Project: UNKNOWN JOURNEY ** UPDATE (4th Feb) ** DVD fixed and button moved **
Discussion in 'Project Logs' started by philb, 14 Oct 2004.
  1. philb
    philb What's a Dremel?
    2 Jan 2004
    This project started about 2 months ago, but the ideas got vastly changed. So this is the start of my new project log!!
    The idea is that case will be smooth and curvy, with a little individuality!!
    This is my first real case mod, and so my first ' unknown journey'!
    The skeleton
    My new top
    New position DVD drive and make shift support
    The mould shape, so far. Stretched fleece ready for fibreglass resin
    Updates soon
    Comments and opinions please
  2. Bentos
    Bentos What's a Dremel?
    12 Feb 2002
    im loving the position of the dvd rom, what made you decide to put it at that angle ?
    and does it still only take one drive bay slot ?
  3. Arkuden
    Arkuden mow?
    9 Jul 2004
    that looks awesome. Very nice idea. Cant wait to see the rest!
  4. Tr!nk
    Tr!nk What's a Dremel?
    24 Aug 2004
    I love the cd-drive set up! :thumb:
  5. LunatiC
    LunatiC What's a Dremel?
    4 Sep 2004
    dude! thats awsome! i love it! :rock: :rock:
  6. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    I'm diggin the fuzzy look on it!! :)
  7. Atarax
    Atarax What's a Dremel?
    13 Jul 2004
    very original, im loving it so far. Im modding the same case myself, so im very curious to see what u do with the remaining drive bays. keep me posted. *subscribes* :dremel:
  8. philb
    2 Jan 2004
    Update Part 2
    UPDATE
    Just finished the rear PSU fan intake surround. this now needs to have the fleece pre-mould made and the resinned.
    The drive bay at the top has now been covered in resin. \this has set extremely hard due to two coats and drying under a very hot lamp. The bay is now ready to be sanded and fillered ready for painting.
    With the resin applyed and drying
    Psu fan intake 92mm , maybe cahnging to 120mm fan? Comments?
    Which mesh for my newly painted fan??
    COMMENTS PLS
    UPDATE SOON
  9. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    What you are doing looks awesome. :thumb: This will be a project to watch. What is the maximum angle a CD/DVD ROM will work at?
    Can you shed some light on the fibreglass resin mod you are doing? What material did you use? I am looking at using a similar technique in manufacturing some speaker pods for my car but am concerned about structural integrity. Just how tough is that skin?
  10. jezmck
    jezmck Minimodder
    25 Sep 2003
    Great to see some unusual skills and materials being used - definitely watching this one.
    BTW:
    HDDs, CDs/DVDs, etc can be used at any angle - moving it while it's spinning can be more risky. (ever picked up a lappy while it's reading a CD?)
  11. philb
    2 Jan 2004
    The method i am using is simply making a general skeleton with MDF, then stretching a porous material over the skeleton, and fixing under the base with glue, such as hot melt. The material i have used i fleece, this is because it has a little stretch in it, to get a smooth shape and also it soaks up alot of resin, to give the strusture stiffness. This the mould will be sanded covered in body filler and sanded. Then u can either apint it, which will require fine sanding, or if ur making speaker pods maybe cover them in some material, less sanding.
    I have used this technique to build door pods in my car, and the finish and structure have been going well for 9 months now. The fibreglass makes a very good enclosure for the speakers!!
    any more qusetions just ask.
  12. philb
    2 Jan 2004
    The techniques i am using are not that widely used in pc modding, but for car installs. i was shown these techniques by a pro car entertainment installer, so there still to do with modding, just a littel bit of a different direction!!
    :confused: :confused: WHICH MESH + DO U THINK THE FAN FOR THE PSU SHOULD BE 92mm or 120mm?? :confused: :confused:
  13. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    cool ideas!!!! I'll be watching this one :thumb:
  14. Exomoto
    Exomoto What's a Dremel?
    21 Sep 2004
    the top mesh looks much much better, the bottom isn't particularly nice
  15. Constructacon
    12 Oct 2004
    From where I sit, both of the meshes look like the same type of expanded metal mesh - but with different size holes. I like the bigger holes.
    Fleece? I've never heard of it (apart from comming off of a sheep's back). I have seen a similar technique using t-shirt material (very thin) for the initial coat, then reinforcing by using chopped fibreglass strand on the back (impractical for my purpose). What you term fleece looks (to me) like a sheet form of dacron, similar to what is used as filler inside sub boxes etc. Am I close?
    I like the direction you're heading with the rounded edges and putting things on different angles. This is one to follow.
    /subscribe
  16. G4m3R_X3r0
    3 Sep 2004
    where did you get your wire mesh from.
  17. Daewood
    Daewood What's a Dremel?
    16 Oct 2004
    lookin good i might just have to build some custom enclosures for those 10 inch subs in my truck and might i ask where one would buy fiberglass resin and how to sand it? :confused:
  18. philb
    2 Jan 2004
    The fleece material, is material that is used for tops, abit like sweatshirt material.
    The mesh is from a car body shp, used to fill the holes in front bumpers etc.
    The resin can also be purchased from car body shops, or hardware stores, also a small tube of hardener is needed.
    The resi can be easily sanded y hand, or with a small file or orbital sander/dremel.
    KEEP THE COMMENTS COMING :confused:
  19. Nevex
    Nevex What's a Dremel?
    25 May 2004
    This one is gonan be a sick mod. I am adding to my watch list.
  20. Daewood
    16 Oct 2004
    thanx for the reply that is a really cool mod you got goin on and keep the posts coming
