked like first. ![]() And after bending - sculpting (with various dremel bits) ![]() ![]() By using some epoxy glue I attached this piece on the bezel. ![]() While I was waiting for the glue to dry I decided to fix the window mocks so they will give an extra 5mm space to hide and attach behind the panel. ![]() ![]() ![]() Then I bended some acrylic to angles and also did the second piece which is going to hold the back piece of the case. ![]() ![]() Some cutting, sanding, filing! ![]() ![]() ![]() By using epoxy again I glued-attached the bezel on the bottom part! ![]() And also attached the second piece the same way. Screws will be used for extra stability/durability. ![]() ![]() Drilled some holes for the screws to pass through . ![]() Attached the back part too! ![]() Time to slowly start building the side panel. First test fit the side panel's supporter. ![]() Here is the wood pieces I am going to use! These are only the half of them! ![]() Cut to exact size and also smaller. ![]() Attaching the first pieces with some universal glue. This is a very slow process as I have to wait around 5 minutes or more for each piece! ![]() ![]() Turned the panel upside down and also start working on the top part as it will be not filled with wood. I will add later 1mm acrylic more designs etc. ![]() ![]() Half way through the first panel. More to follow around 5 January. ![]() I also noticed after more than one month that the motherboard i/o part of the motherboard is reversed due to my mistake on the original design! Now I have to disassemble the whole thing and order a new one!!! OMG! Thanks for reading my worklog guys, I wish you all the best for the year to come but above all health, love and consciousness in your lives! Till next time, peace! |
#152 |
Building Proxima
![]() yayy update! Looks good. keep the pace. such a pity about the mistake. Such things happen though. good bending skill. I'll buy me a heat gun some time. Looks lik a handy thing.
__________________
#153 |
Ultimate Modder
Thanks bro, indeed is very handy though I bought it for sleeving I use it now and for bending. Before that I used a torch which served me really well for a long time.
#154 |
Hypermodder
Verry nice update
#155 |
Building Proxima
oh man I use a lighter for heatshrinking. Theres just too much thing to buy and not enough money.
__________________
#156 |
Ultimate Modder
Thanks bro!
#157 |
Music Enthusiast
Man thats looking cool!!!
__________________
#158 |
Ultimate Modder
Yeah Razer man, always so many things and tools to buy! I used to save money and buy a tool every 2 months until I got the basics!
#159 |
Ultimate Modder
Thanks DP!
#160 |
Keep calm & mod on. =)
So is the pci/io supposed to be facing upwards?, if so then gutted more expense
looking good though mate & like the shape of this a lot Nice connetors too
__________________
Air Cube v2 and gaming tower (Fin Aug 2010) Stealthlow (Fin Sep 2011) Lean & Green - Modular Dual PC Paused Midlag Crisis Last edited by Waynio; 28th Dec 2010 at 19:30. Reason: Nice connetors too :thumb:. |
| Tags |
| awesome, plexi |
| Thread Tools | |
| View Mode | |
