#1 |
Supermodder
Project: Steampunk'd TJ11 DONE!!! October 2012 MOTM Winner!!!
![]() Time for a good Steampunk mod. And what better case to use than the awesome Silverstone TJ11! ![]() ![]() Big shutout to my sponsors!! ![]() Performance-PCs is providing me with the BP mod kits, 240 and 360 rads and the Silverstone slim DVD bay. ![]() EKWB is providing me with a EK-Multioption 250 Res and 90 degree fittings. Hardware Mobo: Asus Sabertooth P67 CPU: Intel i5 2500K GPU: Unknown RAM: 16GB Corsair Dominator 1333 SSD: Curcial M4 128 GB PSU: Silverstone Strider 1200W Fan Controller: Lamptron FC10 Cooling XSPC EX480 EK-CoolStream 360 Another 360 rad EK-Multioption 150 or 250 EK-RAM Dominator EK-MOSFET Sabertooth P67 EK-Supreme LTX 2x XSPC 120mm radiator stand Misc Sleeving: MDPC-X Yellow SMD LED Strips Yellow LED bulbs Sophisticated Finishes Rust Effect Kit Old Vacuum Tubes Lets start working! The first thing I did was do some testing with LEDs in the Vacuum tubes. Here is what they look like with an Orange LED in them. Orange is not the final color, yellow is but at the time I didn't have the Yellow LEDs in yet. ![]() ![]() ![]() Next up was to see how the rust effect paint would workout. First lets try some fan grills. The Paint ![]() The Grills ![]() Primer and Iron paint ![]() Rust Paint ![]() ![]() ![]() ![]() ![]() ![]() Since that test was successful I thought I should try an actual piece of the case. The dual PSU bracket seemed like a good test subject. ![]() And the result ![]() I am very confident in the results so I started doing more, but that's in the next update. Stay tuned by subscribing so you can see all the updates! Cheers till then, Fuga Last edited by Fuganater; 18th Dec 2012 at 01:29. |
#2 |
Retro Fan
This rust effect looks awesome. I love these steampunk builds and those vacuum tubes look great too. Lets hope we see some creative lighting ideas.
__________________
~Intel Core I3 3220 ~8GB Corsair Vengeance 1600Mhz~ CorsairCX600w ~ Asus GTX560ti Direct CUII Core @ 950Mhz Memory @ 2250Mhz ~ P8H77 ~ 128GB Samsung 830 SSD ~ Gelid Tranquillo ~ USB modded NES, Master System, Mega Drive and N64 controllers for Emulation~
#3 |
Supermodder
Thanks. I hope the rest turns out just as good.
#4 | |
What's a Dremel?
i will follow up, so i dont miss an update.... keep on working!
#5 |
*learning english*
looks good!!! keep it up!!!
for me rust is more about pos-ap/biohazard builds. for steampunk i see wood, copper, brass and patina
__________________
10 re-plan "SuperBestBuild Of My Dream" 20 have a sleep 30 goto 10 |
#6 |
Supermodder
The Case
Since testing is over its time to start on the case.
![]() Its actually a good thing I'm modding this case because I got it used for pretty cheap. You would never get a good looking build out of this beatup case unless you paint/modify it. There are several screws missing, HDD bays missing and the front bezel was bent. I was able to fix the front bezel mostly and I ordered lots of new screws. First thing to do is remove all of the buttons, connectors and cables. ![]() Remove the mobo try and fans. I was going to not use the fans but I decided to make a midplate to hide them and that has cutouts for the fans. There will also be some Bitspower passthrough fittings for the tubing. ![]() 5.25" bays gone and mobo tray rails are out. ![]() And here it is in pieces. ![]() The first thing to do before you paint is get a nice coat of primer on the parts. ![]() Next I started painting all the parts with the Iron base coat. This actually has iron particles in it which react with the Rust paint. ![]() All the small bits. ![]() And the large ones. ![]() Next is the Rust paint. Its actually not paint. Its a chemical which looks more like blue water but you get the picture. ![]() Just after 1 coat you can see it starting to work. ![]() ![]() ![]() ![]() ![]() 2-3 coats ![]() ![]() 5ish coats ![]() ![]() And the first coat on the 5.25" bays ![]() It starts the reaction only after maybe 5 minutes after being applied. ![]() Lastly I'll leave you with some of my grill plans. I have a friend who does my laser cutting and he will do up a sick CAD drawing for me and I'll share it with all of you. I'm going to install the 50mm fan on the motherboard so I need a grill to make it look nice. Also since I am keeping the internal 180mm fans I have to keep the side panel vents. I want to dress them up some otherwise they just look funny. ![]() His will obviously look better than what I can draw :P Cheers till next time, Fuga |
#7 |
Supermodder
Top rust effect!
