Reply
Thread Tools View Mode
Old 23rd Mar 2012, 13:20   #1
exexs
Multimodder
exexs's Avatar
exexs has yet to learn the way of the Dremel
Unit-System! Lian-Li PC-9F
This is my FIRST try with modding! I welcome any comment and tips, feel free
Hope you'll enjoy it as much as I do
Some sleeving:
For guys (like me) who are happy to save a few bucks, here is how you do:
2 clips, a screwdriver and.. done
I don't know what is your point of view, but, I think they look as great as Dominator (and cheaper at same stats). Here is my Crucial Elite 8GB 1866Mhz CL9 1.5V :
I'll be using a Lian-Li PC-9F case, not used in a lot in modd, so I hope it is gonna be a little bit different =D
exexs is offline   Reply With Quote
Old 24th Mar 2012, 15:54   #2
exexs
Multimodder
exexs's Avatar
Some changes
Some stuff I'll be using in my case:
And here, I removed the stickers from the fan. At first I wanted to do my own stickers but I think I'll go "naked", they look just great I think
Also removed the MSI logo from motherboard!
LEFT: BEFORE .... RIGHT: AFTER
Old 24th Mar 2012, 16:02   #3
IanW
Grumpy Old Git
IanW's Avatar
IanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpitIanW is almost as Godly as yodasarmpit
Remember that the sticker is there not just to advertise the manufacturer, but also to keep dust/lint/assorted crud out of the fan motor.
__________________
i5 2500K@3.3GHz / Corsair H50-1 / Asus P8P67-M PRO / 16GB Corsair Vengeance / MSI GTX670 / 240GB Samsung 840 /
1TB HDD / Silverstone 600W / Silverstone SG-09 / Dell U2713HM / CM Storm Quickfire TK / Logitech G9 / Win7-64 Ultimate / Ubuntu 13.04-64
IanW is offline   Reply With Quote
Old 24th Mar 2012, 18:21   #4
Metrodusa
Minimodder
Metrodusa's Avatar
Metrodusa has yet to learn the way of the Dremel
One can always make custom ones, if desired. But I leave them on all the time. Making circles without CNC of some kind is a pain in bodily parts.
Metrodusa is offline   Reply With Quote
Old 24th Mar 2012, 20:08   #5
RealWeaponX
Minimodder
RealWeaponX's Avatar
RealWeaponX has yet to learn the way of the Dremel
IanW has a point. If you like the look you should at least put some clear acetate over the area to protect it.
RealWeaponX is offline   Reply With Quote
Old 24th Mar 2012, 22:52   #6
exexs
Multimodder
exexs's Avatar
Yeah I keep it in mind! But the stickers in the front side are not protecting anything, and I should have told you that the ones on the other side are still there, because there will be no possible angle to see them as the fans are mounted in the radiator (push).
Yeah I tried indeed to make some "stickers" myself, by cutting an aluminium sheet of 1mm but wasn't that easy to get perfect circles. I'll try again to remplace the back stickers even if nobody will see them (but me, I know they are there)
Old 25th Mar 2012, 15:52   #7
exexs
Multimodder
exexs's Avatar
Hey guys!
A little update, in fact this is a cover for my GPU I made few weeks ago, but I'll share it with you as you'll see it in the next updates...
This is aluminium 1mm, that i cut sanded.
Here the cover is in I painted it in black. I also used some rubber between the aluminium and the graphic card to be safe xD
(you can notice back then I was using a corsair H50 but now I am using watercooling to the the circuit and stuff)
Old 31st Mar 2012, 15:05   #8
exexs
Multimodder
exexs's Avatar
the "hdd" issue
Hi guys!
Ok, there is not so much place in my case (PC-9F middle tower), so I was brainstorming about the place where I can put my HDD (other drives are SSD so it is not so much an issue)..
Do you remember Hideo Kojima and his "no place to hide" ?
If you are a fan of Metal Gear Solid (as me), you sure remember...
So I said to myself... If there is no place to hide my hdd, why not put it where everyone can see it?
Now, I have to polish my HDD and do my own stickers and maybe paint-it too.. let's get to work
Old 31st Mar 2012, 15:37   #9
Leena
What's a Dremel?
Leena has yet to learn the way of the Dremel
In my opinion the stickers are kinda useless, there is no much dust coming from behind the fan.
Anyway your idea for the hdd is great, keep going !
Leena is offline   Reply With Quote
Old 28th Apr 2012, 13:15   #10
exexs
Multimodder
exexs's Avatar
Hi guys!
BIG UPDATE today, my NEW CASE ARRIVED
What do you think? Am I a amazing modder or what?!
