Modding Project: Flightline
Discussion in 'Modding' started by slipperyskip, 29 Oct 2013.
  1. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Flightline is an Art Deco sunburst design inspired by the architecture of the Wright Brothers Memorial at Kill Devil Hills, North Carolina. The case consists of 167 pieces of hand-cut maple and mahogany veneer laid over a frame of lacewood and aircraft-grade birch plywood.
    The thin mini-ITX motherboard used in this project is made specifically for All-In-One (AIO) PC designs. My idea is to use it in a case designed to accentuate the thinness of the board. At 40mm Flightline is not thin by laptop standards but you have to consider that it is using a desktop Intel Core i7 processor instead of a mobile unit.
    My good friend and renowned veteran tech journalist Alfred Poor provided the initial inspiration for this project. His grandfather designed the Wright Brothers Memorial. Alfred has been a member of my trusted "Insiders" group for over ten years and is one of the reasons I enjoy some success at this hobby. Thanks Alfred!
    Final photos:
    Larger Version
    Larger Version
    Larger Version
    Larger Version
    Larger Version
    Larger Version
    PROJECT LOG:
    After a 20-hour work marathon I put together this chassis.
    18 pieces of wood assembled onto a 1/16" sheet of birch plywood. The wood is all basswood (AKA lacewood) except the darker center piece. That is 1/4" thick maple.
    Many of the boards, including the maple, are simply to stiffen the structure. 1/16" (1.6mm) plywood is easy to work with and keeps the project thin but needs a little help to prevent flexing.
    Gigabyte offers three thin mini-ITX models This is the high-end H77 chipset version.
    One of the tricks in keeping the board thin is use of laptop-style SODIMM memory
    The thin mini-ITX I/O shield is exactly 1/2 the height of a standard ATX standard I/O shield. Some board makers include a full height shield to use in a standard chassis.
    If you installed a "normal" heatsink onto a thin mini-ITX board it would no longer be thin. Intel makes this heatsink and AFAIK it is the only such product on the market.
    The heatsink uses a blower instead of a more common axial fan. Blowers are typically noisier and less efficient but Intel spent some serious R&D on this bad boy. This is the first blower I have ever worked with that allows air intake from both sides simultaneously.
    The backside will remain virgin. No screws, holes, paint. Nothing. This will match up to a similar surface in the cover.
    Adding more material to complete the base structure.
    Though it looks like a horizontal-stepped base it is actually made by building vertical steps.
    I call them reversing pinwheel butt joints. Each layer reverses direction of the joints and cause them to stagger back and forth across each other. Engineered strength. Veneer will hide the crudeness of the butt joints.
    1/16" x 1/32" mahogany strips hand-cut from sheet stock.
    Some burl inlay work.
    Snapshot of my veneering work space. 167 pieces to cut.
    So after a crazy number of hours here are 70 pieces of veneer cut, glued and sanded.
    It will look better when there is contrast between the different woods. Raw, sanded wood tends to be a bit dull.
    Normally I would build a box and then apply veneer but maple is very difficult to work with (for me). I decided to veneer the sides first so I could bring much more clamping pressure to the surface. You gotta bring the pain.
    I estimate this project to be at 65% complete...
    I can't wait to start the wood finishing.
    Adjusted the contrast to get some color into it.
    Cut out the blower intake duct. Still have the back panel veneer to apply.
    Framed up the blower inlet and fit it with mesh.
    Just taking pictures of it while it has no finish. I didn't even brush off the sawdust for this shot.
    Working on the rooftop vents. Five mesh screens.
    Testing out the amber shellac and styling a shiny bit.
    I estimate this project to be 80% complete.
    Sanded back the tint leaving enough behind to get contrast.
    Looking for a good compromise on the burl tint.
    Almost finished with the vent. Around 30 pieces of maple veneer will cover the roof. I'm up to number 7. :)
    Working on the top vent.
    Working on the final bits....
    Wired up the power switch that I positioned on the I/O plate right next to the power jack. Sleeved the power cable and the blower cable. Those are the only wires. :)
    The base is hollow and now painted.
    Used aluminum paint on the rear framing and...
    ...lava grey paint on the rest of the interior except....
    ...the back of the motherboard tray is left natural birch with a couple of coats of lacquer to protect it. I can't paint this piece because it slides directly against the interior of the cover. I can't veneer it either because the tolerances are too close.
    Finished up the exhaust vents.
    A sneak peek at the finished quilted maple
    Specs:
    Gigabyte GA-H77TN Thin Mini-ITX Motherboard
    Intel i7-3770K Ivy Bridge CPU
    Intel HD4000 Graphics
    Intel HTS1155LP Heatsink/Blower
    Intel Lincoln Crest 240GB mSATA SSD
    Kingston HyperX 8GB DDR3 1866
    Thanks for looking!
  2. Cheapskate
    13 May 2007
    Read through carefully for the second time. -Still love it.:D
  3. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    this... is... perfect!!!
