1700+ overclocking - please help
Discussion in 'Hardware' started by Irteza, 19 Apr 2004.
  1. Irteza
    Irteza Banned
    14 Mar 2004
    i got a amd 1700+ and i wanna overclock it . can you tell me how far i can overclock my processor btw i got crappy 2100 ram
    this is what it says on the core
    AMD ATHLON
    AXDA1700DUT3C 9269327260686
    JIUCB 02515PMW (M) (C) 1999 AMD
    btw the processor is unlocked from the factory :rock:
  2. sk8ero
    sk8ero What's a Dremel?
    27 Oct 2003
    i got my athlon xp 1700+ palamino core up to
    1.6ghz was 8x200mhz
    i joined the L1 bridge to unlock multipliers
    i also had pc2100 ram, if i had better ram i think i cudda
    got up to about 205 - 210 fsb
  3. TMM
    TMM Modder
    12 Jan 2004
    all CPUs overclock differntly. you will have to overclock slowly, by trial and error.
    also depends on your cooling... and motherboard. also there is no point running 200+mhz FSB if you only have pc2100 ram. i'd invest in some Pc3200 or better.
    Getting past 2ghz should be easy :p
    check out:
    http://forums.bit-tech.net/showthread.php?t=51323&page=1
  4. Irteza
    Irteza Banned
    14 Mar 2004
    do you think i can overclock my processor high like other people did with their's if i get geil golden dragon 3700 2x256 memory
    im paying abt £80 quid for this memory is thisk ok for the price or can you recommend any other memory for the same price btw i wanna overclock so i need a good memory i read some reviews about golden dragon and they seemed to be the best overclockers in the roundup :thumb:
  5. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    Several comparisons show that the high end brands of RAM (Geil, Corsair, etc) give little advantage (2-3% performance) over good old crucial RAM. You'd be better off saving the money for a new chip (mobile barton 2500 is only £60-70), motherboard or graphics card. :idea:
