Reply
Thread Tools View Mode
Old 4th Jan 2012, 13:57   #1
Paslis
Supermodder
Paslis's Avatar
Paslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run CrysisPaslis can run Crysis
Project - The Next Level - Winner MOTY 2012 -
Hi Everyone,
Its time for another project.My idea/design to build a desk inside a frame with a glass top and without feet ive done 2 times.
Version 1.
Version 2.
I dont want to make a third version so now its time for a new design.This time i go for an ergonomic design.So this is the kickoff for my new project The Next Level.
The idea is to build a design desk that can be adjust in height so everyone can sit at it by simply push a button to move it up or down.My designs always change when im building so here a drawning how its gonna look.
The desk will be watercooled and the hardware is not decided yett.More about this later.
I already bought the lifting column and this is how it looks.
The specs.
• Thrust: up to 2500 N per DL2
• Speed: up to 20 mm/s with CBD4
• Installation dimensions can be seen in the
ordering example
• Stroke length 300 mm, 350 mm, 500 mm ± 4 mm
• Colour: Natural anodized aluminium profiles and
black painted end plates or electro-galvanised
3 mm end plates
• Low noise level
• Compact and mounting friendly design
• Built-in limit switches (not adjustable)
• Dimension column: 147 x 194 mm
• Dimension 8 mm end plates: 160 x 244 x 8 mm
• Dimension 3 mm end plates: flush with the
profiles
• Each column is fitted with a 740 mm ± 60 mm
straight black cable with an 8-pole AMP plug or
100 mm mini-fit cable
• Dynamic bending moment (at 100% stroke
length):
My+/Mx+ = 250 Nm and My-/Mx- = 200 Nm
And a little movie how it works.
http://www.youtube.com/watch?v=61hPwaFKs1E
Sponsored by:
My head is full of new ideas so more to come.
Paslis is offline   Reply With Quote
Old 4th Jan 2012, 14:28   #2
Monsieur R.
In cornichons I trust.
Monsieur R.'s Avatar
Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!Monsieur R. - it's over 9000!!!!!!!!1!1!1!!!
"Why moving when your computer can move for you."
Awesome concept ! I hope it will turn as good as Flipmod did. Good luck
Monsieur R. is offline   Reply With Quote
Old 4th Jan 2012, 14:50   #3
l3p
www.^.nl
l3p's Avatar
l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.
Will certainly follow it!
I love this "kid-proof" desk
__________________
Preparing: Raz3r D3sk
Running : L3p Parvum
Finished : Cross - L3p AlCu - L3p L4n - L3p D3sk
Sites: www.l3p.nl - www.redharbinger.com
l3p is offline   Reply With Quote
Old 4th Jan 2012, 15:04   #4
Paslis
Supermodder
Paslis's Avatar
Thanks mate and you will see.
Thanks Peter but i hope you dont fall in love with this one like you did with my first desk because i dont want to be the reason you cant sleep again.
Old 4th Jan 2012, 16:46   #5
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
I can see your future already: Adjust table, adjust chair to table, adjust monitor, adjust table again.
It should be a cool project. Your other builds were fun.
Cheapskate is offline   Reply With Quote
Old 4th Jan 2012, 16:54   #6
l3p
www.^.nl
l3p's Avatar
Who knows, but doubt there will be anything to improve
__________________
Old 4th Jan 2012, 17:23   #7
Paslis
Supermodder
Paslis's Avatar
There is always something to improve thats why i made a second desk of my first design and maby whit this one also.Who knows.
Old 4th Jan 2012, 17:33   #8
l3p
www.^.nl
l3p's Avatar
Goodluck with it! Want to see you as a MOTY nominee next year!
__________________
Old 4th Jan 2012, 17:45   #9
Paslis
Supermodder
Paslis's Avatar
Thanks Cheapskate and yes maby my next project will be a chair.
Thanks and who knows.
Old 7th Jan 2012, 11:11   #10
bond0071993
What's a Dremel?
bond0071993's Avatar
bond0071993 has yet to learn the way of the Dremel
Great build but wouldn't be better monitors to stay on the desk
bond0071993 is offline   Reply With Quote
Old 7th Jan 2012, 16:15   #11
Paslis
Supermodder
Paslis's Avatar
Thanks and no you gonna see later on what i came up with.
Old 21st Jan 2012, 19:45   #12
Paslis
Supermodder
Paslis's Avatar
Update 1 - 21-01-2012 -
Finally its time for an update.The past 2 weeks some things happend.I got my first sponsors for this project and i changed the design.
Cooler Master sponsored me a silent pro hybrid 1050W and its fully modulair.
http://www.coolermaster.nl/
Some pictures of the psu.
[IMG]http://i1092.photobucket.com/albums/i417/perzikdrank/The%20Next%20Level/cm2.jpg
[/IMG]
Thanks Cooler Master and specially Marco.
Also the company i bought the lifting column from has decided to sponsor my project with a second column.
http://www.linak.com/
Here a picture wiht both lifting columns.
Thanks Linak and specially Adwin.
Because i was afraid of instability i changed my design.This is the final design.
This week i cut the desk and the side pieces with the lasercutter and i made a little movie.
http://www.youtube.com/watch?v=BJEjW9se0xk
Below are the pictures of the pieces i cut.I used 3mm aluminium.
Today i bend the piece with a co-worker ( the guy on the picture ).
Then i spot welded the piece together.
The next thing to do is to spotweld these 2 pieces in the desk and then finsh the welding.
This was it for today.
Old 21st Jan 2012, 20:05   #13
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Love your ideas & work Paslis & I did wonder who did the uber desk first, now I know .
I call this kind of quality of PC in a desk an uber desk .
Waynio is offline   Reply With Quote
Old 21st Jan 2012, 20:06   #14
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!
Cool project mate.
Pranja is online now   Reply With Quote
Old 21st Jan 2012, 20:19   #15
Paslis
Supermodder
Paslis's Avatar
Thank you very much Waynio.
Originally Posted by Pranja View Post
Cool project mate.
Thanks mate.
Old 21st Jan 2012, 20:30   #16
Waynio
Waynio's Avatar
Forgot to add 5 stars & rep .
Old 22nd Jan 2012, 07:53   #17
Paslis
Supermodder
Paslis's Avatar
Thanks for the stars and rep mate.
Old 22nd Jan 2012, 09:58   #18
bugbear974
Multimodder
bugbear974 has yet to learn the way of the Dremel
Desk desk desk only desk every where it's contagious! but really good too^^
bugbear974 is offline   Reply With Quote
Old 22nd Jan 2012, 14:35   #19
Paslis
Supermodder
Paslis's Avatar
Thanks mate and i love to design them maby after this one im making a compleet different project but for now im having an ball.
Old 22nd Jan 2012, 15:08   #20
ASPHIAX
Beyond Complexity Lies Simplicity
ASPHIAX's Avatar
ASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the DremelASPHIAX has yet to learn the way of the Dremel
The work (again) is so clean!
I am loving it already !
__________________
Current Build : BORG COSMOS II
Current build : 2001 - A Case Modyssey
Finished build : IMPERIAL AT-AT
Finished Build : USS EURISKO - Intrepid Mark II Class
www.asphiax.wordpress.com
ASPHIAX is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
