#1 |
Modding and coffee
Cooler Master Cosmos II MbK...Final pics!!!
![]() Cooler Master Cosmos II MbK Sponsered by: ![]() ![]() ![]() Hi my modding friends, A new year begins, so a good start in terms of a new modding season With a brand new case .... which is released right now, the Cosmos II The new flagship of Cooler Master. The hardware which comes in it is not known yet for sure, but it is certain that an x79 mobo and a number GTX580 GPUs comes in And offcourse watercooled. The color combination is going to be black, gray and white The package was brought a month ago, the deliveryman cursed me ![]() What a case and what a weight, unbelievable. My wife was pissed and called me some names I didn't heard before So I needed to make space in my workshop to properly view the case. The package: ![]() ![]() ![]() ![]() First unpacking which quite a operation turned out to be ![]() And here it is the great Cosmos II ![]() ![]() ![]() ![]() ![]() Lots of case with a lot of space, really a true pleasure to mod this one Cooler Master Raymen, Ruud and Marco and of course anyone who makes this possible ... Thanks! And then moved it straight to my workshop to view and show interior First some specifications: -Exterior Material: Aluminum, mesh, synthetics -Interior: Steel alloy, plastic, rubber -Dimensions: 344 (W) x 704 (H) x 664 (D) mm / 13.5 x 27.7 x 26.1 inches -Weight: 22 lb kg/48.5 -Maximum compatibility CPU cooler height: 190 mm/7.48 in. -GPU-Length: 385 inches mm/15.15 -Type-M/B: Micro-ATX, Micro ATX, E-ATX, Extended ATX, SSI CEB, SSI EEB Once dragged in my workshop and opened it immediately, I noticed how much 3.5 Drive Bay are in it less than 13 pieces in total (2 from X dock, Mid cage for 5 HDDs, bottom cage for 6 hard drives) The middle bay has room for 5 HDDs ![]() ![]() In the lower HDD bay there's room for 6 hard drives which is hidden behind a beautiful fan bracket with 2 x 120 mm fan, 1200 RPM, 17 dBA ![]() ![]() ![]() And here there is room for 6 HDD's ![]() ![]() The PSU has shifted back for some extra space inside ![]() And is raised a little ![]() At the front there is space for two HDDs through the X-dock and there are three 5.25-inch drive bays available ![]() Below this compartment, behind the mesh part there is one 200 mm LED fan, 700 RPM, 19 dBA (converted from 120 / 140 mm) And below that there is still room for a 120mm fan for the airflow trough the lower HDD's bracket ![]() ![]() The back has room for a 10+1 Expansion Slots [IMG]http://i759.photobucket.com/albums/xx233/kier1976/Cosmos%201/DSC05678.jpg[/IMG And a 140 mm fan, 1200 RPM, 19 dBA comes with it to the rear ![]() At the top is a lot of space under the mesh ![]() ![]() This cover is very easy to remove with a screw, and below is enough space for 3 fans and wiring ![]() There also would fit a 360 rad but for that there are some adjustments needed. And it comes with a black 120 mm fan, 1200 RPM, 17 dBA ![]() Also on the top there is a sliding panel. Below that there is a control panel with 7 functions More about this in the next update ![]() ![]() ![]() ![]() ![]() At the front there is the I / O panel with 2 xUSB 3.0, 4 x USB 2.0, 1 x e-SATA and audio in / out ![]() And there is very good tought about the cable management ![]() ![]() With enough holes ![]() ![]() ![]() I could go on an d on about the case but..... now it's modding time I removed the top mesh and made a number of strips. ![]() Which are directed obliquely backwards, this is still a rugged design and has yet to be finished ![]() ![]() Cut out the fan controller carefully ![]() ![]() ![]() Here is coming a slot loader DVD or Bluray. ![]() For measuring I used this one . ![]() And made a slot for it ![]() ![]() Where before was the sliding panel I cut and bent a piece of aluminum ![]() Which is placed like this ![]() ![]() And made the slot for the slot loader drive ![]() ![]() ![]() I hope this is a good start of the new year for you ... for me it is ![]() More to come!!! Last edited by kier; 8th Jun 2012 at 17:03. |
#2 |
Making You Feel Old Since 2010
Awesome! Great start! Love the case, can't believe you got it so soon.
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#3 |
Fenrir The Wolf
How did you get this case???
It is not even listed on CoolerMaster website. |
#4 |
Modding and coffee
Thanks you guys... and it was released exactly at 00:00
#5 |
Minimodder
Probably He got from them?
#6 |
Do you even mod, bro?
That case is so nice, its almost a shame to mod... but I can't wait to see what you do!
How about a WC 7970 with a massive GPU Core overclock instead of a 580?
__________________
Deep Silence 1 - 2500K @4.6Ghz - ROG Maximus V Extreme - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG |
#7 |
Modding and coffee
I have 2 gtx580 now and maybe 3 for this build
#8 |
Supermodder
OH MY GOD , im in love !
#9 |
Multimodder
Congrat for the brutal case!
#10 |
Fenrir The Wolf
This is epic case,and it will become unmortal mod.
Respect!!!! |
#11 |
The modding head is firmly back on.
I like where you're going with that top panel. I'll be keeping an eye on this one.
#12 |
What's this button fo......
Following this one.. already hooked!!
#13 |
Master of Pancakes
I've got to copy everyone else here and be happy with what you've begun. Good luck on your mod.
I'll start posting mine up here soon! |
#14 |
*learning english*
very nice case!!! i feel some chest-ache when i saw pics of reaping such beauty apart... i hope result would be good!
#15 |
Kier should make case mods for other people and sell them. And make MBK one of his best sub brands for cases, going off your previous MBK mod, this will be incredible!
Coolermaster set a very high bar for 2012 with this case, can you set a very high bar for modding?
__________________
#16 |
Modding and coffee
Thanks y'all, I won't let you down
@KidMod lol, I've allready started to place the "MbK" logo in some mods now ![]() ![]() Coolermaster has really raised the bar yes, I hope I can do this also For that Ill need your feedback my modding friends
#17 |
Multimodder
epic case+epic modder=got to follow
good luck with this new one
__________________
Scratch Build : GALLUZZO-I : silent wood case MOTM nominee |
#18 |
Modding and coffee
Just to compare the size of this beast
![]() ![]() And next to some other cases ![]()
#19 |
Supermodder
Looking forward to this build Richard I hope u make something unique for this case. But by the first post u already had a good start with the fins on the top of the case
#20 |
*learning english*
that corsair boys really looks like a kids compared to BEAST
*watching* *thinking that it's almost time to abandon scratchbuilding and move to that brilliant cosmos2* |
| Thread Tools | |
| View Mode | |
