#161 |
Squid
very very nice!
#164 |
Fenrir The Wolf
I admire your skills.
And your machines.
#165 |
Pump Killer
Heh!
Thanks man! ![]() Me and you both my friend! I'll try to keep it up on the next pieces! ![]() Thanks! Do you by any chance know anyone who has a vinylcutter? A company you can recommend or something? ![]() I admire the machines as well! I'm a lucky *******!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nomineeWII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
#166 |
↓ Don't trust that face!
Very lucky...
That's some delicious reservoir work. filling the logo with colored resin would take away the awesome implied bevel the toolpath left. -Wait, this is Angel... Is it a real bevel? Edit: Yep, real bevel. I'm blind and an idiot.
__________________
#167 |
8-bit addict
Awsome reservoir work.
That engraving looks sick. What feed/speed were you using? Also, the surface of the letters look like they are 3D, are they or is it just the direction of the milling that creates a "brushing" effect? Awsome whatsoever.
__________________
Project: ProtoHype (paused) Project: GET A LIFE (Complete) Project: Widescreen Projector(Complete) Guide: How to brush Aluminum |
#168 | ||
Pump Killer
![]() Nah... You're not really blind... ![]() Quote:
![]() It's 0.15mm deep, 8000 rpm, and the feed was only 400. I don't want more feed, as the tool is shaped as it is.
__________________
#169 |
Pump Killer
Btw. IF I ever receive the mail from Quiet Pc so I can choose the color of the case, it's going to be the white R3. I'll run dual loops, one red and one blue.
Just wanted to let you know so you can hate me already! ![]() Also, I plan to rotate the mobo 90 degrees, but I have to figure the real details out when/if I ever get the case. ![]() Uh, and I bought a PCI-E riser cable...
__________________
#170 |
Keep calm & mod on. =)
![]() ![]() Sounds awesome to me though Angel .Just noticed the secret of it not being 3d still looks like it though, awesome effect .
#171 | |
Pump Killer
![]() But thanks man! I saw a picture of a red/blue dual loop on a bench and it looked awesome! Also I received some fans from aquatuning that are red. That kind of sparked the idea! ![]() They don't come in blue, but I found some Asus ones that are, and they are almost identical in shape!
__________________
#172 | |
8-bit addict
__________________
#173 | |
Pump Killer
__________________
#174 |
Pump Killer
A small sidenote to start up! I wrote QuietPc.com yesterday, and right now my case and PSU are in transit to moi!
![]() This also means I gotta get a move on with this mod! So a bit more on the res boys and girls. As mentioned, I made a small mistake when drawing up the res itself which resulted in the top rings being milled wrong. Luckily it was a quick fix as I had taken off too little! ![]() The rings as they should be: ![]() Snug fit: ![]() First one put on: ![]() And the second put on: ![]() Tried it with the tops in: ![]() ![]() Just like I wanted it! ![]() I got started on the bottom piece as well, and milled the outline: ![]() And a small chamfer for Achron! (And a bit for me as well) : ![]() And that's it! I'm hoping to get a bit further this week, but you'll be the first to see the results!
__________________
#175 |
Modder
Instant "wahaaa....." feeling for the awesome milling! keep it up!
#176 |
Ahhh no more hold ups
, bound to be the best case mod of the one your getting .
#177 | |
gief cake?
Tell them that you were referred to them by HP sahl:P
__________________
#178 | |||
Pump Killer
![]() Quote:
And now I know what I'm going to spend my weekend with if I'm lucky enough to receive it before the weekend! ![]() I was actually going to clean out and throw out half of my stuff in my appartment so I would be more ready for moving, but there are more important things in life! ![]() Quote:
__________________
#179 |
The scratches on the res top look like neutrino patterns. Something like that would make a neat accent. You already have them neatly framed. Make it art.
![]() We've seen that at least HALF of your body was already hairless. I shudder to think where the hair you lost was from.
__________________
| Tags |
| 42, it's this mod! |
| Thread Tools | |
| View Mode | |
