Thread Tools | View Mode |
#1 |
What's a Dremel?
"Experimental-Lambda-Core" HL² Mod
Butterkneter's "BLACK MESA EXPERIMENTAL LAMBDA CORE" Already testet on a LANSession with 1224 Gamers. It worked !!! (sorry for my terrible english) After many hours of work now its almost done ( 99%). Inspired by the phantastic work of Piloux, I also decided to build a HL² Mod. System: Gehäuse - Chieftec CS 901 Server TowerMainboard Gigabyte GA - 7VRXP 1 GB DD Ram PC 2100 Netzteil 530 Watt Sapphire Atlantis Radeon 9700 Pro Soundblaster Audigy Gamer 1 Nec DVD-Burner, 1 x DVD 4 Harddisks = 280 GB 7200 rpm L O G : At the Beginnig I used Sketchup to help me imagine how it would look like. . . The Layout of the frontdoor . . . . ![]() First a little Shoppingtour Here what i found in a little turkish store . . . ![]() Some Base Painting of the Interior . . . ![]() ![]() First Tests with the Rustpainting ![]() here on with Polystyrol. My favourit material ![]() here on some other built- in- elements The Frontdoor . . . ![]() DVD-RW and DVD ![]() the 120 mm Fan ![]() the exterior Fan (80mm) with LED Lights. ![]() The Reactor-Core . . . ![]() The Rustpainting for the TFT an the keyboard ![]() ![]() the side-doors of the CS 901 without . . . ![]() ![]() the side-doors of the CS 901 with Rust . . . ![]() ![]() First Test of the layout for the Frontpanel ![]() The Result ![]() With Killswitch , Keyswitch, Cigaretlighter + + + + + + + + + + + + + + + + + + + + All together it looks like this . . . ![]() ![]() ![]() to be continued . . . Butterkneter Last edited by *Butterkneter*; 18th Aug 2004 at 20:50. |
| *Butterkneter* |
| View Public Profile |
| Find More Posts by *Butterkneter* |
#2 |
Multimodder
That´s some awesome work.. the HL2-theme has been kind of overdone by now, but whatta heck that case is just top notch!
#3 |
Multimodder
i couldnt care less how many people do the ideas as long as new ideas are made and i love some of the modding in this, one question how do u do the rust affect and/or do you know how to do a burnt or cindered look, this is for my inferno case project not yet writen up
| crash32953295@msn. |
| Find More Posts by crash32953295@msn. |
#4 |
What's a Dremel?
nice |
| Dr.Headshot |
| Find More Posts by Dr.Headshot |
#5 |
Hypermodder
to crash... :
you could use the search to find how to rust a case... I think this has been talked about a few time. btw : excellent mod Butterkneter
__________________
my english's not so bad ... Aluminium rig:-Darkcrystal woodcase:-Blackmesa HL²case:-Bit-Tech pics_log:-Valvesoftware DemoPC:-Bit-Tech_part1-Bit-Tech_part2 |
#6 |
What's a Dremel?
THX to Piloux
What a Honor to get acknowledgment by the "Hypermodder" here is some more . . . here the Sidedoors with the Bulletholes, which TheSchumi copied in his mod. the CD Storage closed . . . . open . . . here some pictures in the dark look at the Bulletholes. . . with Case open . . . a bit closer . . . The "Lambda-Core" a self-made Warning sign . . . a little accessoir. . . Butterkneter . . . and here is the Control-Unit
| *Butterkneter* |
#7 |
Multimodder
ok jus a little not i jus did a search turned up nothin apart from your exellent half life project, have u made a guide on this?
and since ur the one in the know, any ideas on a burnt/ sincged effect. and again exellent mod *Butterkneter* |
#8 |
..look but don't touch..
looks great, although it's this theme is a bit overdone... btw... what is black messa? i still haven't cought what it is
this is definately in the top 10 of hl2 mods. I just hope the game doesn't turn out to be a flop
__________________
Acid Burn ================= Water cooling is like unprotected sex.. one spill and you're #&%¤%"/!)#() up! Project Green Dragon |
#9 | |
Modder
__________________
Write that down.
#10 |
What's a Dremel?
I don't think HL2 mods are overdone, I think the rusting paint effect is overdone. But good mod, eitherway.
#11 |
grunge modder
Its not a question of Quantity
But it is a question of Quality....
I don’t care how many H2 or rust mods are done, as long as they are kicka** mods. This is defiantly one. Great job. <suggestion> You may want to go into more detail on how you made some of your components, like your 'lambda core' or the detail on the door. How did you make those? Note to everyone: Get used to seeing these types of mods. A destroyed, aged or rusted mod is a lot more user friendly then trying to build a mod that looks stock, as well as a lot cheaper to do unless you work at a cnc shop. Lets not rag and say "its been done" at least its getting done.... <IMHO>
__________________
Don't Tread On Me! I suppose that makes me a radical now... Project: Perforated, a Grunge Mod - cut down Antec Dragon case, SciFi themed 'Aliens' mod - Maximum PC Rig of the Month Aug 2005 Project: Harlot 5, a Grunge Mod - SFF Scifi themed, Flight Data Recorder |
#12 |
Minimodder
Butterkneter postet "his" Bulletholes in an german forum earlier than aug. 13th. Originally it's his how2 but i can't understand his reaction... that's studip.
#13 |
Multimodder
who cares about copying bulletholes, the mod rox! ^^
btw would it be cooler to like 'mask' the purple color and keep it orange with a bit of that radioactive stuff
__________________
left hand : buy and spend right hand : smash to pieces and rebuild it better
#14 |
Supermodder
realy nice job
The front realy rules. IMHO, the rust-projects are not overdone. its just a new way of modding, i like them more instead of all those standard modded lian li's and chieftecs without own ideas.
#15 |
Patmol
Guest
Posts: n/a
you took with some idea of mod HL2 of Piloux but it is a beautiful mod nevertheless
I love the "Lambda-Core"
| Patmol |
#16 |
Banned
This is sicker than Piloux!
| -N4cR-Stigma2K |
| Find More Posts by -N4cR-Stigma2K |
#17 |
Plexi Expert
Looks good, just a little too much of the theme now...
I really like the side panels though and are interested in how the lettering is "painted" on...
__________________
Total Mod (n) :: Project Divergence and Convergence... Project Divergence The Ultimate Premod First Place PC Club CM3 Case Modding Contest Project Convergence Bit-Tech's next great Plexi Mod - Handcrafted Modified Art in Action PC's :: Designed on a Mac... 12 inch powerbook running sketchup 5...
#18 |
Supermodder
wow, it really does look like a server version of the blackmesa mod by piloux.. good work though.. despite alot of the cases im seeing following the rust effect.. they are all turnin out to be original in their own way..
great mod
__________________
Hexus Feedback |
| TheCleaner |
| Find More Posts by TheCleaner |
#19 | |
and the fact that piloux lives in belgium which is a crap country when it comes to finding good parts, makes his mods even better. can anyone tell me what black messa is?
__________________
#20 |
What's a Dremel?
You should play Halflife . . .
Black Mesa is the corporation , Gordon Freeman , the main character of the game, worked for. Nobody wants to "BEAT" Piloux. This is not a match. Modding is simply fun !!! |
| *Butterkneter* |
| Thread Tools | |
| View Mode | |
