Reply
Thread Tools View Mode
Old 9th Jan 2013, 21:22   #61
siliconfanatic
Rep whore/ Car lover/ Speed Junkie
siliconfanatic's Avatar
siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.
very much so GIMME! sketchup may not render but its at least good for planning
__________________
Hard to explain to someone who has no clue. Or doesn't believe you. It's a daily struggle being in pain or feeling sick on the inside while you look fine on the outside. Please put this as your signature for at least 1 hour if you or someone you know has an invisible illness (Pancreatitis, Crohn's, PTSD, Anxiety, Bipolar, Depression, Diabetes, LUPUS, Fibromyalgia, MS,Lupus, ME, Arthritis, Cancer, Heart Disease, Epilepsy, Autism, etc.) " Never judge what you don't understand.
siliconfanatic is offline   Reply With Quote
Old 9th Jan 2013, 21:27   #62
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for president
Ok, then expect pics soon.
I need to finish everything and then is yours.
__________________
_Cosmos S Reaper_ _L.R.E.C._ _Scorpio_
_Arya_-under construction _ROG Crawler_
Pranja is offline   Reply With Quote
Old 9th Jan 2013, 21:30   #63
Hukkel
Multimodder
Hukkel has yet to learn the way of the DremelHukkel has yet to learn the way of the DremelHukkel has yet to learn the way of the Dremel
It looks kind of alien. Very original!
Hukkel is online now   Reply With Quote
Old 9th Jan 2013, 22:59   #64
Nutman
Never stuck with stock@Hotmods.net
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Congrats of shagging up with Enermax. How did you manage to get them on board? Local representative, or someone at Enermax HQ?
__________________
Best regards, Nutman
Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks
Nutman is offline   Reply With Quote
Old 10th Jan 2013, 10:41   #65
Pranja
Fenrir The Wolf
Pranja's Avatar
You mena alien-bug? Thanks!
Thank you. I contacted their PR-there isn't local representative because Enermax is not sold in Croatia.
__________________
Old 11th Jan 2013, 19:47   #66
Pranja
Fenrir The Wolf
Pranja's Avatar
Before sending model to the CNC, I had to redesign some things.
First thing to change was case feet-now they are smaller and look more agressive then previous model. They are also thinner- 8mm compared to 16 mm before.
Case itself is now 6 cm lower and I don't have any unused space between central structure and floor. Number of case feet was also changed-6 compared to 5 before.
Central structure is now 14 mm (16mm before). Now I will use 2*3 mm + 8 mm plexi instead 2*8mm.
There are also new PSU mounting and MBO tray. Changes are mostly estetical,but PSU mounting now support rubber inserts under the PSU if they are needed.
__________________
Old 11th Jan 2013, 19:53   #67
siliconfanatic
MEGAGASP
__________________
Old 11th Jan 2013, 20:00   #68
Pranja
Fenrir The Wolf
Pranja's Avatar
MEGAGASP
Well,I don't know what that means,but Google says this: " The act of opening the mouth convulsively to catch the breath; a labored respiration; a painful catching of the breath."
So, thank you!
__________________
Old 22nd Jan 2013, 08:13   #69
GamerIDGoesHere
www.^.com
GamerIDGoesHere's Avatar
GamerIDGoesHere has yet to learn the way of the Dremel
This looks very cool, even the prototype looks awesome
- Dan
__________________
modbot - In Progress
GamerIDGoesHere is offline   Reply With Quote
Old 22nd Jan 2013, 08:16   #70
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Brilliant work mate, love the new revisions
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 22nd Jan 2013, 09:03   #71
Pranja
Fenrir The Wolf
Pranja's Avatar
- Dan
Thank you Dan. Nice to hear that you like it.
Thank you. If you love this-wait until you see final design. I changed it so it can be cut on smaller CNC machine, so now everything is going to be 100 % work of me and my friend.
What you see above is version 3-pics of version 4 will be uploaded today.
__________________
Old 23rd Jan 2013, 16:12   #72
Pranja
Fenrir The Wolf
Pranja's Avatar
Hi everyone!
As promised-here is the new Scorpio. I compared this new model with first one and you cas see what is different-case is lower,shorter and has different organization of components.
Now I have more space for bigger components in smaller case. For example,I now I can put 32 cm long GPU's inside.
As you can see, I never stopped to develop this case, and I am happy to announce start of production next week.
__________________
Old 23rd Jan 2013, 21:52   #73
siliconfanatic
yeah, i have a tendency to recycle memes cause I'm a tad lazzzzzy
But, please, please, PLEASE tell me you just omitted fan models for simplicity's sake. Still looks epic, and the beefier hardware potential just made my head 'fatboy itself
__________________
Old 23rd Jan 2013, 21:57   #74
Pranja
Fenrir The Wolf
Pranja's Avatar
Well, yes, I was a little bit lazy to put fans on the model.
Don't worry,they will be on the actual case.
And because I know you want to see new Scorpio with the fans, you will get it. And also final color scheme of the case.
__________________
Old 23rd Jan 2013, 22:00   #75
siliconfanatic
you know me all too well, my friend.
__________________
Old 26th Jan 2013, 16:37   #76
Pranja
Fenrir The Wolf
Pranja's Avatar
@siliconfanatic:
Here is something for you mate-final color scheme and fans.
I have chosen transpern-black plexi color scheme. I think it will look great like that.
Also,CNC will start work on case very,very soon so there will be sone nice updates.
__________________
Old 26th Jan 2013, 18:12   #77
Editor22
E22.BIZ
Editor22's Avatar
Wow it looks stunning great job mate
__________________
Store: E22
Old 26th Jan 2013, 19:13   #78
Pranja
Fenrir The Wolf
Pranja's Avatar
Thanks mate.
I can't wait to show real thing. These renders are best I can do for now.
__________________
Old 26th Jan 2013, 19:50   #79
Razarach
Multimodder
Razarach's Avatar
Razarach has yet to learn the way of the DremelRazarach has yet to learn the way of the DremelRazarach has yet to learn the way of the Dremel
Damn, this would be one awesome case. Can't wait final product.
Razarach is offline   Reply With Quote
Old 26th Jan 2013, 20:07   #80
Pranja
Fenrir The Wolf
Pranja's Avatar
Hvala.
I ja isto ne mogu dočekati da krenem sa sklapanjem.
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
