Old 21st Mar 2011, 15:13   #121
HourBeforeDawn
a.k.a KazeModz
HourBeforeDawn has yet to learn the way of the DremelHourBeforeDawn has yet to learn the way of the Dremel
wow that cpu block overall looks fantastic but feels like its still missing something visually.
__________________
Current Rig: Project STEALTH
DimasTech Test Bench Black ICE Triple 120 Rad Dual Bay Res/Pump DD Fill Port & Res D-Tek FuZion 2 CPU Block ASUS M3A79-T Deluxe Mobo AMD Phenom II 3ghz @ 4ghz 8gb DDR2-1100 Memory (2) AMD 6870 XFire (2) WD Black 640gb Raid 0 (2) 1.5TB SEAGATE Blu-Ray/HD DVD Drive ASUS XONAR DX2 30" DOUBLESIGHT LCD (2) 23" ASUS LCD ZALMAN 8 FAN CONTROLLER (4) NOCTUA P12 (2) NOCTUA P14 1000W ZALMAN PSU WINDOWS 7 PRO 64
HourBeforeDawn is offline   Reply With Quote
Old 21st Mar 2011, 15:32   #122
Gtek
Doesn't raise the bar; he IS the bar.
Gtek's Avatar
Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.Gtek is a hoopy frood who really knows where their towel is.
nice and clean blocks like made for me
__________________
Gtek is offline   Reply With Quote
Old 21st Mar 2011, 16:19   #123
CMos
Minimodder
CMos has yet to learn the way of the Dremel
Very nice block but I feel it could do with some engraving
CMos is offline   Reply With Quote
Old 21st Mar 2011, 16:29   #124
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
So this is what happens when Attila takes a shot at water cooling, I absolutely love it 100% awesome .
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Waynio is offline   Reply With Quote
Old 21st Mar 2011, 16:41   #125
Razer2007
Building Proxima
Razer2007's Avatar
Razer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the Dremel
Can't handle that much cheesecake... head will explode...
__________________
Proxima - MOTM Feb 2012 Winner
CAGE - MOTM Sept 2010 Winner
Razer2007 is offline   Reply With Quote
Old 21st Mar 2011, 16:42   #126
Shadow703793
Supermodder
Shadow703793 has yet to learn the way of the DremelShadow703793 has yet to learn the way of the Dremel
You are going with a Al + Copper loop? I assume you will be using 50/50 mix then?
Personally, I think you should have gone with a full Al loop. Your temps will be a bit worse, but you won't have problems with mixed metals at the blocks. However, you will still have problems with the rads.
Shadow703793 is offline   Reply With Quote
Old 21st Mar 2011, 18:17   #127
KidMod-Southpaw
KidMod-Southpaw's Avatar
KidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming SaiyanKidMod-Southpaw is a Super Spamming Saiyan
Beautiful block- it's a fantastic idea to have it go behind the board! One of the best works I've ever seen! Rep.
__________________
Project Logs: Refraction - Steampunk Flash Drive - Steel; Sleek; Slate
BitFenix Prodigy - Gigabyte Z87N - Intel 4670K - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - M4 128GB - WD Red 1TB X2 - H60 - Antec 650W - Dell U2312HM - Poker MX Red - Sennheiser HD 598
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 21st Mar 2011, 19:54   #128
HourBeforeDawn
a.k.a KazeModz
you can get your hands on an all aluminum rad, not really designed originally for PC use but with some slight mods which Im sure he can handle you can use it for such. I used a Outlaw race kart aluminum rad once for a build project
__________________
Old 21st Mar 2011, 22:24   #129
Shadow703793
Supermodder
Good point. You could probably find full aluminum car rads,etc.
Old 22nd Mar 2011, 01:00   #130
GCOFIELDD
Multimodder
GCOFIELDD's Avatar
GCOFIELDD has yet to learn the way of the Dremel
When I saw update number 2 one word came to mind "YAY!"
GCOFIELDD is offline   Reply With Quote
Old 22nd Mar 2011, 01:20   #131
KayinBlack
Toxophile
KayinBlack's Avatar
KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.
If you were closer I have a Koolance 4x120 rad with shroud that's all AL. In fact, for shipping it's yours if you want it. We get home tomorrow, I'll find it a box.
KayinBlack is offline   Reply With Quote
Old 22nd Mar 2011, 02:25   #132
wahoomcdaniel
Multimodder
wahoomcdaniel has yet to learn the way of the Dremel
Not wishing to state the obvious, but... the mixed metal debate isn't ending Attila.
Surrender the cooling system to one or the other may be the only viable option.
wahoomcdaniel is offline   Reply With Quote
Old 22nd Mar 2011, 02:53   #133
Attila
still thinking....
Attila's Avatar
Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.
Thanks for the replies and thanks for the concern at the haphazard way I've approached this. And Kayin, thanks a lot for the offer of the rad, that's very generous of you.
