Cooling 120mm fans required
Discussion in 'Hardware' started by donok, 23 Mar 2014.
  1. donok
    donok Every Little Helps .....
    16 Feb 2011
    hello people
    I have a fractal arc mini case and will be fitting it with some new fans. Just brought a Corsair H80 and will be getting a msi r9 290 at the end of April.
    Im looking for some powerful but quiet fans. the PC is in my bedroom and the quieter the better but I'm a student so cheaper the better also.
    I was thinking about going for the corsair AF120 quiet edition. you can get a dual pack for £20 on Amazon
    I then stumbled upon the Bitfenix spectre pro fans which are £9.80 each on Amazon.
    I was thinking about a total of 4 fans. 2 in the front and 1 on the H80 in rear and 1 in the roof.
    Any ideas would be great
    thanks
  2. narwen
    narwen narwen
    6 Aug 2010
    I've not used either fan but looking at the specifications the bitfenix looks best.
  3. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
  4. spolsh
    spolsh Multimodder
    4 Feb 2012
    Agree with AlphaAngel, I've got 3 bequiet PWM 120's in my rig and they're great, the mobo looks after controlling them, so no need for a fan controller, and they're whisper quiet even when working hard. I haven't tried them on an AIO cooler though.
    edit : I'm sure I saw a thread the other day saying that they were tricky to mount in rads due to the rubber mounting system they use instead of ordinary screws.
  5. Nexxo
    23 Oct 2001
    Personally I'm taken with Phanteks fans, but they are a bit pricey. The Akasa Apache and Viper series are also reported to be quiet and powerful, and would have been my second choice. In reviews both come out consistently well.
    The BeQuiet series are certainly good, but like the NoiseBlocker series, in reviews they are rated slightly more variable. The Corsair series seems expensive for what they are, and you might as well pay out for Phanteks or Noctua fans. However at this level, differences are likely to be small.
  6. donok
    16 Feb 2011
  7. donok
    16 Feb 2011
  8. donok
    16 Feb 2011
    so 4 fans at around £6 each
    1. Enermax - 11.0dB - 42 CFM
    2. Be quiet - 19.2dB - 51.4 CFM
    3. Air Pen - 19.7dB - 42.6 CFM
  9. donok
    16 Feb 2011
    wow the price difference from pure wings 2 at £6 and silent wings at £16 is huge.
    with very little change in the specs - 3DBA
  10. techhead
    techhead Minimodder
    17 Jul 2010
    The Enermax fans are ok as case fans they are very quiet I have 5 in my case. But to use on the back of a rad they are no good they have no static pressure
  11. donok
    16 Feb 2011
