Reply
Thread Tools View Mode
Old 14th Jun 2013, 02:44   #1
quizz_kid
Squid
quizz_kid's Avatar
quizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on you
Revelation (2/12 Final photos and video!)
Revelation
While the R-Kaid-R project is on hold, I must have something to do. Sooooo I decided to start my biggest project ever. The concept of the Revelation is basically a huge game archive. This is truly my biggest project so far, and itís going to be one hell of a machine. Some features:
- A dual gaming system with two boot options. One with a more classic approach containing all the game systems pre 5th generation, with a customized version of the frontend Maximus Arcade. The other boot is for modern and more demanding PC games.
- An intergrated 500 ANSI LED projector
- A transparent 22Ē LCD that will, while having the function of a regular monitor, also display a beautiful water cooled PC system underneath.
- A decent soundsystem
- A turning foot stand
- Two wireless joystick gamepads, stored and intergraded into the main console like pulling drawers in the front.
- A modified wireless wooden keyboard/mouse setup that will rest upside down on top of the chassis when not in use.
The color concept will be black stained walnut, black and copper, so thereīll be a lot of wood working and some finer copper processing.
Here is a very rough low res sketch:
Planning:
There's a lot of stuff going into this build, so the construction have to be optimal. It was a real pain to design it, and took me over 3 months. The case will be divided into two segments, vertically.
PC Specs:
CPU: Intel i5 3570k
Motherboard: MSI mitx Z77IA-S01 Inet Edition
PSU: Be Quiet! 550w
RAM: Corsair Dominators 2x4GB
SSD: 2x Corsair 240gb disks
GPU: ZOTAC GTX670 AMP! 2GB
Water cooling:
CPU: Alphacool NexXxoS XP≥ Light - Acetal Edition
GPU: Alphacool NexXxoS NVXP Nvidia GTX680
Pump: Alphacool DC-LT Ceramic - 12V DC Pro with plexi top
Radiator: Alphacool NexXxoS ST30 Full Copper 360mm
Res: Alphacool Cape Corp Coolplex Pro 10 - Copper Edition
Fittings: Alphacool shiny copper
Fan cooling: 7x Be Quiet! Silent Wings 2
Additional:
Keyboard: Logitech K810
Projector: LG PB60G
LCD: Samsung transparent 22Ē display
Joysticks: Ultimarc J-Stiks
I'm gonna try to make this a quick one, since I only have access to the workshops til the 15th of July. We'll see...
A big thank you to the sponsors:
Hope youíll like it!
//Quizz
__________________
Tempel / Revelation / The Shrine / REDELUX / 4M
Follow me on facebook or Instagram
https://www.facebook.com/lovehultenau
@lovehulten
quizz_kid is offline   Reply With Quote
Old 14th Jun 2013, 02:45   #2
quizz_kid
Squid
quizz_kid's Avatar
For more final pictures, see page 10.
Video demonstration(Music credits: Turrican scores performed and supported by Chris Huelsbeck)
Making of video
__________________
@lovehulten
Old 14th Jun 2013, 02:46   #3
quizz_kid
Squid
quizz_kid's Avatar
So, let's get on with the processing.
I started by cutting some walnut
Glued them together for the side panels
Some other pieces were made for the bezel of the LCD
Pieces planed and flush
This is after some cutting. You can see I've been using laser for some of the details here. Then I drilled three holes in each piece from below, using a long 5mm drill. After that, I had to seperate the panels in 3.5ļ angles, so I used a dimsaw. I will have m5 inserts in the upper segemet to secure it all together. More about that later.
Here is the start of a foot stand. I used MDF and made a 800mm long piece, about 30mm thick.
Some dimsaw cutting, and I had eight pieces of cake =)
Put some old veneer on those
Well, youíll get the idea
Then I started on some laser cut detail pieces. The laser can only go about 4mm deep into solid wood, so removal of material is a must.
You can see the fancy stuff in this picture, which means that Iím almost through.
Laser cut stuff in a pile
Close up. This piece right here is for ventilation in the lower case segment.
On to some metal work. To support the machine, the turning foot stand has to be very stable. I chose a simple solution for stability and weight, solid steel.
This is after some welding and turning.
And after some sandingÖ a perfect fit! This construction will be mounted under the wooden octagon later on.
Made some mountings for the radiator, which will be placed on the back of the console later on.