Keep us posted and don't let this build "die"!
__________________
Latest Project: « «[ Little Angel ]» » (FINISHED!) Sponsors: *** Aquatuning | Atlas Informática | NZXT *** *** ProSilentPC | Seasonic | IzarMicro | E22 *** Follow me on Facebook! |
#8 |
Multimodder
Lookgs good however this seems more post-apocalyptic than steampunk :S
#9 | |
Multimodder
Shocker on the looks this is....Very intruiged as to where you'll be taking this
![]() /uselessInfos Quote:
/end uselessInfos |
#10 |
Keep calm & mod on. =)
This is not the typical case for doing a semi damaged look on & steampunk incoming also, keenly subbed.
#11 |
Minimodder
Definitely can't wait to see this finished
#12 |
What's a Dremel?
#13 |
Supermodder
I agree, the paint job is fantastic. I have to admit, looking at the fan grills I thought they were old and rusted and was wondering why you were using them. Well done!
__________________
Pfaffen Wood Case Mods: Completed: World Map, Fibonacci, Canary Mesa, Molesworth, Cray-1, Federal Cellarette, Newbery TARDIS Wood Case Mods: Under Construction: Vogel Haus, Four Hokusai Cases |
#14 | |||||
Supermodder
Thanks! I hope I don't dissapoint. Quote:
Haha! |
#15 |
Mad FPS Gamer
Going to be a interesting mod.
I do like the Steampunk stuff but I am not sure if I will like it on a TJ11. Sub'd to see how it turns out though and hope it looks amazing in the end.
__________________
Core I7 3930K, Rampage IV Extreme, 16GB Corsair Vengance 1600mhz, GTX 680 SLI, Corsair Force 3 250Gb SSD, Creative Sound Blaster X-Fi Titanium, NZXT Switch 810, XSPC RX 360mm + Alphacool 240mm All Copper, 10x Scythe Kazi Jyuni 1900rpm 5v & And It's Silent!!!!!!!!! . Market Place Feedback http://forums.bit-tech.net/showpost....&postcount=104 |
#16 |
The German
Cool start to a promising mod! Looking forward to what you have in store for us
__________________
Obsidian 650D | Asus P8P67 EVO | Intel i5 2500K | OCZ Vertex 4 | Corsair Vengeance 16GB | MSI GTX 660Ti PE OC | Cooler Master 850W Silent Pro M |
#17 |
Multimodder
BAD ASS! lol
__________________
Yesterday is history, Tomorrow a mystery, today is a gift, which is why it is the "present". |
#18 |
Multimodder
Looks incredible Shane! I'll be keeping an eye on this one
And ignore what Toby said, your sketches look great
#19 |
MMMMMMm watercooling....
Loving the rust effect, subbed. +rep
__________________
Asus ROG Maximus V Formula MoBo, Core i5 3570K @ 4.7Ghz, 6GB Corsair Dominator Ram 1600Mhz, SLi GTX460's(1GB), Enermax Revolution 1250W PSU, Xigmatek Elysium Chassis
Dual WaterCooling Loops with 12 Noctua NF-P12's = WOOOOSH!!! ![]() |
#20 | |||
Supermodder
![]() Quote:
Thanks Quote:
Thanks! |
| Thread Tools | |
| View Mode | |
