#1 |
< Your add here >
ZdMods - Project 180 - Update 2.6
Now that I've almost finished Project pǝʇɹǝʌuı (new GPU arrives today!) I've started on a new mod, which I'd like to share with you. This time not a scratch build, but a rebuild of an exisiting case, the Antec P180. Why this case, well simply because I had it sitting around after building Inverted. Currently the hardware is outdated: Intel Q6600, 4Gb Ram, Radeon 6870. So I'll buy new hardware along the way of the build. Picture time! Standard Antec P180 housing Again I'll be using 25x25mm aluminum tubes Cut away parts of the original front to make room for the alu tubes All alu bars in place, 3mm transparant plexi in between Finished the top and bottom with a alu strip Testfit of the front I want to put 2 fans in the front that will draw air from the bottom of the front through the tubes. They won't be able to breathe much, but hopefully enough for what I want to do Sketchup of the fan cutout in the front This is what it looks like so far, the 2 outer tubes still need to be cut That's it for now... ![]() Last edited by Meelobee; 2nd May 2013 at 07:24. |
#3 |
Fenrir The Wolf
Looks really nice, I like it.
Good idea with the tubes.
#4 |
Supermodder
Great idea, and fits very well with the part of the front which remained
__________________
HTPC Onkyo style Log -- cosmod -- alien hospital -- i-spider Log -- chemical overdose Log |
#5 |
________
That front door looks sweet as...
#6 |
Multimodder
very nice as always!
__________________
Inverted 600T - OCN Mod of the month July 2012 CM Test Bench V2 - Cooler master mod competition 3rd prize Rig of The month December - Guru3D Nice articles of the test bench: Here and here |
#7 |
The modding head is firmly back on.
I love the look of that front. That is going to look really good when it's done.
As for the fans, you'll be surprised at just how air flow you will get. There are no filters or other obstructions to impede the air. So it shouldn't have to much of an affect. |
#8 |
Rep whore/ Car lover/ Speed Junkie
that front. industrious-looking. aggressive yet sleek..
10/10! love the idea for creating airflow! where are the words to describe this?!
__________________
Hard to explain to someone who has no clue. Or doesn't believe you. It's a daily struggle being in pain or feeling sick on the inside while you look fine on the outside. Please put this as your signature for at least 1 hour if you or someone you know has an invisible illness (Pancreatitis, Crohn's, PTSD, Anxiety, Bipolar, Depression, Diabetes, LUPUS, Fibromyalgia, MS,Lupus, ME, Arthritis, Cancer, Heart Disease, Epilepsy, Autism, etc.) " Never judge what you don't understand. |
#9 |
Multimodder
Wow this is looking good
#10 |
Supermodder
Great originals idea subbed looking forward to where this goes
![]() Sent from my Nexus 7 using Tapatalk HD
__________________
Got the mod bug bad project dmx lighting overkill http://forums.bit-tech.net/showthread.php?t=231790
#11 |
< Your add here >
Thanks for the great replies everyone
![]() I've done some more work on the case: First I've finished the front, the fans are now countersunk into the tubes There were some damaged area's on the plexi which I filed down, before: After: Fans fitted Front on the case I've bought some pieces of alu sheet to replace the front, back and midplate of the case. Took the case apart, the white sheets on the left are the new alu parts After cutting the front and back there wasn't much of the original material left Made the front sheet to size And bolted it all together again Last edited by Meelobee; 2nd May 2013 at 07:25. |
#12 |
Making You Feel Old Since 2010
This is just awesome! Love the front panel!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2) "The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181 |
#13 |
quick tip, you might want to get rid of the front part of the fan shroud as, when you shoved em in you created what my mind sees as a severe hindrance to the airflow, because as far as the fans are concerned, the bar/tube thickness just got halved, which halves the amt of air they can getwas also halved... the other option is to un-sink them a tad. correct me if i am wrong, a few red flags just flew up in my head. still great idea, gives me even more ideas for getting more air into my case.
__________________
#14 |
Keep calm & mod on. =)
About time I subscribed to this, looking nice so far Meelobee.
![]() Acrylic aluminium cheesecake sandwich.
#15 | ||
< Your add here >
Thanks
![]() Quote:
![]() Quote:
![]() Had some time to work on the case this weekend, first I've put the original I/O panel into the midplate. Then I've cut 2 bars to replace the top piece of the case. To still be able to slide in the sidepanels (the panels have small hooks) I had to cut 3 rectangular holes in the side of each bar The 2 top bars sit on L shaped pieces attached to the front and back of the case With the sidepanels on it's all flush and straight ![]() I've polished the strips on the top and bottom of the front with Commandant #4 after sanding them to P800 Last edited by Meelobee; 2nd May 2013 at 07:25. |
#16 |
still thinking....
Terrific work Meelobee!
__________________
stillthinking |
#17 |
< Your add here >
Thanks alot Attila
#18 |
________
#19 |
i might've missed something
, but are you, say, gonna light up the acrylic, or do something flip-out crazy awesome with it
__________________
#20 | ||
< Your add here >
![]() Quote:
| Thread Tools | |
| View Mode | |