2mm steel bended in a 13ļ angle
Over to some copper processing and started on some knobs for fan control and other things.
The result.
This piece right here is for the projector. Sort of the eye of the console I guess.
For the water cooling I'll use 15mm copper piping, and these are the fittings.
I tried some pipe bending, but my pipes are too brittle, so Iíll just use pre-bent 90 fittings instead.
And here are some of the components going into this beast:
Intel i5 3570k processor. Thank you Intel
MSI mitx Z77IA-S01 Inet Edition board. Thank you Inet.se
ZOTAC GTX670 AMP! 2GB. Itís a beauty. Almost a shame to put a block onto that one. Thank you ZOTAC
7x fans and 530W PSU. Thank you Be Quiet!
Water cooling goodies, more about these later. Thank you Aquatuning and Alphacool
8GB RAM and 2x256GB SSDs. Thank you Corsair
For the keyboard mod Iíll use a Logitechs Bluetooth illuminated K810
And this is the transparent 22Ē display. In order to function itíll need light from behind, so Iíll work with that as well later on.
//Quizz
__________________
@lovehulten
Old 14th Jun 2013, 07:07   #4
dipzy
Supermodder
dipzy's Avatar
dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.dipzy is definitely a rep cheat.
i do like it, want to see more
Congrats on the awesome sponsors by the way
dipzy is offline   Reply With Quote
Old 14th Jun 2013, 08:39   #5
Sn00k3r
Modder
Sn00k3r's Avatar
Sn00k3r has yet to learn the way of the Dremel
Yeah Baby!
i love your Mods and your craftman skills, can't wait to see more..!
Sn00k3r is offline   Reply With Quote
Old 14th Jun 2013, 10:58   #6
LegendaryScott
Trying to live up to the name
LegendaryScott's Avatar
LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.LegendaryScott is the Cheesecake. Relix smiles down upon them.
SCRATCH BUILD PORN!!
Cant wait to see more
LegendaryScott is offline   Reply With Quote
Old 14th Jun 2013, 11:02   #7
Phame
COOOOFFFFEEEEE
Phame's Avatar
Phame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpit
You are a boss!
Phame is offline   Reply With Quote
Old 14th Jun 2013, 11:31   #8
dombooth
Minimodder
dombooth has yet to learn the way of the Dremel
Should look great.
Dom
dombooth is offline   Reply With Quote
Old 14th Jun 2013, 11:52   #9
Asouter
Asouter's Avatar
Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.
Thanks Quiz Kid, it's a breath of fresh air to see that you have got the sponsorship, Looking forward to seeing this progress
__________________
Finished Projects : D33P THOUGHT : THING : Mini Moto Mayhem
Current Project : BITZA
Asouter is offline   Reply With Quote
Old 14th Jun 2013, 11:53   #10
Overminde
Multimodder
Overminde's Avatar
Overminde has yet to learn the way of the Dremel
me likey im in for some more :P
__________________
Urban Camouflage
Overminde is offline   Reply With Quote
Old 14th Jun 2013, 12:10   #11
hairyknacker
Multimodder
hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.
Quizz
I just luuuuurve you stuff and will be watching intensely
Will u be using emulators for the 360 software- would be most interested if you are
hairyknacker is offline   Reply With Quote
Old 14th Jun 2013, 12:19   #12
Vetalar
*learning english*
Vetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming Saiyan
excellent! 5 stars from me
__________________
10 re-plan "SuperBestBuild Of My Dream"
20 have a sleep
30 goto 10
Vetalar is offline   Reply With Quote
Old 14th Jun 2013, 14:02   #13
Darkwisdom
Level 99 Retro Nerd
Darkwisdom's Avatar
Darkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming Saiyan
Looks great. I guess you're becoming famous as a modder; those sponsors are quite impressive.
I did like your sputnik 0667 mod with all the integrated keyboard and monitor so it'd be nice to see how your skills have progressed since that one.
__________________
Main Rig: i3 3220 ~ GTX 970 Strix ~ 8GB Vengeance Ram ~ EVGA Supernova G2 750W ~ P8H77-m le ~ Samsung 830 128GB SSD ~ Steelseries GCv2 ~ Razer imperator ~
Darkwisdom is online now   Reply With Quote
Old 14th Jun 2013, 15:01   #14
siliconfanatic
Johny-come-Lately
siliconfanatic's Avatar
siliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyan
Seems the spring flood of noobs is coming in.
