Case Mod - In Progress [project] the G5-yufi - done !
Discussion in 'Project Logs' started by thegyufi, 10 Dec 2013.
  1. thegyufi
    thegyufi What's a Dremel?
    21 Mar 2011
    Hello Bit-Tech ! :dremel:
    After more than one year since my last project based on an Apple Cube, I started another one bigger based this time on the well-known Apple PowerMac G5 !
    If we like or not the brand with an apple, I think the design of this case leaves no one indifferent !
    Let's the party begin ! :dremel:
  2. thegyufi
    21 Mar 2011
    First Update !
    I started on the front of the case, by creating a new entry for a slot-in drive, it took me a lot of time for this but I'm quite happy with the result
    First aff all, some line on autocad, to be sure of what I'll do !
    then the drawing
    somes holes
    with some little files
    result
    cut
    temporary support of the new slot
    and, the cut on the case :dremel:
    installation of the new slot on the case
    and gluing with the epoxy
    and, drill all the little holes with the help of a guide
    When it's done, we take off all the parts to clean them
    and we put it all together with some epoxy mastic
    when it's dry, we sand
    and again some drilling to unclog holes filled product
    little spray paint to have an idea of the result
    this part is finish !! All your comments are welcome !
    The next update will be on the front panel
    Stay around ! :lol:
  3. MattoDaLegare
    MattoDaLegare What's a Dremel?
    7 Oct 2013
    Very good start. :naughty:
  4. Nikozii
    Nikozii What's a Dremel?
    29 Oct 2013
    Stunning work. Respect!
    Continue! :thumb:
  5. TadZilla
    TadZilla tadbitnerdy
    5 Nov 2009
    Amazing work! I've always wondered how people make these slots themselves. Great guide!
  6. stuartwood89
    20 Aug 2008
    Nice work. Continuing the holes to make it look OEM is always a good plan with these cases. Most others just bolt stuff to the front/back.
  7. longyny
    longyny What's a Dremel?
    8 Aug 2012
    Amazing work dude! Waiting to see more stuff
  8. thegyufi
    21 Mar 2011
    Second Update !!
    This time, it's about the integration of a USB 3.0 frontpanel .
    As I done for the slot, I begin with some lines on Autocad
    then some drawing and cutting
    and I cut the case :dremel:
    the two parts ready to be assembled
    after some sanding
    drilling
    some painting to check the result
    then we continue on the support of the frontpanel, my goal was to make it invisible from the outside of the case, so it take lot of time and holes !
    first, find some space to drill holes ont the frontpanel
    the same on an aluminum corner
    after many steps this is what I got, I think this part is not so clean than the other, because I redrilled all the holes in 3,5mm (instead of 3,0mm) to try to hide this support.
    then we glue the support with an exoxy glue
    and this is the result after some finishing
    The next update will be about the integration of the lian li hotswap rack !
    Stay around :lol:
  9. mav2000
    mav2000 In Training
    16 Oct 2010
    Awesome work man....just beautiful
  10. MegadetHCl
    MegadetHCl What's a Dremel?
    8 May 2004
    I hope you did not short that PCB on the aluminum support :)
  11. Nexxo
    23 Oct 2001
    Finally someone who respects the holeyness :)p) of this case and doesn't just cut huge chunks out of it. Great work! :thumb:
  12. Cheapskate
    13 May 2007
    Glorious work. :D I love how much work you have put into making this full retooling almost unnoticeable.
    @Nexxo- Ow...
  13. stuartwood89
    20 Aug 2008
    Couldn't agree more. I'll be taking a leaf out of this book when I get round to doing my G5.
  14. Darkened
    Darkened Minimodder
    28 Feb 2004
    Now this is what a G5 mod is supposed to be!
    I've never seen anyone take such an approach this far and I sure hope you'll have the strength to pull out all the stops all the way.
    I'll definitely be watching this one.
    Darkened
  15. thegyufi
    21 Mar 2011
    thanks a lot friends for all your kind comments, it really helps me to keep my motivation !!
    Update!! SSD's @home !!
    Admire what the Santa Claus brought to me !!
    Two beautiful Kingston's drives SSD HyperX 3k :jawdrop:
    Ok my rabbits, let me take a few more pictures of you !
    Their finition is just perfect, these ssd got a look so classy while remaining sober, they smell good the quality as usual !! :clap: It will be very hard to wait until the project is finished !
    Stay around ! :lol:
  16. thegyufi
    21 Mar 2011
    Hi here !
    I'll probably post this afternoon some pictures of the psu during unboxing and some more progress with the hotswap rack !!
  17. thegyufi
    21 Mar 2011
    Update !!! PSU @home !!
    The superb P-760 Hybrid by Seasonic has arrived safely, and visibly the travel was good !
    Let's start the show !!
    jolie assortiment de câble :D
    et la voilà... vraiment bien protégé dans sa jolie pochette en velour tout doux [:bakk3]
    and one last picture of the family
    The PSU and the packing reflects the quality that we know of Seasonic ! ;)
    Next update will be about the integration of the hotswap rack !
    Bye!!
  18. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    Great work there. Shows a lot of respect for the original design, which is what mods should be about IMO.
  19. gardnerphotos
    gardnerphotos What's a Dremel?
    2 Aug 2013
    just awesome!
  20. thegyufi
    21 Mar 2011
    Update !! about the installation of the HDD rack
    first, remove all I don't need !
    for the integration I reversed the bottom with the top
    Some M4 tapping
    then the cut of the separating plate
    Little Picture of all the parts
    and, installation of all this parts
    That's all ! Next update will be about the creation of the support for the 2x140 mm Prolimatech's fans !!
    :dremel:
