Scratch Build – In Progress Project ZOE
Discussion in 'Project Logs' started by Zesti, 31 Oct 2011.
  1. Zesti
    Zesti Aluminium + file
    9 Feb 2010
    Hi all, been reading this forum for a long time, but now it's time to start my first project log here. ;)
    Project plan:
    - Compact LAN-party computer, volume about 22 liters
    - Scratch built from aluminum
    - Jet Age -inspired design
    Colors:
    - Exterior: Metallic red and black
    - Matt black / carbon fiber interior with a touch of red
    - Mostly black sleeving
    - White/red LEDs, indirect light
    Preliminary hardware specs:
    CPU: i7-3770K (Ivy Bridge)
    CPU cooler: Antec H2O Kühler 620
    MB: Asus Maximus IV Gene-Z/GEN3
    RAM: G.Skill Ripjaws Z 4x4GB 1600MHz
    GPU: ATI Radeon HD7xxx
    PSU: Silverstone Strider Plus 750W
    SSD: OCZ Vertex 3 120GB
    HDD: n/a
    ODD: n/a
    Fan controller: Aquaero 5 Pro with Aquaremote
    Others: MDPC-X sleeving, screws and connectors
    Umm, yeah. I'm buying most of the components later when case is closer to finishing. However, I've bought some parts that don't get old too fast. For example PSU is ordered and should arrive soon.
    And if someone is wondering where the name 'Project ZOE' comes, here's an explanation:
    I started to number my builds when I got more serius with this modding stuff.
    So my first build was Z01 'Vanilla'.
    Second build was Z02 'Embolado'.
    And this one is Z03 - hence the name ZOE.
    Ok, let's go ahead to The Good Part aka pictures. ;) First just some parts and then construction pics.
    First 16mm switch with white led ring. I'll be using one as a power switch and possibly a second one for reset.
    MDPC-X crimp contacts and 24pin housings. This build will have custom lenght cables since the case will be quite a compact. I think that for example GPU power cables should be like 20cm long. :lol:
    Aquaremote for Aquaero. Don't know if I really need it - I just had to get one. :brrr:
    And the Aquaero itself. Bought the Pro-version since I don't like the capacitive buttons on the XT.
    These are the tools of destruction:
    And now finally - Lets get started on the case itself. :)
    First part is cut from 5mm aluminum plate that I happened to have around.
    Then we need a new sheet of 3mm aluminum. (There's a protective film over it.)
    Didn't took any pictures while cutting because I think you all know how it looks like. ;)
    Anyway, here's a freshly cut part:
    And suddenly there was two of them!
    Sooo.. How will those go together?
    Ok, little bit of tape and lets hope it stays together long enough..
    Like that.
    Now those parts just need sanding etc.
    That's all for now. I'm hoping to get next update online soon. :)
    yassarikhan786 and Razer2007 like this.
  2. Fedmas
    Fedmas Leader of the casemod watchers :D
    29 Jan 2010
    Woah. Lookin'good. Good luck!
  3. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Great start and great pictures. That always draws my attention! Will be watching :)
  4. Cheapskate
    13 May 2007
    Jet age inspired? -First parts aren't a square box? I'm in!:clap: This should be cool.
  5. L1U
    L1U Minimodder
    1 Sep 2011
    good luck with your project, cant wait to see the HD7xxx fitted in there :D
    PS: you may want to resize your pictures a bit before posting
  6. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    Nice start mate and good luck :). Have you got project logs of your other builds on other forums, because I would like to see your other work :).
  7. Zesti
    9 Feb 2010
    Fedmas and Razer2007, thank you both. :)
    Cheapskate, haha, thanks. I like to think that 'why build another black box when you have freedom to do whatever you want'. ;)
    L1U, yeah, I'm eagerly waiting for new graphics cards generation. I just hope they aren't physically very long.. It'll be really annoying to fit 300mm card into this case. :rolleyes:
    And those pictures are already resized to 1000px wide which I think is a good compromise between details and screen resolutions. Hopefully it wont be huge problem for users with smaller screens since this forum can resize pictures pretty well. :)
    yassarikhan786, thank you. And sorry, this is in fact my first public project log anywhere.. :) I might make project log from my last mod (LiLi PC-8N modded to inverted ATX) since I'm thinking about making some changes into it. But we'll see about that later.
  8. Razer2007
    18 Jul 2010
    Are you editing pics in PS or something similar? When you save them you can reduce the quality a bit for smaller file sizes :) That might help some people.
  9. Zesti
    9 Feb 2010
    Nah, I don't have photoshop. I just resize pictures in IrfanView and save them with 95% quality. It would really hurt to drop quality more for faster downloading.. :D
  10. yassarikhan786
    10 Aug 2011
    No worries mate. I will be following this one for sure :).
  11. Fedmas
    29 Jan 2010
    Agree @ Above! I will follow your project log for sure!
  12. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    awsome... i love these projectlogs !
    Edit: Subbed OFC!
  13. alternativesurfer
    alternativesurfer What's a Dremel?
    14 May 2007
    Definitely interested in how this turns out.
    *Subbed
  14. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    I'm in!
  15. Sarakon
    Sarakon The German
    11 Feb 2011
    I like the sound of this (and of course the beginning)...:thumb:
    >Subbed
  16. Zesti
    9 Feb 2010
    Thank you all for nice comments. :thumb:
    PSU arrived to the post office and I went to pick it up with a bicycle.. Didn't realize that SilverStone uses ridiculously large boxes for their power supplies. Nearly broke my backpack when I stuffed the box in it. :hehe:
    But it was well worth it.. Even the box is beautiful:
    And the PSU itself.. I must admit that I was waiting for lower quality. Surface finish is very nice, connectors are easy to use and so on. Even more expensive Enermax PSU's I have used aren't this nice.
    I like it.. But it has so much stickers to remove. :duh:
    You might also wonder why I got Silverstone PSU and not Corsair, Seasonic etc. Well, here's the number one reason for that; Silverstone uses 1:1 -connected modular cables which are really easy to sleeve. Here's 24pin connector connected to the PSU:
    Oh, and those images are now 800px wide and a bit lower quality. As a result they should be over two times faster to download.. ;)
  17. yassarikhan786
    10 Aug 2011
    What a lovely PSU. Nice image quality and they did load pretty fast :).
  18. Mork
    Mork What's a Dremel?
    9 Nov 2009
    I subbed at the title banner and everything just got better the further I scrolled down :blush:
    I'm looking forward to seeing this project evolve! :)
    /Mork
    Edit: Apparently I'm really bad at reading.. didn't see you had listed the mb form factor ;)
  19. Razer2007
    18 Jul 2010
    Nice PSU and thank for making the pics a bit smaller. It still looks great!
  20. Wing Zero
    Wing Zero Ita-sha owner
    28 Apr 2010
    I was hoping this was a mod inspired by Konami's 'Zone Of the Enders' series of games, but it's looking good so far