Ok I explain: I am modding my 24/7 config so this is really hard to switch it off to modd, so I decided to put my computer in a box in order to be free to modd my Lian-Li case. I'll start cutting it soon!
__________________
Support and comments for my FIRST worklog are appreciated: http://forums.bit-tech.net/showthread.php?t=228161
Old 19th Jul 2012, 15:43   #11
exexs
Multimodder
exexs's Avatar
Hi there!
As you can see, painting is in progress!
I'm painting with spray paint, and it needs some layers before it looks good...
PS: If you have some advices for painting, i'm here
__________________
Old 20th Jul 2012, 17:15   #12
exexs
Multimodder
exexs's Avatar
big update
The painting is done! I'm quite happy with the results! What do you think?
I decided not to paint the motherboard tray, because the motherboard itself is black, so it would have been difficult to see "her", and has "she" is one of the major component in the case, would have been a pity!
Feel free to comment! This is my first "worklog", I don't have a lot of experience and any comment is welcome!
__________________
Old 20th Jul 2012, 18:20   #13
SilveR_172
Supermodder
SilveR_172 has yet to learn the way of the DremelSilveR_172 has yet to learn the way of the Dremel
Cant realy see the results of paint due to 1 poor lighting / poor camera quality / High grain in pictures
SilveR_172 is offline   Reply With Quote
Old 28th Nov 2012, 23:15   #14
exexs
Multimodder
exexs's Avatar
My apologizes, I only have a iPhone 4S for pictures for now, so I do my best with what I have
Ok, not an update but a question for you guys, I need some help
I would like to put my GPU under water, so here my question:
Will it be possible to have decent temp for my i7 860 (small oc from 2.8Ghz to 3Ghz) + GTX660 Ti?? I'll be using a 360rad (XSPC RX360, the thick one) and 3 Noiseblocker S2
If not, what are my options? thinner rad with push/pull fans (so 6 in total) will give my better temp?
As a "bonus", here is where I'll put my HDD (hope my sketchup is right, because there is no much room in this case!!)
Thanks a lot for your answers and comments, it always motivates me
__________________
Old 19th Dec 2012, 22:19   #15
k.3nny
Hypermodder
k.3nny's Avatar
k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.
you can even cool the gpu and cpu with that Dual rad
And always put RES-PUMP-everything else! never put a component between reservoir and the pump, your pump can run dry then and can break
k.3nny is offline   Reply With Quote
Old 20th Dec 2012, 20:36   #16
exexs
Multimodder
exexs's Avatar
To be honest I didn't know that How comes? I mean, there is water in the radiator too? Little bubbles can affect the life of my pump?
Anyway, I changed my mind a little bit about my integration, and the new sketch is taking your advice into account! (not in purpouse as I did the sketch before your comment but shh it's a secret )
The only think I am not happy with is having the res just in front of the fans. I'll maybe change it ^^
__________________
Old 20th Dec 2012, 22:41   #17
k.3nny
Hypermodder
k.3nny's Avatar
Yes, Air in your loop is bad.
Old 24th Dec 2012, 14:11   #18
exexs
Multimodder
exexs's Avatar
hi guys! I'm working on a cover for my new gpu (pictures soon), but I have a question here: can I make a gpu cover with 3mm acrylic? I'll then painted it in black with temp-proof painting.
My concern here is about the heat? Can it damage my acrylic cover? (melt or something) Also, you have to know that my gpu is a GTX660 (moderate power ^^) Thanks for your tips on that one!
__________________
Old 24th Dec 2012, 14:38   #19
siliconfanatic
Car lover and Speed Junkie
siliconfanatic's Avatar
siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.
Nope, long as you play it safe. if the graphics/gpu are running nice and cool, which they should on water or a nice, good air cooler, then you should be a-ok. good luck, and make it look good!
if the gpu is below 30 that means that the back of it is only a little warm to the touch. on a good WC, with MORE than just a 240, you'll be fine even for a high load. but if you aint gaming much a plain 240 is safe, just don't run many gpu-intensive applications like i do.
__________________
Originally Posted by quizz_kid View Post
Blackalize it!
I *am* the guy who loves too many threads to bump them all.
siliconfanatic is offline   Reply With Quote
Old 26th Dec 2012, 00:45   #20
siliconfanatic
im not doubting you here, but how would that make your pump run dry? ts actually about the placement of the pump in terms of above or below the res if im not mistaken. as long as theres water in it your good to go, after that? your right but not quite specific and general info always seems to confuse me in the weirdest, most backwards kind of way. my mind works really weirdly...
__________________
Blackalize it!
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