You know I've never really been a fan of water cooling but I do like a challenge, and this is certainly a challenge. I really wanted to see if I could build a w/c system, just once, and build it my way. When ever I start thinking of something, a picture forms in my mind, a picture of how it will all look and work, of the materials I will use, colours, finishes even how I can make the parts. This picture is very hard to shake. The blocks have to be anodised alu. They just have to, that's all there is to it, I need to make this work. The only reason I've become attached to the copper bottoms is from the experience of 'working' the metal. This stuff is very different from the alu I'm so accustomed to. Sure it's more difficult to work but it's what I noticed when cutting and filing that won me over (as far as a material for cooling). When I cut or file or drill alu, the work piece and the tool become hot, but when working with copper, the piece got hot but the tool stayed cool. It appeared to me that the copper was like a heat 'magnet', sucking the heat away from the tool, I imagined that sitting on top of a processor, the copper would 'suck' the heat out and pass it on quickly to the flowing liquid to be removed. But if I want to keep the alu blocks then the copper will have to go. Not only that but the brass radiator will have to go as well. In this scenario the only small problems will be the nickel plated fittings. Now nickel is even further away from alu than copper on the galvanic scale, but because the ratio of alu to nickel will be so great (alu blocks, water channels, radiator), that with some finely tuned anti-corrosives, the system should have a long working life. Oh, and I wont be using 'anti freeze' or anything with ethylene glycol.
The other problem may be the efficiency of the bottoms. But these will be easy to remake and fit if they need to be (because of really bad cooling) down the track.
Now if (dreaming again) I had a mill right here, then I would simply make the entire block from copper and mill a chunky alu 'sleeve' to cover it. But too much time and effort has been expended making what I have and I don't have the will to do it all again.
Now if you'll excuse me, I need to PM Kayin.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 22nd Mar 2011, 03:05   #134
awratten
What's a Dremel?
awratten has yet to learn the way of the Dremel
I think everyone is over thinking this whole galvanic corrosion deal.
Inside a computer cooling system is a very controlled environment. ie. no external unpredictable scenario's to contend with.
if you look at the" Anodic Index" of Aluminium and Copper, and work out the galvanic difference it's only 0.55 Volts, which is almost with the allowable tolerances (0.5Volts diff). with a reduced conductivity agent in the coolant this would be no problem at all.
And he's going to Anodize the Blocks!! as long as it's both inside and out, I see no problems with the setup that Attila has.
if all the aluminium is anodized then brass, nickel and copper are all that's left in the mix and they have very close galvanic index's, with only a 0.1volt spread. No problem as I see it.
PS. Great Work with the blocks by the way, they look really good.
awratten is offline   Reply With Quote
Old 22nd Mar 2011, 03:52   #135
KayinBlack
Toxophile
KayinBlack's Avatar
The only problem with that is that anodizing is tough to get to stick on complex surfaces.
If you want to use copper bases, get them electroless nickel plated. You shouldn't have any issues then.
Old 22nd Mar 2011, 04:19   #136
Shadow703793
Supermodder
Actually, it's not an over blown issue. Some people have run mixed metal loops pretty fine for months with out many issues. However, there have been quite a few people that this:
Source for the pics:
http://forums.koolance.com/viewtopic.php?f=5&t=207
http://www.xtremesystems.org/forums/...d.php?t=203601
Koolance was notorious for this problem. This is why I STILL don't buy Koolance stuff.
As you can see, it's not really a minor issue. Go through XS threads and you will find plenty of corrosion stories + pics,etc.
edit: How the hell do I re-size images so they appear at 800*600 in the Forums? I'd rather not do this manually if it is possible....
Old 22nd Mar 2011, 04:24   #137
KayinBlack
Toxophile
KayinBlack's Avatar
Those blocks used a sacrificial layer of zinc in between the aluminum and an outer coating of nickel. With bare copper, the zinc was a sacrificial anode, and actually caused the aluminum to corrode faster.
The better choice would have been in that case a delrin top and a nickel plated base. Nickel is pretty noble, so it's tough to provoke a reaction from it.
While the GTX case was a severe one, I've actually seen far worse than that. It all depends on loop chemistry, specific processes used in manufacturing and if you held your mouth right while you put it together.
Also, that center pic is from the rusting steel Koolance fittings that were pulled from the market. Koolance cleaned up its act, enough that I'd rather recommend them over EK right now.
Old 22nd Mar 2011, 05:08   #138
Achron
Cad Pro Quo
Achron's Avatar
Achron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the Dremel
I don't care how long people have been running loops with mixed metals. At one point or another, physics will win. And when it wins, it will kick your ass. Anodizing isn't always thorough, things get worm down and chipped, etc.
Mixed metal + water = bad.
On a fun note, you're like a damn factory. Don't you ever take a break?
__________________
Completed: Acronym
Achron is offline   Reply With Quote
Old 22nd Mar 2011, 06:40   #139
Nutman
Never stuck with stock
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Even factories need a break now and then - this guy is much more persistent. He must be an alien. Or an unstoppable hun.
__________________
Best regards, Nutman
Projects: Nutman - Hampen - F.O.B. T.C. - BabyShark - The Scratchbench
Nutman is offline   Reply With Quote
Old 22nd Mar 2011, 08:54   #140
Attila
still thinking....
Attila's Avatar
I've seen those pictures before, and worse! I'm not concerned about the corrosion likely to occur in the blocks or water channels, The feature sizes here are very large and the material very thick.
My main worry was inside the radiator where the channels are small and the material very thin. Corrosion in the system could lead to blockages here and after time, even perforation of the thin walls here. I still need to read up on which metal in a mixed metal system will suffer the most deterioration. If anyone knows this please reply before I ditch my rad.
Anyway, life goes on. I had about an hour spare today, so a start was made on the GPU block. This time I will do this a bit differently by drilling a bunch of holes. This will make routing the channels a lot easier.
It got a little messy.
And ready for routing tomorrow, if I have time.
I should be able to remove a fair bit of the bulk of this towards to front (top of the case) so I need to think of a design that can make this part look a little better.
__________________
stillthinking
Reply
Tags
aluminium, oldnewby
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
