Electronics 120vdc from a pc PS
Discussion in 'Modding' started by Frogbutt, 22 Oct 2003.
  1. Frogbutt
    Frogbutt What's a Dremel?
    15 Feb 2003
    I got some small cathode neon light bulbs off ebay and want to use them in a case mod. The sell says I need to hook them up at 120vdc at very low current. What would I need to get that out of a Computers PS?
  2. OrbDemon
    OrbDemon Minimodder
    6 Jul 2003
    An ac inverter - to step the 12v dc from your psu to 120v ac to power the lights i suspect.
    If so, an inverter suitable for an electroluminescent LCD backlight, would probably surfice.
    BTW: aren't those 2$ bills as rare as hens teeth?
  3. hacnslash
    hacnslash What's a Dremel?
    20 Aug 2003
    no, in fact i have 2 sitting on my desk as i type this, one is a 1995 and the other one is 19 sixty something, its really crumpled up...
  4. Frogbutt
    15 Feb 2003
    you recomend a place that sells one thats not part of a kit?
  5. hacnslash
    20 Aug 2003
    wait, didn't he say he needed 120vDC??
  6. Frogbutt
    15 Feb 2003
    your right the sellers exact words were "120vdc at very low current"
  7. OrbDemon
    OrbDemon Minimodder
    6 Jul 2003
    Doh! I just noticed that when I re-read the topic title! Sorry!
    Only thing I can think of is some sort of step up transformer then...
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    With neons you get the glow at the negative electrode, so if it's shaped as a reflector that makes sense. A diode or bridge rectifier on the CCFL inverter output would give you DC, but don't blame me if you blow the bulb or the inverter. :worried:
  9. best49erfan
    best49erfan What's a Dremel?
    27 Dec 2002
    try www.allelectronics.com
    part number ex-38
    It says that a 6V DC supply gives you 90VDC So maybe 9 or 12V should give you what you want
  10. dfhaii
    dfhaii internets
    24 Mar 2002
    with cpemma on this, a bridge rectifier on a ccfl invertor, dont forget though that the dv from thet will be ~1.41 * as much as the ac out.
    Col
    :clap: same disclamer as above :lol:
