Case Mod - In Progress Project Streamliner (upd 23.12.14)
Discussion in 'Project Logs' started by aio, 16 Mar 2014.
  1. aio
    aio Minimodder
    8 Jun 2012
    Hi. Theme of this project is "retro cars"
    Part1
    Thermaltake Element S. In the picture: without excessive parts
    Front panel frame
    Excessive parts are cut with a dremel tool, holes of 2 mm are drilled out, factory paint is washed off
    Put back
    New front panel 3d model.
    Milling. Aluminum 35mm
    Thread M2 for coupling with frame
    Side panel
    The same actions were taken as for front panel frame
    Side wall panels. Vector
    Laser cutting. Aluminum 2mm
    Jointly with frame
    Punchdown rivets connection
    After grinding
    Heads (other side)
    Mnpctech feets
    Pranja likes this.
  2. Nexxo
    23 Oct 2001
    Stopmotion animation and sweet, sweet CNC'd aluminium. I'm sold. :)
  3. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Really unique and lovely stop motion animation; love it.
  4. Guest-23315
    Guest-23315 Guest
    Stopmotion is awesome for case mods.
  5. Darkened
    Darkened Minimodder
    28 Feb 2004
    That's a cool (and arduous) way of presenting a mod. Well done!
    I'll keep my eye on this for sure.
    Darkened
    Pranja likes this.
  6. Cheapskate
    13 May 2007
    Holy Cow! Hand riveting!:thumb:
  7. aio
    aio Minimodder
    8 Jun 2012
    Part 2
    3D models of front panel plates
    1Milling stage. 2mm brass
    Bending
    Second stage of milling
    Gas-oxygen welding pack rack
    Brass pins HMP soldering
    Plates took seat after through holes were made
    Side panel plates. Vector
    Laser cutting. Brass 2mm
    Brass pins M2. Brazing
    Overall view
    Mistook about two bottom holes sizes. Patch
    Parts after sandblasting. Flux, dross and cutter marks are removed.
    Sandy texture is a kind of artistic solution.
    After sandblasting, threads are made again on pins.
    External exposed surface grinding
    Apertures pattern for bottom plate was taken from the radiator grill of Soviet car GAZ-13 "Chaika" [​IMG]
  8. Attila
    Attila still thinking....
    22 Feb 2008
    GET OUT! :eeek: Awesome work dude. :dremel:
  9. aio
    aio Minimodder
    8 Jun 2012
    Thanks man :D
  10. aio
    aio Minimodder
    8 Jun 2012
    Part 3
    Photos coming soon
  11. Hukkel
    Hukkel James' minion
    20 Dec 2012
    It is not my style of modding, but your presentation and work on it is amazing. Such cool videos!
  12. David
    7 Apr 2009
    This is first class.
    The video work must be very time consuming, but it's such an effective presentation method. Well done.
  13. MarkVarley
    MarkVarley Minimodder
    12 Sep 2014
    I love the way you compose the videos, done interesting points in the case too :)
    Sent from my GT-I9505 using Tapatalk
  14. Cheapskate
    13 May 2007
    Delicious
    Delicious!!!!!​
  15. bulldogjeff
    2 Mar 2010
    This is lovely. The look the way it's being put together. It's all seriously cool. Top modding dude :thumb:
  16. aio
    aio Minimodder
    8 Jun 2012
    can you say more about your style of modding ?
    Thanks
    :hip: woow, woow, thanks
  17. aio
    aio Minimodder
    8 Jun 2012
    Let's deal with the chassis
    Dismantled chassis
    Unnecessary parts are cut off
    L-profile aluminum stiffening rib
    Cable channel made from square aluminum tube for the inner lining of a power cable
    Let’s take off the factory paint and join the parts
    Powder coating, RAL9005
    Rear part of the case
    Also cut off unnecessary
    The most difficult part for paint removal
    Filling piece for the rear panel. Laser cutting, groove milling. 2 mm aluminium
    Riveted
    Four brass standoffs for mounting one prop that appears at the end of the project.
    Powder coating, RAL 3011
    Assembling the chassis
    Bottom part of the case
    The insides are cut, the paint is washed off.
    On its place
    Riveting
    New parts
    Laser cutting. 6 mm aluminium
    Profile for LED strip
    Inserted in the grooves
    Bottom of the case assembled
    RGB LED stripe inside the profile
    Stripes are covered with light-diffusing cover. Feet are bolted to the bottom
    The connection between the bottom and the frame
    PCI slot plugs. Laser cutting, CNC bending. 1 mm steel
    HDD enclosure. Laser cutting, CNC bending. 2 mm aluminum. Round brass standoffs are used instead of shelves
    On its place
    Cable channel for power cable
    Angle IEC cable.
    Box for insulation of the high-voltage power connector and for storing of excess length of the power cable. Inserts into the HDD enclosure.
    On its place
    High-voltage plug is soldered to the cable
    Bolted
    Ventilation grids of the bottom
    On its place
    Enclosure is ideal for 2.5"drives. It also supports the installation of 3.5" drives by two outer mounting holes
    Frame for vertical installation of PSU
    On its place
    Top panel of the original case. Powder coating, RAL 3011
    Added fastens for internal illumination
    The hull is ready
  18. Cheapskate
    13 May 2007
    Awesome.:D
    -It seems it would have been easier to build the entire case from scratch. You obviously have the skill to do that.
    Vetalar likes this.
  19. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    :eeek:
    How did I miss this...
  20. aio
    aio Minimodder
    8 Jun 2012
    In the beginning it was planned to make it in an easier way
    "The appetite comes with eating" :)
    welcome :)
