Reply
Thread Tools View Mode
Old 1st Sep 2011, 20:36   #1
dmcgrath
Master of Pancakes
dmcgrath's Avatar
dmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremeldmcgrath has yet to learn the way of the Dremel
AzTtec - Added Keyboard and Mouse - Completed!
rocks for sponsoring this case contest I had the honor of participating in.
It's going on over at http://www.modders-inc.com if you want to check out the other competitors.
My idea was to make a Mayan themed case.
I'm sorry if my Mayan/Aztec/Olmec references may get mashed together at points. I'm busy studying the various points of all of them and I'll try not to mess that up. But for all intents and purposes it should be classified as Mayan based since the HUGE calendar is going to be on the one side.
Some of the ideas are really straightforward, stone textured/colored. Moss in the cracks and vines and what not.
Some of this stuff I can get at a local train/plane/miniatures type hobby shop. I will have to go with a Balsa foam sculpting medium that I really like the idea of. It will easily translate into looking like a stone material, and be light as heck. The glue and the paint on it will probably end up weighing more than the material itself.
I will probably omit the window in the side since glass wasn't around...
Unless I can make it some kind of a cave/mouth/opening. That will have to come when I get the case in my face.
Like I mentioned on my original submission, the release for the door may be somewhat modified from my drawing. I may just make it part of the ruins and make it accessible to a finger to press on it.
I think the key areas may be easily hidden behind some special "stone" that is removable, maybe with an embedded magnet to keep them in place.
I do still want to wholly contain this rig's functionality/versatility by keeping the front slots, perhaps modifying the location of some of the buttons or omitting them as needed is all. And I think having the headphone hanger still available but a large sculpted item would also be a nice touch.
Pros,Cons,input all accepted!
Quick links to progress below.
1 - Working with Balsa Foam for the first time. And my tools used.
2 - Getting better at carving this Aztec Calendar thing.
3 - Aztec calendar finished.
4 - Adding bits of foam to other places and making it all fit together.
5 - Oh boy, is this stuff MESSY!
6 - Carving the front of the case.
7 - More front detail carving.
8 - Making the removable HDD area better.
9 - AzTtec is named.
10 - Detail finishes on the door side.
11 - Toenails and details.
12 - Painting begins in earnest.
13 - Dry brushing and creating the vines.
14 - More detail shots, and packaging.
15 - Final Pics, and Hi-Res downloads. Page 7
16 - Started the Keyboard and Mouse, PLUS, secure packaging a 40 pound object for shipping.
17 - The Foam Hardener I always wanted as a child, and some carving.
18 - Final carving, and paint, off to CES Vegas! Page 9
Thanks for looking.
Last edited by dmcgrath; 1st Jan 2012 at 01:43. Reason: Edited - title and content.
dmcgrath is offline   Reply With Quote
Old 3rd Sep 2011, 07:15   #2
dmcgrath
Master of Pancakes
dmcgrath's Avatar
I'll post an abridged version, no need to repost everything I've done, maybe you guys get the highlight reel.
I did a little Mayan man/chief and added some fun to him, a pair of headphones and a game controller.
I had to redo a transfer, kinda easy to redo, just lightly sand off the old one.
Lots of detail. LOTS.
And several days later, more details, just taking every carving line and having to bevel the edges takes a decent amount of time. Then there are several altitudes I'm working within the object as well, trying not to mess it up as I go along.
There's more to it than just cutting away what I don't want. Sometimes I have to work at different depths, and with different textural styles. But mostly I just scratch away, a millimeter at a time.
The dust gets everywhere, I do wear a particle mask most of the time though.
Since I can't blow the dust off the object, and I can't use a paintbrush most of the time to dust either (it will wipe away the transfer marks I haven't etched yet), I use our kid's booger sucker bulb from when she was an infant. It's got a new life, and I'm so very glad I never threw it away!
Here's a side by side comparison of the level of detail I have achieved with the one on the left, vs. the etched one on the right.
And a close up, I love cheap macro extensions for SLR's
Thanks for looking!
Old 3rd Sep 2011, 10:19   #3
Fuganater
Supermodder
Fuganater's Avatar
Fuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run Crysis
OMFG!!!!!!!!!!!
That's all done by hand??
Fuganater is offline   Reply With Quote
Old 3rd Sep 2011, 13:36   #4
O_Pucaro
Multimodder
O_Pucaro's Avatar
O_Pucaro has yet to learn the way of the Dremel
amazing , the best thing i have ever see
O_Pucaro is offline   Reply With Quote
Old 3rd Sep 2011, 15:05   #5
Razer2007
Building Proxima
Razer2007's Avatar
Razer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the DremelRazer2007 has yet to learn the way of the Dremel
WOW! How are you going to make it hard?
__________________
Razer2007 is offline   Reply With Quote
Old 4th Sep 2011, 03:36   #6
barry99705
sudo rm -Rf /
barry99705's Avatar
barry99705 has yet to learn the way of the Dremelbarry99705 has yet to learn the way of the Dremelbarry99705 has yet to learn the way of the Dremelbarry99705 has yet to learn the way of the Dremel
Sooooo many ways this could go.....
__________________
I always wanted to have that ideal father son relationship. You know, where I get to see him for like eight hours every other weekend, and send checks to some woman I hate. -- Tucker, Red vs. Blue
barry99705 is offline   Reply With Quote
Old 4th Sep 2011, 03:45   #7
KayinBlack
I Endure
KayinBlack's Avatar
KayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for presidentKayinBlack should be considered for president
Now you make me wanna do a Mayan themed rig. Sweet...
KayinBlack is offline   Reply With Quote
Old 5th Sep 2011, 02:41   #8
dmcgrath
Master of Pancakes
dmcgrath's Avatar
Thanks for the kinds words everyone, here's a little bit more detail.
@ barry HAHAHA!!!!
It's actually a pretty tough material as it sits. I have been thinking about it's portability and longevity, though.
I plan on painting it, and hopefullly that will add a pretty good level of toughness to it. As t sits now, you can bump it with your knee and not really do much, but if you hit it with something sharp it will mark up pretty well.
The next two "rings" finished. The little flower design things were pretty fast due to the repetitiveness of them. And the little animal sections, also kinda fun. I've got better at using a Dremel with just a sewing needle in there for a faster foam removal technique. It has sped me up a tiny bit, but also removes so little material at a time that it's hard to make noticeable mistakes.
On to the final part of the calendar. The Thermaltake logo (not only being a requirement) looks pretty good in there, don't you think?
Old 5th Sep 2011, 05:29   #9
mav2000
In Training
mav2000 has yet to learn the way of the Dremel
Very nice work and looks like something you have spent a lot of time and energy on....
mav2000 is offline   Reply With Quote
Old 6th Sep 2011, 23:51   #10
dmcgrath
Master of Pancakes
dmcgrath's Avatar
Okay! FINALLY done with that portion. Arguably the hardest part is over. I hope. The rest should be as good looking I hope, but not nearly so labor intensive on a single piece. At least... as far as I know.
The green stuff is putty, some of the joints were a bit farther away than I wanted and I kinda want to fill them up a tiny bit on the weaker areas. I'm sure after I get a base coat of paint on the job it may need some more touch-ups.
And a good close-up shot of the Tt logo. Which I'm very happy to say came out great, even the little ® turned out!
Old 7th Sep 2011, 00:35   #11
St3ph
Multimodder
St3ph has yet to learn the way of the Dremel
This is freaking awesome! I've seen so much great stuff here and this ranks high =O
St3ph is offline   Reply With Quote
Old 8th Sep 2011, 04:09   #12
supermonkey
Deal with it
supermonkey's Avatar
supermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpitsupermonkey is almost as Godly as yodasarmpit
I don't often visit the modding section, and I rarely comment on people's work logs. However, this is some of the best custom case work I've seen on Bit-tech in a long time. Your patience and skill in carving the panel is admirable. Well done!
__________________
But of bliss and of glad life there is little to be said, before it ends; as works fair and wonderful, while still they endure for eyes to see, are their own record, and only when they are in peril or broken for ever do they pass into song.
-J.R.R. Tolkien, The Silmarillion
supermonkey is offline   Reply With Quote
Old 8th Sep 2011, 07:22   #13
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run CrysisGuilleAcoustic can run Crysis
OH MY GOD !! Great skills mate What is this material you are carving ?
I'm a big fan of mythology and especially mayan one, I'll keep an eye or two on this thread (+rep)
GuilleAcoustic is offline   Reply With Quote
Old 8th Sep 2011, 07:24   #14
Attila
still thinking....
Attila's Avatar
Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.Attila is a hoopy frood who really knows where their towel is.
Holy crap dude! I just want to hang that on my wall. Terrific.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 8th Sep 2011, 18:01   #15
Tynecider
Since ZX81
Tynecider's Avatar
Tynecider is a hoopy frood who really knows where their towel is.Tynecider is a hoopy frood who really knows where their towel is.Tynecider is a hoopy frood who really knows where their towel is.Tynecider is a hoopy frood who really knows where their towel is.Tynecider is a hoopy frood who really knows where their towel is.Tynecider is a hoopy frood who really knows where their towel is.Tynecider is a hoopy frood who really knows where their towel is.Tynecider is a hoopy frood who really knows where their towel is.Tynecider is a hoopy frood who really knows where their towel is.Tynecider is a hoopy frood who really knows where their towel is.Tynecider is a hoopy frood who really knows where their towel is.
whoa, bloody impressive indeed.
__________________
Sent from Discovery One using HAL 9000
__________________________________________________ _________________
Rig under construction
Tynecider is offline   Reply With Quote
Old 9th Sep 2011, 02:13   #16
dmcgrath
Master of Pancakes
dmcgrath's Avatar
Wow, thanks for the comments, guys.
I'm using a material called Balsa Foam (type 2, it's tougher). The only drawback to this stuff really has been the dust. It's everywhere, haha. Before final paint I'll have to take it out and hose it down with a compressor for about an hour.
Old 10th Sep 2011, 17:55   #17
Tokari
Multimodder
Tokari's Avatar
Tokari has yet to learn the way of the Dremel
The attention to detail is unbelievable!
__________________
i5-2500k o/c to 4.5Ghz / Gigabyte GA-P67A-UD4 B3 / 8Gb Corsair RAM / Asus GTX 560 Ti DirectCU II o/c to 900Mhz / Titan Fenrir Evo / Corsair AX850
Tokari is offline   Reply With Quote
Old 12th Sep 2011, 14:06   #18
Zanib
Minimodder
Zanib's Avatar
Zanib has yet to learn the way of the Dremel
That is proper artwork right there! looking forward to seeing the end result
__________________
Core 2 Quad Q9950 OC @ 3.9GHz Watercooled, Armor+ Case, Asus Rampage Extreme, 4GB GSkill DDR3, Sapphire Radeon HD 5870, 2 x Samsung F1 1TB, x1 256 M4 SSD, Thermaltake 1200W, Alesis Studio speakers, Creative Titanium sound card, Asus MS238H 242 monitor
Zanib is offline   Reply With Quote
Old 12th Sep 2011, 16:03   #19
Guinevere
Mega mom
Guinevere's Avatar
Guinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpitGuinevere is almost as Godly as yodasarmpit
Another OMFG.
Please please please don't overdo the painting. It'd be a real shame to lose some of that detail beneath half a dozen coats of dulux.
Guinevere is offline   Reply With Quote
Old 13th Sep 2011, 14:31   #20
Sunny Sahota
Saving up for my new rig
Sunny Sahota's Avatar
Sunny Sahota has yet to learn the way of the Dremel
OMG!! That is extraordinary!!!!
Sunny Sahota is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
