#1 |
Fenrir The Wolf
Cosmos S mod-Reaper *completed*
Hi everyone,
welcome to my project log. This will be Reaper themed Coolermaster Cosmos S case. I would like to thank my sponsors: Thanks to Sale,Kiki,Goc and Apach from iShop Sisak. Without them this project would not exist. Thanks to Milan Simic from Coolermaster for supporting this project and giving me such a great opportunity. Thanks to Robert Reibold from Inter-tech for CobaNitrox fans,they are top quality. Thanks to Miroslav Mokry from ASBIS for their support and for supplying me with Inter-tech products. Thanks to Sandro Vrbanus for great discount for their plexi cutting and etching services. Thanks to folks at LD Cooling for supporting me with their top quallity case accessories. This was the base for my project: Finished: Last edited by Pranja; 28th Mar 2012 at 11:57. |
#2 |
Fenrir The Wolf
I received some goddies from iShop and they had to be utilized immediately:
Then I took out on/off clap switch from my old lamp project,and adjusted it to meet my needs: The clap switch was installed and I took out fan controller,which caused a lot of molex mess (I will sort this out later): Of course,something was not good with clap switch. I just had to move one wire and voila-it worked like a charm: Then,I started to make power supply extension cables: Bought some new tools: More pics of extension cables (two are finished): Last edited by Pranja; 1st Feb 2012 at 19:06. |
#3 |
Fenrir The Wolf
I didn't had any heat shrinks left (purchased today),so I started to work on right panel.
It was sprayed by previous owner,but I will remove it before it is painted in my choice of colours. Pics of case with new right panel (you may notice that I removed plexi and put original mesh on left panel): Last edited by Pranja; 1st Feb 2012 at 19:07. |
#4 |
Fenrir The Wolf
Here is a small video of me turning on and off lights on Cosmos:
#5 |
Minimodder
nice mod, can't wait for more pictures
#6 |
Loading...
Nice project Pranja, I like the concept.
Good luck with the build! |
#7 |
Fenrir The Wolf
Thank you very much guys.
This is just the start,so expect more pictures (soon). |
#8 |
Never stuck with stock@Hotmods.net
Haha, got to follow this one. How will the clap sensor work when you're attending a computer party with techno music banging from speakers on every desk?
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#9 | |
Fenrir The Wolf
![]() I noticed that music from my 5.1 sistem is not making any problems,but when I play games and pc get loud,I can't activate switch. This will be solved with some sound insolation around switch. ![]() Stay tuned,because there will be more work with electronics (hint: motorized vxxxs). |
#10 |
Fenrir The Wolf
Little update
Here is a little update of my project.
I received package from Coolermaster (thanks to Coolermaster and Milan Simic). I got some very useful parts. I shaped plexiglass just like a stock Coolermaster mesh,but I was not been able to cut it because my mother was sick and I didn't wanted to disturb her with dremel sound. And I finally finished my cable extensions. What do you think about them,guys? |
#11 |
Loading...
Nice stuff! good work with the cables!
#12 |
Fenrir The Wolf
#13 |
Fenrir The Wolf
Ok. More updates (time to speed up).
I made PSU shroud and cover for back side od drive cages. Of course,everything must have holes for addition fans. ![]() You can see that I transformed my bathroom in workshop. ![]() This week case should be painted,and I have to speed up this dremeling part. So expect more pictures tomorow.
#14 |
Multimodder
What cards are those?
__________________
i7 2600k @4.42GHz, | Asus Maximus IV Gene-z | 8GB G.Skill Ripjaws CL9 | GTX 570 @ 803/2002 | 128GB Crucial M4 SSD | Coolermaster RP Pro 1000w | Lian Li PC70 | Onkyo SR608 amp | Mordaunt Short components | |
#15 |
Fenrir The Wolf
#16 |
Fenrir The Wolf
Update from last three days.
I received two LED strips (red offcourse) from ebay. Now I have total six of them. ![]() Case has been dissasembled,packed and transported to paint shop. Bag 'em and tag 'em. ![]() My PC ended up like this: Real hardcore mode. ![]() Tommorow I will pick up the case and assemble it. Project is 70 % done. To do list: -find suitable hardware(red-black/black RAM,MBO,new CPU) -make/buy water cooling -finish PSU shroud -make Reaper etching on plexi
#17 |
Fenrir The Wolf
Haiku time:
New day New tools Painted rivets Red ![]() Some of them turned really gread,but some were total disaster. ![]() I painted 70 rivets so I can pick good ones. |
#18 |
Did you paint them using expandable paint? Otherwise, the paint will crack and peel off once you fasten the rivets...
__________________
#19 |
Fenrir The Wolf
#20 |
Fenrir The Wolf
Case painted
New update-case has been painted and asembled.
Unfortunately,my Olympus C-510 makes bad pictures. ![]() I will take more tomorow. Hope you like it. ![]() |
| Tags |
| case mod, coolermster, cosmos s, reaper |
| Thread Tools | |
| View Mode | |