  4. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Glad you think so!
    Found a tasty piece of mahogany and cut it to size. The piece is 1/32" (.8mm) thick.
    Carved out the openings using my trusty Japanese razor knife.
    Just showing off. Notice the distance to the edge on the audio ports. Those holes were not made by a drill.
    Thanks for looking.
  5. bulldogjeff
    2 Mar 2010
    Oh yes, I do like this one, especially that top section.. Top modding yet again Jeff
  6. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Thanks Jeff! The base was originally suppose to be black granite. I've been wanting to do some stonework for some time. Life got in the way of a lot of things for me this year including this. :sigh: Stumbled across the finish line in August but lately I have been working on a few details like the I/O plate work.
    Here is a video with me doing the human lazy susan thing. Watch to the end to see the cover removed.
  7. landspeeder95
    landspeeder95 What's a Dremel?
    11 May 2010
    Your work leaves little room for comment – other than thanks for continuing to share.
    I LOVE seeing every piece of art you produce.
  8. asura
    asura jack of all trades
    22 Apr 2009
    Increadable marquetry, and probably the worlds most beautiful thin client! I love it! Had you considered lavikite for the base rather than granite? It's much more atractive and less boring :geek:
  9. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Thanks! I appreciate that.
    Thank you. I had to Google that material. Looks interesting but I suspect it is difficult to work with. Granite is also difficult but there is a lot of expertise out there right now because of the popularity of granite countertops.
    In the end I had to finish it with what I had on hand. I almost had enough black walnut. Here are a few Sketchup renders I did before starting work. It is my first SU drawing so forgive me.
    I believe this is called parquetry. Marquetry is more of the artsy decorative organic shapes while parquetry is the geometric stuff. I made the mistake of calling it marquetry on one of their forums and they tore me a new one. :duh: Sheeesh
  10. Arboreal
    21 Jan 2011
    Once again I'm in awe of your "wood engineering" (as coined by my 4 yr old nephew!) skills.
    Great to see you back on BT, was worried when you bowed out of the NUC competition-hope things are ok for you.
    I thought this was good for starters, then felt the original i/o plate colour scheme was a let down and not in keeping.
    You must have read my thoughts, as the next thing that happened was you creating just the right thing in mahogany.
    I'm a sucker for ITX any day, and thin ITX in an upright box is the business! (only seen flat implementations of this so far, which are so uninspiring).
    Always so pleased to see someone with an affinity with wood; something that I just don't have, or the confidence to develop woodwork skills.
    Keep up the good work
  11. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Thanks Arboreal! I'm a firm believer in the idea that you can over-stealth a project. That comes from my experience displaying at CES where I spent considerable time answering the "What is it?" question. There is nothing wrong with leaving a few clues so that the casual observer can figure it out for themselves. Being part of the goof instead of being goofed on sorta thing.
    Flightline is competing in the Cooler Master contest and it'll need all the help it can get. I knew the mahogany cover-up plate would be a positive thing. After thought? Yes but I'm up against entries that are sponsored by Cooler Master.
    One way to help my cause is to improve my photography. I have invested in a new larger light tent and have been doing some testing...
  12. Cheapskate
    13 May 2007
    The 'what is it?' question is a mark of success in my opinion.
    If voting is involved, there will be a slant toward facebook campaigners too.:(
    I can't really see an improvement at this resolution, but feel free to post more porn.
  13. slipperyskip
    slipperyskip Member
    26 Oct 2003
    You are going to regret saying that. :D
    On the topic of wood aging over time, G-metric Nano is my most dramatic illustration of that.
    2008....
    I didn't foresee the contrasts of the geometric design changing so much. I feel like the guy who planted the tree too close to the house. "Looked good at the time."
  14. slipperyskip
    slipperyskip Member
    26 Oct 2003
    The center of the "What is it?" controversy...
    I remember ten years ago shopping on eBay for a cheap collection of fountain pens to use as props. The only pen of any real value is the red one. It is an Esterbrook.
    My mama once told me "When all else fails...cheat". :D :thumb:
    Off-topic photos clogging up your screen? Blame Cheaps.
  15. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Don't make me use puppies. Happy Holidays!
  16. slipperyskip
    slipperyskip Member
    26 Oct 2003
  17. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    Love them all, thank you sharing again!
    Could we maybe see an art deco steamOS box, since steamOS is still a big buzz.
  18. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Thanks! My site has been getting a lot of traffic lately from Steam Box talk-talk. Mostly from reddit. I'm just amazed at the level of ignorance out there about mini-ITX boards.
  19. TheMadDutchDude
    23 Aug 2013
    That is some amazing work! Love it! :)
  20. Burnout21
    9 Sep 2005
    They use to be really hard to get hold of, and generally didn't support anything interesting due to not being able to pump decent voltages to power hunger CPU's, etc.
    But you avoided my request, lol! Art Deco steambox!