Looking real good, quiz. Nice Idea with the transparent lcd.
__________________
Do not let anything good in life pass you by. Cherish it with all of your heart, because before you know it even life will have passed you by. And if you let all those things pass you by? The only thing filling your heart will be deep sadness and regret. So whatever you do, hold on, and never let go.
siliconfanatic is offline   Reply With Quote
Old 14th Jun 2013, 15:05   #15
Pranja
Blackwolf
Pranja's Avatar
Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.
Another spectacular project from quizz.
Pranja is offline   Reply With Quote
Old 14th Jun 2013, 18:24   #16
Glyph
What's a Dremel?
Glyph has yet to learn the way of the Dremel
I can't begin to say how much admiration I have for all your work! Just incredible! :O
Glyph is offline   Reply With Quote
Old 15th Jun 2013, 00:28   #17
quizz_kid
Squid
quizz_kid's Avatar
Originally Posted by Sn00k3r View Post
Yeah Baby!
Originally Posted by Phame View Post
You are a boss!
Originally Posted by dombooth View Post
Should look great.
Dom
THank you guys, much appreciated!
Originally Posted by hairyknacker View Post
Quizz
Thank you. Well, I'm not sure if I can emulate 360, but this machine will have most of the systems out there, that's for sure =)
Thanks Wisdom! Yes, the references to my first build are many, glad you noticed. I'm also very curious how this one'll turn out.
Thanks Silicon! Transparent LCD, that's from the future, right???
__________________
@lovehulten
Old 15th Jun 2013, 00:49   #18
quizz_kid
Squid
quizz_kid's Avatar
This is the small projector I'll be using for Revelation. It's the LG PB60G, and it's a very bright little beamer with its 500 ANSI
... and of course I had to open her up and see how she looks on the inside.
Because of the position of the lens, I won't have acess to the focus dial when centered. So I'll have to make some kind of extension. This is where LEGO technic comes very handy =) More about this later
Woodwork of today:
Drilled a lot of holes today. Due to some sparse dimensions, I figured I had to use 4mm dowels connecting the differnet pieces.
Here are the the parts for the lower section that'll house beamer and foot stand.
When drilling holes in the side panel parts, I made a simple 3,5ļ jig...
... and just slided the pieces in there. Very efficient!
Here are the three ledges that'll keep the upper structure together for now. They are tiny, and might look simple from above...
But as you can see, I've put a lot of work into these looking at the profiles.
Then I used a router for some inner sliding tracks.
From above.
Then I dry fitted the construction with dowels, just to get an idea of how it'll look like later. This is the lower section.
Upper section.
Sections mounted together
Another angle.
More to come
__________________
@lovehulten
Old 15th Jun 2013, 01:25   #19
Attila
still thinking....
Attila's Avatar
Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.
Hot damn! Lovely work and beautiful timber kid.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 16th Jun 2013, 00:04   #20
quizz_kid
Squid
quizz_kid's Avatar
Thank you Attila, appreciated! Yeah, these walnut pieces are really something.
Todays work:
Continued on the foot stand today. Started by removing a lot of material below...
Had to make some special tracks because of my n00b welding skills
Put the steel construction in there and drilled som holes for wood insert nuts later
Made a cove on top and a small chamfer below, for a nice touch,
Here it is... I'm quiet happy with the result. I will paint the lower steel construction later, black I think. Or copper perhaps.
Then I started on the framework of the LCD. Made these 12mm thin walnut pieces and started to cut.
I usually complicate things, for the fun of it, and this is no exeption. I wanted the bezel to follow the angle of the side panels, and then make it a bit curved for a retro touch. Here's a simple jig for the dim saw.
After a lot of trial and error I finally got it right. These small angles everywhere are a pain.
Then I draw some lines for the curves and started sanding.
The two side pieces have the same angles, so I just taped them together for the mirror effect.
Pieces with curves.
Used the router for some round overs and then added some dowels
Glued under pressure.
Put it through the sanding master and got it down to exactly 10mm. Framework complete. Here's a dry fit.
It's hard to capture the small angles in photos due to the lens effect, but here's the bezel illustrated for a better visual.
Bezel corner, close up.
Here's a picture from the back where you can see that the bezel fit right into the sliding track I made yesterday.
Laterz!
__________________
@lovehulten
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
