Scratch Build – In Progress The Tempel - Thank you guys!
Discussion in 'Project Logs' started by quizz_kid, 23 Dec 2013.
  1. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Hi guys, I'm back with a big project.
    THE TEMPEL
    I'm in need of a workbench, a place where I can focus dealing with electronics and modding.
    The design of this bench is inspired by classic bureaus with a folding deskop. When opened, it reveals the inside; a perfect workspace for me as a hobby electrician and computer modder. It will store all the tools and equipment needed, and most of the stuff will be integrated into the furniture itelf somehow(soldering iron, multimeter etc) In the heart of Tempel, I will install a water cooled m-itx system based on my needs. The desk will also host a pop-up hidden 24" LCD display, using a linear actuator lift from within the construction. With its 25 pull-out drawers, it's also a great storage unit for all of my smaller electronics and tools.
    I guess Tempel is sort of a new improved version of my first PC build Spunik 0667, somewhat...
    There's going to be a lot of wood working in this log. Just a heads up for those not interested in wood builds.
    Hardware:
    MB: ASRock H77M-ITX
    GPU: Not decided yet
    HDD & SSD: 1 TB Samsung and 240GB Corsair
    RAM: Corsair Dominators
    PSU: Cooler Master modular V700
    Water cooling:
    CPU block: Alphacool NexXxoS XP³ Light - Acetal Edition
    Rad: Alphacool NexXxoS ST30 Full Copper 120mm
    Pump: Alphacool VPP655 with plexi top
    Res: Alphacool Cape Corp Bullseye
    Fittings: Alphacool
    Additional:
    Slim slot-in disk unit
    A decent soundsystem
    Samsung 24" screen
    For the hidden pop-up monitor I'll use this 12V Linear actuator
    Here's the Samsung 24" screen
    A big thank you to Cooler Master for some help with PSU and fans!
    Also, a big thank you to Aquatuning once again for supplying me with the water cooling!! Man, I just love the bullseye res!!
    Guinevere likes this.
  2. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Finals
    THE TEMPEL
    Front, lid closed
    Lid opened
    Monitor lift up-up-up!
    There we go.
    With built in lighting turned on
    Another shot, in the dark
    The lock serves as a lighting switch. Turn the key, and you'll have a solar system glowing from inside the circular window.
    Close up, solar system
    Close up, end grain key hole
    The lighting reflects on the small brass domes and creates a really nice effect.
    Drawers...
    More drawers...
    A close up of the stained ash grains.
    Behind the screen is a modular tool wall for smaller tools
    Here's the right panel. It got a built-in soldering station, analog multimeter and R speaker.
    Soldering iron inserted in stand with magnets
    Here's the multimeter in action, sort of.
    The modified soldering iron, tailored for the sake of the brass theme
    On the left panel we've got L speaker, HDMI out-in, phones input, light switch+dimmer, disk reader, fillport+res, USB 3.0 x4, amp with volume+tremble+bass, disk eject, start button and finally a switch for the monitor lift.
    Close up, res in action... The cape corp bullseye res sure is a beauty!
    And here's a little video showing monitor lift and res in action. Sorry about the quality.
    http://www.youtube.com/watch?v=CgN5YF4-DJM&feature=youtu.be
  3. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Basic woodwork, cutting pieces and veneering. Quite boring this process actually...
    The grains I'll use for this build are ash and walnut combined.
    First, cutting some 19mm MDF with slices of ash added.
    Cutting and planing the veneer pieces. Yep, there's lots of them...
    After gluing under pressure.
    One of the side panel's getting ready for some veneer.
    For the main worktop I've made a part in ash, embedded into the MDF. But more about that later...
    Worktop ready for veneer.
    Cut some walnut pieces for the feet. These are going through the lathe later on.
    And here's a key lock mechanism. I'm going to mod it some...
    I will replace this part later on... But I don't want to spoil everything right now =)
    //Quizz
  4. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    The construction for the 25 drawers test mounted.
    These are two of four feet made in the lathe
    Here's that unfolding desk in progress. Two 8mm MDF pieces glued together, then a LED strip added.
    The warm yellow LEDs will make a light show inside the window, from the outside.
    Inside the window I'll have walnut, and so I added a 6mm MDF piece with a sheet of walnut veneer on top of the rest...
    Here's the cables from the LED list...
    And here's the great part of this construction. The cables are now being covered by an ash piece.
    After that, veneer on both sides...
    I had to get rid of the veneer covering the circular window with a sharp scalpel.
    Then it was time to make a hole for the locking mechanism, and thereby hopefully also find the cables I hid inside.
    And there the are... Had to be careful not to ruin the cables when milling the hole.
    Cables pulled out
    For the drawers I'll use 6mm birch ply... 25 drawers are a lot of material!!
    I'm going to use golden velvet for the bottom of the drawers... Though about classic green cloth first, but it's always fun to try something new.
    I cut two 8mm thin sheets of walnut and started on the inner panels. After some laser cutting I used a milling tool with a very small bearing. I wanted a small profile, getting rid of that "lasercut touch".
    Much better...
    Here are the panels in whole. Will go into details later on...
    //Quizz
  5. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Cut the hole for the pop-up monitor and made a cover piece. For the cover piece it's ideal to find a piece of veneer that blends in. Not perfect, but I'm pretty close I think.
    Close up
    Started on the box making for the drawes. I need 25, so it will take some time I guess...
    First boxed glued.
  6. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    When all wood work is done, time for some staining... I picked up some samples from the local hardware store. I chose to do a mix between these two for the perfect patina look
    Not too red, not too gloomy. Perfect! Starting with the bottom piece.
    Here's the bureau stained with everything glued together. Very happy with the result!
    Just a little close up of beautiful grains.
    I made the knobs for the drawers from a 12mm round bar in brass.
    Here are 25 drawer knobs plus some additional ones for the tech panels
    After holiday's over I'll start on the fun, hardware installation!
  7. G0oB
    G0oB Fresh made Modder
    27 Jul 2010
    Again you show amazing woodwork, wow
    cant wait to see how this turns out!
  8. Asouter
    Asouter --------
    18 Jan 2012
    Yay a new quiz project,while I've got nothing on at the moment I'm looking forward to relaxing and watching you work ...subbed :D
  9. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Hey, I returned to BT just in time to spy a new Squid project. Looking interesting so far.
  10. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    wow the bureau is looking very nice already, can't wait to see how this turns out :) Subbed!
  11. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanks G0ob!
    Thank you Asouter! I'll continue with this one as soon as holidays over...
    Thanks Wisdom! Wasnt sure I was gonna put this one on BT, but... it does include a PC rig =)
    Thanks Meelobee! Appreciated!
  12. bulldogjeff
    2 Mar 2010
    Yet another project on the go.. Do you ever sleep..lol
    Nice one dude
  13. David
    7 Apr 2009
    I'm fascinated already. Subbed!
  14. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanks jeff! I mod in my sleep, a bad habit :)
    Thanks man!
  15. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Update:
    Been working a lot the last couple of weeks now. I would say this piece will be finished by next week, hopefully.
    I decided to remake all the 25 chest drawers. That's a lot of work, but I didn't like the ply ones. Made them from birch this time, and a little thicker as well. Here are the materials cut out.
    One box glued together.
    Finished drawer with front in walnut. Also ditched the brass knobs, and made small holes instead this time. A bit more playful...
    Then I made a mount for the monitor and the linear actuator. Alu, just very simple...
    Test mounted. Seem to do the trick!
    I made a mount for PSU and the 360 rad. Acrylic lasecut, pretty simple, but I like it =)
    Another angle.
    This is how I mounted disks and pump
    And here's the MB+GPU mounted, as well as the James Bond styled monitor lift. Pretty tight fit with all those drawers. Yikes!
    Here are the parts for the locking mechanism mod. It's going to serve not only as a lock, but also as a light switch. Very unique! I lasercut an acrylic clone of the original steel plate and made two small conductive plates for +&-
    This is after gluing and sanding...
    This is where I am right now, working on the tech panels. More about these later...
    Over and out!
    //Quizz
    The_Crapman likes this.
  16. Hukkel
    Hukkel James' minion
    20 Dec 2012
    What an original project. I like it a lot!
  17. The_Crapman
    5 Dec 2011
    Incredible work as always. Just seen in your first post a warning for people who don't like wood builds, they'd be crazy stupid to miss out on this or any of your other builds. Mad modding skills mixed with craftsmanship of the highest standard. What not to like?
  18. thegyufi
    thegyufi What's a Dremel?
    21 Mar 2011
    dude, your project is just awsome, please continue just like this ! can't wait to see the final !!
  19. Knighthammer
    Knighthammer What's a Dremel?
    18 Feb 2011
    Subbed - looks awesome!
  20. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    Nice work... though I would have just used solid oak myself , but it's cheap here by me, no idea what it's like over there...
